Active IQ Unified Manager KBs
Other Resources
- Cluster acquisition via REST fails in AIQUM with NPE on GMode ConversionJun, 2026
- AIQUM 9.18 encounters an out-of-memory condition that causes the service to stop and become inaccessibleJun, 2026
- Unpacking of baseline messages failed with error: {} : java.lang.ClassCastException : java.lang.ClassCastExceptionJun, 2026
- Snapmirror Lag Status not populated with REST based acquisition in AIQUM 9.16P2Jun, 2026
- AIQUM volume page status display alarmJun, 2026
- Is it possible to have two or more clusters with the same name in AIQUM?Jun, 2026
- Operation state "Failed" with status Green in AIQUM GUI due to excessive stale lun map entriesJun, 2026
- Active IQ Unified Manager 9.8 unavailable on Support SiteJun, 2026
- Server shows the connection is insecure after installing a CA certificateJun, 2026
- Unable to launch AIQUM in OVAJun, 2026
- Unable to add cluster to Unified Manager due to duplicate certificate entries in a clusterJun, 2026
- Ontap ems severity to Active IQ Unified Manager event severity mappingJun, 2026
- Is there an equivalent to volume latency in Unified Manager by using ONTAP CLI or SNMP?Jun, 2026
- Unable to access AIQUM by assertion failure due to corruption on MySQL tablespaceJun, 2026
- How to create custom REST calls for Active IQ Unified ManagerJun, 2026
- How to change language for Unified Manager graphical user interface and documentation on browserJun, 2026
- After installing Active IQ Unified Manager 9.7 for Windows, the NetApp Active IQ Acquisition Service fails to startJun, 2026
- Active IQ Unified Manager Update fails because of password settingJun, 2026
- Active IQ Unified Manager install hangs - Please wait while the application is preparing for first useJun, 2026
- AIQUM VMware vSphere reported CVE-2025-41244 and CVE-2025-14087 VulnerabilitiesJun, 2026
- 'Vserver Configuration Is Not In Sync' alert for MetroClusters is not present in AIQUM MiB
- "Asynchronous Vault Lag" event in Unified Manager
- “Cannot store non-PrivateKeys” Error When Managing EMS Events in AIQUM
- "failed to register EMS" when trying to add new cluster in Active IQ Unified Manager 9.7P1
- "No External NTP Servers" alert is received in AIQUM
- "NVRAM Interconnect Link Down" alerts triggered several hours after the actual event
- "SSH is using insecure ciphers" event is detected on Active IQ Unified Manager
- "Unable to locate any package files" when trying to upgrade Active IQ Unified Manager
- "unified-manager-server-disk-space-nearly-full" is reported on AIQUM vApp. Is this event ignorable?
- "Volume Partially Available" events generated on AIQUM server
- 404 error received when attempting to launch the AIQUM WebUI
- 404 error received when attempting to launch the AIQUM (for OVA) WebUI
- AIQUM 9.16P2 and above upgrade fails or service fails to start with MySQL auth protocol error in server.log
A
- A few days after takeover/giveback, AIQUM warns that ONTAP is failing over
- Access fails in AIQUM with LDAP error code 1
- Accessing AIQUM WebGUI fails with ERR_Connection_Refused
- Acquisition does not work in AIQUM due to memory not being enough
- Acquisition failed for all clusters in AIQUM due to maximum connection limit exhaustion
- Acquisition fails after AIQUM upgrade: Connection Attempt via HTTP Instead of HTTPS
- Acquisition fails in AIQUM for all clusters due to disk space issue
- Acquisition fails with NullPointerException on Active IQ Unified Manager 9.9
- Acquisition Service fails to start after MYSQL DB restore in Windows
- Acquisition service is not running on ActiveIQ Unified Manager installed in Windows
- Acquisition service is not working in AIQUM because of IIS service running in Windows
- Active IQ login redirects to BlueXP and login fails
- Active IQ reports FlexGroup Constituents Have Inodes Issues
- Active IQ Unified Manager - Performance statistics not displaying in explorer tab
- Active IQ Unified Manager "hostname.err" file fills up disk on Windows
- Active IQ Unified Manager “Lag Status” show Warning or Error for volume relationships?
- Active IQ Unified Manager "Permission Denied" error when trying to download a Support Bundle
- Active IQ Unified Manager (AIQUM) EMS Subscription not Working
- Active IQ Unified Manager (AIQUM) missing IOPS and other performance data
- Active IQ Unified Manager (AIQUM) Web Interface Fails to Load with HTTP 404 Error
- Active IQ Unified Manager /api/management-server/events API throws error: "Duplicate key"
- Active IQ Unified Manager 9.14+ does not retrieve any performance data any cluster
- Active IQ Unified Manager 9.7 error "The MYSQL8 service on Local Computer Started and then stopped."
- Active IQ Unified Manager 9.7 polling fails
- Active IQ Unified Manager 9.7+ vCenter server acquisitions fail with the error: "The vCenter data cannot be processed"
- Active IQ Unified Manager 9.7RC1 cannot monitor vCenter with error "Discovery failed, the vCenter data cannot be processed"
- Active IQ Unified Manager 9.8 is not discovering VMs that are created on a NFS 4.1 datastore
- Active IQ Unified Manager 9.9 on Windows is vulnerable to MySQL 8.0.21 security advisories
- Active IQ Unified Manager 9.x services are crashing spontaneously
- Active IQ Unified Manager acquisition fails using IPv6
- Active IQ Unified Manager acquisition fails with "internal error has occurred during MetroCluster component refresh"
- Active IQ Unified Manager acquisition fails with: Data source with name X was not found
- Active IQ Unified Manager aggregate capacity commitment calculation
- Active IQ Unified Manager alert configuration and management Resolution Guide
- Active IQ Unified Manager alert: Aggregate RAID status is reconstructing because of broken disks
- Active IQ Unified Manager alerts on 'Aggregate Nearly Overcommitted' and 'Aggregate Overcommitted'
- Active IQ Unified Manager Alerts on disk-shelf-path-failure
- Active IQ Unified Manager and EMS Alerts Resolution Guide
- Active IQ Unified Manager API 'access_endpoints_get' fails with error 403
- Active IQ Unified Manager backup failing with "Table 'table_name' doesn't exist"
- Active IQ Unified Manager cannot update address of cluster datasource
- Active IQ Unified Manager cannot use a load-balanced or round-robin SMTP mailhost or Syslog server where backend nodes present individual TLS certificates
- Active IQ Unified Manager Certificate Regeneration and Importing Resolution Guide
- Active IQ Unified Manager cluster health polling is stuck, slow, or fails
- Active IQ Unified Manager cluster monitoring fails with error: "Failed to parse response"
- Active IQ Unified Manager Cluster monitoring fails with error: Failed to fetch the HTTPS certificate. Enter a valid Hostname or Port
- Active IQ Unified Manager Cluster Polling Stuck Resolution Guide
- Active IQ Unified Manager Cold Data Reports n/a after ONTAP upgrade
- Active IQ Unified Manager collecting inventory from cluster resolution guide
- Active IQ Unified Manager Completes Health Polling But Has No Performance Data
- Active IQ Unified Manager CVE-2022-23235 Vulnerability Workaround
- Active IQ Unified Manager Dashboard Stuck at “Data for the newly added cluster will be available shortly” Message
- Active IQ Unified Manager database backup and restore resolution guide
- Active IQ Unified Manager database backup fails with MySQL 8.0.28
- Active IQ Unified Manager database corruption caused by disk running out of space
- Active IQ Unified Manager database restores take a long time
- Active IQ Unified Manager displays "404-Not Found" error when attempting to launch UI
- Active IQ Unified Manager displays a 404 Not Found when rebooted after updating the Performance Service Level policies
- Active IQ Unified Manager displays volume or aggregate percent space consumed graphs, but when exported to CSV file the space columns show 0
- Active IQ Unified Manager does not create events for subscribed EMS messages
- Active IQ Unified Manager does not generate an event for a status change on a Cluster object
- Active IQ Unified Manager does not process EMS notifications from unsupported lif types
- Active IQ Unified Manager does not remove manually subscribed events
- Active IQ Unified Manager does not send ASUP via authenticated proxy
- Active IQ Unified Manager does not show created users in the web UI
- Active IQ Unified Manager does not work in pure IPv6 environment
- Active IQ Unified Manager doesn't properly report protocols when viewing SVMs
- Active IQ Unified Manager doesn't report CIFS Shares
- Active IQ Unified Manager erroneously displays "Authentication failed. Please verify Username and Password" for a Local User login in the webUI
- Active IQ Unified Manager error 404 opening WebUI due to ocie service not started
- Active IQ Unified Manager error Sign in failed: verify Username and Password
- Active IQ Unified Manager error when attempting to setup Remote Authentication
- Active IQ Unified Manager event continously obsoleted despite already being obsolete
- Active IQ Unified Manager event: 'Too many snapshot copies' when managing ONTAP 9.4+
- Active IQ Unified Manager failed to collect data from the cluster with "Authorization failed" error
- Active IQ Unified Manager fails for LDAP user login even though LDAP test succeeds
- Active IQ Unified Manager fails inventory collections from a cluster due to certificate or network connectivity issues
- Active IQ Unified Manager fails to add a cluster due to a timeout reading the certificate
- Active IQ Unified Manager fails to add OnTap cluster currently monitored by Cloud InSights Workload Security
- Active IQ Unified Manager fails to install MySQL with "The GPG keys listed for the 'MySQL 8.0 Community Server' repository are already installed but they are not correct for this package."
- Active IQ Unified Manager fails to install on Linux when install directories are pre-created
- Active IQ Unified Manager fails to monitor a Metrocluster cluster after removing nodes from the setup
- Active IQ Unified Manager fails to read the cluster certificate due to network issues
- Active IQ Unified Manager fails to regenerate HTTPS certificate in Chinese GUI
- Active IQ Unified Manager fails to regenerate or import a certificate with the error "The CN of the host certificate is not valid"
- Active IQ Unified Manager fails to restore file with error "Invalid output from the cluster"
- Active IQ Unified Manager fails to retrieve performance data from ONTAP
- Active IQ Unified Manager fails to update performance poll interval when using the "um option set" command
- Active IQ Unified Manager for VMware Vsphere OVA – CVE-2021-4428 Apache Log4j Vulnerability – Workaround
- Active IQ Unified Manager forward time drift not being corrected by the NTP service
- Active IQ Unified Manager gives error "Authentication Failed. Please verify username and password"
- Active IQ Unified Manager global search results include objects that should no longer exist
- Active IQ Unified Manager GUI fails with Error 404 - Not Found following AIQUM upgrade due to Jboss permission errors
- Active IQ Unified Manager High CPU Usage - Resolution Guide
- Active IQ Unified Manager HTTPS certificate page does not open
- Active IQ Unified Manager ignores custom alert thresholds
- Active IQ Unified Manager incorrectly raises "Verify That Intercluster Peering Is Up" event
- Active IQ Unified Manager indicates NFS Service down for DR SVM
- Active IQ Unified Manager inform "Cluster Config Backups Are Not Being Pushed Remotely" alert
- Active IQ Unified Manager inform "DQP Package Downrev" alert even DQP is the latest revision
- Active IQ Unified Manager install fails to start the services due to missing files
- Active IQ Unified Manager install fails with "Non-fatal POSTIN scriptlet failure in rpm package netapp-um-9.X-XXXX.x86_64" on Linux platforms
- Active IQ Unified Manager Installation and Upgrade Logs
- Active IQ Unified Manager installation failing on windows using "SYSTEM" account
- Active IQ Unified Manager installation fails after downgrading MySQL from version 8.0.22
- Active IQ Unified Manager installation hang on "Configuring MySQL" step on Windows OS
- Active IQ Unified Manager installation on Linux fails with "Waiting for MySQL.."
- Active IQ Unified Manager is down
- Active IQ Unified Manager is failing CommVault AuxCopy jobs due to duplicate volume names
- Active IQ Unified Manager is losing connection to monitored clusters due to InnoDB open file limit
- Active IQ Unified Manager is not able to collect data from a cluster
- Active IQ Unified Manager is not showing performance data for vCenter VM
- Active IQ Unified Manager is not showing total capacity for Capacity: All Volumes view
- Active IQ Unified Manager is sending multiple alerts on the same issue
- Active IQ Unified Manager is unable to add a cluster using HTTPS
- Active IQ Unified Manager is unable to add cluster because system clocks are not synchronized
- Active IQ Unified Manager is unable to add ONTAP cluster with time drift issues
- Active IQ Unified Manager is unable to receive EMS alerts from cluster, due to stuck data in Recv-q
- Active IQ Unified Manager Japanese environment specific issue Resolution Guide
- Active IQ Unified Manager keeps sending alerts after problem is already solved
- Active IQ Unified Manager Landing Page
- Active IQ Unified Manager Linux upgrade fails with GPG check FAILED and removes the existing installation
- Active IQ Unified Manager login fails because the Unified Manager security certificate is regenerated
- Active IQ Unified Manager monitoring fails with "Unable to retrieve samples from the performance archive for the same file"
- Active IQ Unified Manager monitoring of clusters stops after clock adjustments of VMware OVA
- Active IQ Unified Manager MYSQL Login Fails with the Error "This app can't run on your PC"
- Active IQ Unified Manager MySQL service periodically crashes, requiring the application to be restarted
- Active IQ Unified Manager MySQL service does not start due to log sequence number is in the future error
- Active IQ Unified Manager MySQL service does not start due to MySQL redo log corruption
- Active IQ Unified Manager MySQL service fails randomly, requiring an application restart
- Active IQ Unified Manager NDMP restore fails with invalid UTF-8 character
- Active IQ Unified Manager Not Generating Volume Full event
- Active IQ Unified Manager not loading due to its certificate expired
- Active IQ Unified Manager not sending alerts for all events
- Active IQ Unified Manager OCIE service stuck on "starting..."
- Active IQ Unified Manager OVA time drifts away from NTP time
- Active IQ Unified Manager performance collection fails because the web service is not enabled
- Active IQ Unified Manager performance collections failing due to disabled performance archives in ONTAP
- Active IQ Unified Manager Performance Data Collection - Resolution Guide
- Active IQ Unified Manager poll stuck "In Progress" due to a large snapmirror history table
- Active IQ Unified Manager Polling failed with a "Completed Unsuccessfully" error
- Active IQ Unified Manager polling fails and self-resolves randomly at any time
- Active IQ Unified Manager Qtree search returns 0 results even though search string is accurate
- Active IQ Unified Manager quota email notifications are missing SVM in generated output
- Active IQ Unified Manager redirects to Dashboard screen when using a link to access the UI
- Active IQ Unified Manager Remote Authentication Stops Working with the Error "Unable to Find Valid Certification Path"
- Active IQ Unified Manager reports 'missing source volume' against a CommVault managed relationship, but relationship appears to be working
- Active IQ Unified Manager reports "Storage failover not possible: unknown"
- Active IQ Unified Manager reports alert /test email failure error "Failed to send email"
- Active IQ Unified Manager reports Error Advisory ID: NTAP-20160412-0001
- Active IQ Unified Manager reports Log Forwarding Not Encrypted
- Active IQ Unified Manager reports that a volume is not subscribed to storage service
- Active IQ Unified Manager Resolution Guide for issues with monitoring VMware Virtual Machine
- Active IQ Unified Manager returns "No data" on Capacity Volumes/Aggregates view
- Active IQ Unified Manager running slow, unresponsive, or hanging on virtual machines
- Active IQ Unified Manager SAML Authentication Resolution Guide
- Active IQ Unified Manager scheduled reports do not send at the time defined in the schedule
- Active IQ Unified Manager scheduled reports not being sent
- Active IQ Unified Manager sends false positive events for Metrocluster
- Active IQ Unified Manager sends unwanted alerts even after disabling the relevant alerting
- Active IQ Unified Manager server show both in Cli and UI we see the SHA1 Fingerprint not SHA2
- Active IQ Unified Manager services are stops even after manual restart
- Active IQ Unified Manager services don't start after upgrade because of corrupted files
- Active IQ Unified Manager services not starting after successfully upgrading from 9.11 to 9.13
- Active IQ Unified Manager services on Windows installations might fail to start after an upgrade
- Active IQ Unified Manager services timeout when trying to start on Linux after updating java
- Active IQ Unified Manager shows "Storage VM CIFS Service Down" alert for certain SVMs
- Active IQ Unified Manager shows less than 72 hours worth of data despite successfully polling
- Active IQ Unified Manager shows Quota Type "None" and "N/A" in the Qtree Page
- Active IQ Unified Manager shows the incorrect "Last Successful Update" date for volume relationships
- Active IQ Unified Manager SNMPv1 traps recieved by localhost
- Active IQ Unified Manager SNMPv3 traps have varbinds in the wrong order
- Active IQ Unified Manager stops collecting the performance data
- Active IQ Unified Manager Support Bundle Automatically Upload Option Through Maintenance Console
- Active IQ Unified Manager Support bundle fails with "Invalid Date"
- Active IQ Unified Manager throws error "Resource-key not discovered" when managing a SnapMirror relationship
- Active IQ Unified Manager time drift issues
- Active IQ Unified Manager triggers multiple volume full alerts for all grouped volumes not honoring group level threshold
- Active IQ Unified Manager um run query fails selecting more than 1 field of a table
- Active IQ Unified Manager unable to communicate with the authentication server due to not configured properly
- Active IQ Unified Manager upgrade failed "Failed to start MySQL Service Setup will terminate now!"
- Active IQ Unified Manager upgrade failed. OCIE service will not start, .war files fail deployment
- Active IQ Unified Manager upgrade fails due to corrupt server keystore
- Active IQ Unified Manager upgrade fails if the MySQL 8.0 Community repository is not installed
- Active IQ Unified Manager upgrade fails on Windows as the server was rebooted
- Active IQ Unified Manager upgrade fails Unable to perform operation due to available disk space limitations
- Active IQ Unified Manager upgrade fails waiting for services to start
- Active IQ Unified Manager upgrade fails with error: Ports are in use
- Active IQ Unified Manager upgrade on Windows fails due to permissions issue
- Active IQ Unified Manager upgrade resolution guide
- Active IQ Unified Manager users are not able to login after OS upgrade (RHEL)
- Active IQ Unified Manager virtual appliance deployment fails in VMware Cloud Director
- Active IQ Unified Manager virtual appliance upgrade fails with error: "Failed to Upgrade platform_base"
- Active IQ Unified Manager virtual machine performance data not shown
- Active IQ Unified Manager vsphere virtual appliance hangs at the boot screen
- Active IQ Unified Manager web interface becomes unavailable around 4AM server time every few days
- Active IQ Unified Manager web interface goes unresponsive due to 'Too many open files' error caused by file descriptor leak
- Active IQ Unified Manager weekly database backup creation failed with the reason: MySQL database dump dump file was not created
- Active IQ Unified Manager with MySQL 8.0.22 causes NullPointerExceptions
- Active IQ Unified Manager: Post upgrade to 9.6 or newer scheduled reports are not shown
- Active IQ Unified Manager's discovery operation for a newly added cluster fails
- Active IQ Unified Manager's OCIE or OCIEAU(Acquisition) services will not start
- Active IQ Unified Manger fails to run alert scripts on object names containing an ampersand
- ActiveIQ event remain NEW in Unified Manager even after getting cleared from AIQ
- ActiveIQ UM 'Assign System Recommended Performance Service Level' is not adaptive to a highly variable workload
- ActiveIQ UM 9.8 is reporting volumes to be full in 15 days which is not correct
- ActiveIQ UM certificate SAN cannot contain multiple IP addresses
- ActiveIQ UM does not trigger the alert notification for 'Logical space nearly full' and 'Logical space full'
- ActiveIQ UM EMS subscription fails due Host resolution on UM
- ActiveIQ UM EMS subscription fails due to ONTAP DNS issues
- ActiveIQ UM restore from a snapmirror destination failure
- ActiveIQ UM: Metrocluster monitoring fails with error regarding nodeswitchlink.NodeSwitchLink
- ActiveIQ Unified Manager 9.13+ becomes unresponsive due to high CPU utilization
- ActiveIQ Unified Manager 9.7p1 on Windows Failed to Install because of JDK
- ActiveIQ Unified Manager 9.8 "um event list" command fails with ERROR : Request cannot be processed due to internal server error
- ActiveIQ Unified Manager Acquisition Service starts then stops
- ActiveIQ Unified Manager Active Directory test login fails with LDAP error code : 49/52e
- ActiveIQ Unified Manager alert Cluster Not Reachable caused by Ontap API timeout
- ActiveIQ Unified Manager alert for Flash Disks - No Spare Blocks is received
- ActiveIQ Unified Manager Alerts Resolution Guides
- ActiveIQ Unified Manager backup fails with an error that '7zz' does not exist
- ActiveIQ Unified Manager cluster 'Operation State' shows 'Failed' but there is no polling issue
- ActiveIQ Unified Manager disables SSL certificate checking for REST API's
- ActiveIQ Unified Manager does not process EMS messages from all clusters
- ActiveIQ Unified Manager doesn't display volumes with Anti Ransomware Protection
- ActiveIQ Unified Manager fails to install an externally generated certificate
- ActiveIQ Unified Manager fails to monitor cluster after the cluster certificate is updated
- ActiveIQ Unified Manager install fails due to permission errors on MySQL database files
- ActiveIQ Unified Manager install fails due to the MySQL service configuration
- ActiveIQ Unified Manager install problems after failed install on RHEL
- ActiveIQ Unified Manager is not able to add a Vcenter datasource with error PKIX path building failed
- ActiveIQ Unified Manager MySQL service cannot start, due to a missing or corrupted INI file
- ActiveIQ Unified Manager MySQL service fails to start
- ActiveIQ Unified Manager not triggering events for EMS after port 514 is blocked on network
- ActiveIQ Unified Manager OVA GUI shows initial setup screens after rebooting existing instance
- ActiveIQ Unified Manager Protection Relationships screen is missing the Source data
- ActiveIQ Unified Manager reports Alert "ntp server count is low" for cluster
- ActiveIQ Unified Manager returns no results when using the "um run cmd" CLI command
- ActiveIQ Unified Manager script failing with "Request cannot be processed due to internal server error"
- ActiveIQ Unified Manager sends Cluster Monitor Failed alerts after disabling Ontapi
- ActiveIQ Unified Manager Service failed to start due to "Invalid record type" error in server log file
- ActiveIQ Unified Manager services not starting
- ActiveIQ Unified Manager services will not start with SELinux enabled
- ActiveIQ Unified Manager SNMP MIB file does not define event severity
- ActiveIQ Unified Manager stops polling Cluster information due to less than 10 percent free space on the installation drive root partition
- ActiveIQ Unified Manager triggers outdated security events for ONTAP 9.10 and above clusters
- ActiveIQ Unified Manager upgrade fails for Linux versions if a MySQL password is set
- ActiveIQ Unified Manager Volume Performance page doesn't display any volumes
- ActiveIQ Unified Manager Web UI not opening due to running database dump
- ActiveIQ Unified Manager WebUI is unresponsive or does not show performance data
- ActiveIQ Unified Manager will not authorize adding a cluster via HTTPS or switching to HTTPS
- AD remote authentication fails with AIQUM
- AD Remote authentication takes long time logging in to AIQUM GUI
- Added storage's 'Operation Status' never becomes 'completed' and its name or status is not shown on AIQUM Cluster Setup page
- Adding a cluster to AIQUM 9.14 and later fails when SAML is enabled
- Adding a Vcenter to UM fails with incorrect username or password
- Adding cluster data source in Unified Manager fails due to insufficient permissions
- Adding cluster fails by "Failed to read the certificate due to incorrect formatting."
- Adding cluster for monitoring in Unified Manager fails with "Failed in conversion" and NullPointerException errors in the logs
- Adding cluster to AIQUM fails with The \"applications\" object is invalid error
- Adding ONTAP 9.14.1 and above Cluster to AIQUM 9.14 and above fails when SAML is enabled on cluster
- Adding ONTAP Cluster to Windows AIQUM Server fails with "Unable to add cluster datasource. This can occur if the clocks on the systems are not synchronized and..."
- Adding ONTAP Cluster with CA signed certificate on AIQUM with CLAG fails with certificate chain error
- Adding ONTAP clusters in AIQUM fails when cloud agent is enabled
- Adding or testing a user in ActiveIQ Unified Manager fails with an "Unknown authentication server error"
- After a takeover AIQUM may repeatedly report Takeover Impossible
- After Active IQ Unified Manager OVA upgrade to 9.9, the virtual machine becomes unresponsive
- After AIQUM 9.10p1 or 9.11 upgrade ONTAP or GCP CVO will not allow single file restore
- After CA signed certificate install on AIQUM, clusters cannot be polled anymore
- After changing the domain of a Windows server running AIQUM, updating the HTTPS certificate results in the "The CN of the host certificate is not valid."
- After installing Active IQ Unified Manager on Linux the maintenance user fails to authenticate
- After migrating Active IQ Unified Manager from OVA to RHEL restore fails or backups do not generate
- After migrating Unified Manager to a new machine it doesn't work properly
- After ONTAP upgrade, AIQUM reports "ONTAP Version Mismatch" even if all nodes are successfully upgraded
- After ONTAP user password change, AIQUM attempt to login at high frequency and the user is locked
- After redeploying ONTAP Select cluster, AIQUM cannot monitor the new cluster
- After restarting AIQUM for vSphere users are unable to login via the WebUI
- After restoring Active IQ Unified Manager, daily and full backups fail with error: "Access denied for user 'jboss'@'localhost'"
- After the controller replacement, although the HA status is healthy on the ONTAP side, an error is still shown under the HA details in Nodes page of AIQUM
- After updating Java on the Active IQ Unified Manager host, services will not start
- After upgrade from AIQUM 9.9 to 9.11P1, ocie service does not start
- After upgrade of AIQUM from 9.7 to 9.9, OCIE service does not start
- After upgrading Active IQ Unified Manager to version 9.8 the web interface shows the error: "Cluster discovery failed. Rediscover the cluster after resolving the issue"
- After upgrading AIQUM Windows to 9.13 or later, incremental backups are not taken
- After upgrading AIQUM, sometimes it becomes unstable or the GUI stops responding
- After upgrading from AIQUM 9.10p1 or 9.11 to 9.11p1 cluster acquisition stop working
- After upgrading to Active IQ Unified Manager 9.7P1 it fails to load with the error: "Unified Manager cannot be loaded. Try again later or contact your system administrator"
- After upgrading Unified Manager, custom alert scripts are no longer triggered
- Aggregate Overcommitted event is detected for the first time after rebooting AIQUM
- AIQ Unified Manager 'Cluster monitoring failed' and become obsolete 15min later
- AIQ Unified Manager 'Cluster monitoring failed' or 'Cluster not reachable' alert due to network lag with ONTAP cluster
- AIQ Unified Manager Active Directory remote authentication resolution guide
- AIQ Unified Manager backup creation failure due to missing 7zip
- AIQ Unified Manager backup fails with file system error
- AIQ Unified Manager cannot delete snapshots triggered by CommVault
- AIQ Unified Manager created an event destination in ONTAP, to non-routable interface on Unified Manager host
- AIQ Unified Manager event "too many snapshots" with an unexpected number of snapshots
- AIQ Unified Manager fails to add cluster and generates error 'unexpected time drift'
- AIQ Unified Manager hangs after configuring audit log transfer
- AIQ Unified Manager on a linux host does not start after a successful upgrade due to file permissions
- AIQ Unified Manager OVA can configure only 1 NTP server
- AIQ Unified Manager SMTP sends 'EHLO localhost' instead of 'EHLO fqdn'
- AIQ Unified Manager upgrade fails with error Database creation command failed for UM
- AIQ Unified Manager: acquisition fails for all clusters after upgrade
- AIQ/OnCommand Unified Manager cluster add fails due to SHA-1 certificate
- AIQCASecure workings in the ActiveIQ Unified Manager server
- AIQUM installation fails in RHEL with custom installation directory and symlinks
- AIQUM - Cluster Monitoring Failed alert - duplicate IP addresses
- AIQUM 9 14 the monitoring of node root volumes and root aggregates is not available
- AIQUM 9.10RC2 upgrade fails on starting services with Unknown Column this._isMD5PasswordHashUsed
- AIQUM 9.11 and 9.12 and 9.13 shows backup location update issue with Commvault aux copy jobs
- AIQUM 9.11P1 windows upgrade fails due to checksum error
- AIQUM 9.12 virtual appliance does not allow to download Support Bundle
- AIQUM 9.13 installation hung in MySQL server configuration
- AIQUM 9.14 and above shows wrong Snapshot and Qtree disk used size with wrong unit
- AIQUM 9.14 and above windows installation or restore from backup fails due to keystore files access failure
- AIQUM 9.14 shows backup location update issue with Commvault aux copy jobs
- AIQUM 9.14RC1 cluster discovery fails as it does not populate au.log
- AIQUM 9.14RC1 populates server.log with error on FileNotFoundException: /var/log/nmsdk
- AIQUM 9.16 and above shows multiple issues during fresh installation on RHEL 9.x due to File Access Policy and Firewall daemons
- AIQUM 9.16P2 or 9.18 update to MySQL plugin patch versions fail with Plugin 'mysql_native_password' is not loaded
- AIQUM 9.18 OCIE service crashes in restart loop due to OpenJDK C2 JIT compiler bug
- AIQUM 9.7 GUI inaccessible Error: Authentication Failed
- AIQUM 9.7 no longer showing performance data
- AIQUM 9.7 vCenter acquisition fails [Error connecting] - Could not connect to vCenter
- AIQUM 9.x cannot add ASA r2 systems to monitor
- AIQUM acquisition fails during WFA cache acquisition after upgrading to 9.18P1 and above
- AIQUM acquisition of cluster fails in db Update Operation due to ONTAP having stale vserver peer relationship entries
- AIQUM acquisition process after adding datasource does not finish because Health Poll fails
- AIQUM Acquisition service fails to start with Error 1075 on Windows
- AIQUM acquisition unit receives authentication error even though correct credential is set
- AIQUM acquisitions to all clusters failed due large MySQL tables
- AIQUM adds suffix ".0" to SNMP trap OIDs
- AIQUM Aggregate metrics returns internal error when requesting data more than 3 days
- AIQUM alert is not sent for Storage Failover events even after events are detected
- AIQUM alert notification is not delivered even after detection of related events
- AIQUM alert notification is triggered for all objects when no resources are selected
- AIQUM alerts at random times "Cluster is not reachable" for multiple clusters
- AIQUM alerts for MetroCluster IP inter site connectivity status is down when ONTAP SYStem Manager is not reachable for Metrocluster environment
- Aiqum and Commvault jobs for PMV relationships failing due to snapmirror snapshot owner name
- AIQUM and ONTAP return insufficient privileges error for aggr-check-spare-low ZAPI
- AIQUM and WFA integration fails due to update attempts issued to WFA
- AIQUM API call not working and failing with an error code 500 Internal server error
- AIQUM API calls fail to obtain data intermittently with request time out error
- AIQUM API triggers MetroCluster is not supported in ONTAP cluster audit log
- AIQUM authentication (SAML) fails post regenerating the HTTPS Certificate
- AIQUM backup fails with an error about 7zip
- AIQUM backup fails with mysql error access for jboss user denied
- AIQUM backup restore fails with access denied error for user jboss
- AIQUM becomes unreachable due to out of memory crash
- AIQUM can not collect performance data after ontap upgrade
- AIQUM cannot add a cluster with 'failed to set field "username" to "admin" Username does not meet configured requirements'
- AIQUM cannot apply PSL because "No available resources after filtering by IOPS"
- AIQUM cannot restrict cluster acquisition traffic to a single interface on systems with multiple NICs
- AIQUM cant exclude specific Resources while creating an alert
- AIQUM capacity graphs display Insufficient Historical Data due to ONTAP compatibility
- AIQUM capacity graphs with 1-year timescale show "Insufficient Historical Data"
- AIQUM causes account locked out in AD with wrong credentials while logging in
- AIQUM Change password of account used to poll ONTAP clusters
- AIQUM client certificate deletion failed in ONTAP with serial number is in use by cloud agent
- AIQUM Client certificate expiring
- AIQUM cluster acquisition fails with "trustAnchors parameter must be non-empty"
- AIQUM Cluster Acquisition Fails with Keystore was tampered Error
- AIQUM cluster acquisition is failing after being re-added
- AIQUM cluster acquisitions failing with trustanchor errors
- AIQUM Cluster Addition Fails Due to Expired Certificate or Cloud Agent Issue
- AIQUM cluster addition fails silently when hosts file contains IPv6 entries
- AIQUM Cluster addition in CLI with domain user fails with error "ERROR: The username or password you entered is incorrect"
- AIQUM cluster data acquisition fails due to java.security.KeyStoreException
- AIQUM cluster details page show false Protection Job failed status
- AIQUM cluster discovery failed with invalid XML character from API response
- AIQUM cluster discovery fails due to certificate-uuid exception
- AIQUM cluster discovery fails with Cloud Agent after ONTAP upgrade or cluster restart
- AIQUM cluster discovery halt In Progress
- AIQUM cluster discovery halt In Progress following upgrade to 9.14RC1
- AIQUM cluster discovery status shows failed with PKIX path building failed
- AIQUM cluster monitoring state shows failed
- AIQUM cluster polling failed after ca-signed certificate renewal of Cluster
- AIQUM Cluster Polling Failed due to volume-get-iter call
- AIQUM cluster rediscover failing with Certificate with CN is expired or not yet valid
- AIQUM cluster rediscovery fails no name displayed in GUI
- AIQUM Cluster Status Shows “Failed” Due to mTLS and SAML configuration
- AIQUM compatibility requirements for changing Amazon EC2 instance type
- AIQUM compatibility with Oracle Linux Virtualization Manager
- AIQUM Continues to Send MutualTLSCertificateExpired Alerts After mTLS Is Disabled
- AIQUM Custom Alert script fails with "The system cannot find the file specified"error
- AIQUM dashboard shows "Error loading cluster dropdown" due to stale vCenter datasource entries
- AIQUM data acquisition is unstable due to scale issues
- AIQUM database backup failing with error "Not enough free space to start backup"
- AIQUM database backup restore is failing due to insufficient space on disk
- AIQUM datasource acquisitions are not being reflected in the WebUI
- AIQUM DB backups not visible in GUI
- AIQUM deploy issue with MySQL "Error: Failed to download metadata for repo"
- AIQUM detects Cluster Monitoring is stuck and fails to gather all node's information
- AIQUM detects Detect Expired Certificates event
- AIQUM detects Mirror Replication Lag Warning and SNMP trap 15260 is sent
- AIQUM displays error icon on the qtree due to Qtree Space Full
- AIQUM does not accept EMS alerts with errors as unknown host
- AIQUM does not automatically disable alerts regarding AV connector
- AIQUM does not create events when cluster has Volumes with Abnormal Activity alerts
- AIQUM does not detect any events even though ONTAP detects cpeer.unavailable event
- AIQUM does not display events even though monitored ONTAP meets occurrence conditions
- AIQUM does not find any virtual machines from VMware vCenter
- AIQUM does not generate HA Interconnect down alert
- AIQUM does not show ACL in SMB Shares
- AIQUM does not show IOPS and Latency data for one node in the cluster
- AIQUM doesn't clean up the client or server-ca certificate after a cluster is removed
- AIQUM doesnt generate event despite breaching the performance threshold policy condition
- AIQUM doesnt generate vScan disconnected alerts
- AIQUM EMS messages get obsolete after +/- 30min by default
- AIQUM End of Support notification
- AIQUM event is retriggered after 6 months
- AIQUM Event Management page doesn't list "Protection Job Failed" event
- AIQUM event report files display different time zone
- AIQUM external certificate generation using EC failed
- AIQUM failed to discover cluster due to future dates due to Incorrect datetime value for ZAPI calls
- AIQUM failed to monitor metrocluster after ONTAP upgrade
- AIQUM failed to start due to mysql Data Dictionary initialization failed error
- AIQUM fails to add a wildcard certificate
- AIQUM fails to add cluster datasource due to cloud agent unable to establish connection from certificate error IP address mismatch
- AIQUM fails to add cluster due to stale vserver peer in ONTAP
- AIQUM fails to add new ONTAP cluster or discover previously added clusters due to expired AIQUM HTTPS certificate
- AIQUM fails to add ONTAP cluster due to a breach of max number of EMS notification destinations
- AIQUM fails to add ONTAP cluster due to unavailability of ONTAPI service
- AIQUM fails to Add or Monitor a cluster when AIQUM is configured to use Cluster Interconnect Network
- AIQUM Fails to add or rediscover clusters due to incorrect URI entry in cluster cert
- AIQUM fails to add the Cluster with self-signed SSL certificate expired error
- AIQUM fails to add/monitor the Cluster with "Failed to fetch the HTTPS certificate"error
- AIQUM fails to authenticate user with AD remote authentication
- AIQUM fails to collect performance data
- AIQUM fails to collect performance data due to ONTAP user does not have permissions
- AIQUM fails to collect performance information from the cluster when SAML is enabled
- AIQUM fails to download more than 100k events from GUI
- AIQUM fails to expand the data disk with an error that e2fsck needs to run
- AIQUM fails to fetch IDP metadata
- AIQUM Fails to Launch GUI with error “This page is not working”
- AIQUM fails to load Snapshot Copies with "PKIX path validation failed" error
- AIQUM fails to process EMS events when there are multiple brackets within EMS message
- AIQUM fails to receive auto subscribed EMS due to wrong certificate serial being used
- AIQUM fails to send alert emails from incorrect Email address
- AIQUM fails to start due to 'databaseJobStore.JobSerializationErrorChecker'
- AIQUM fails to start the acquisition service with error "Failed to start acquisition - Failed to load certificates" and webUI issues
- AIQUM fails with Unable to get CN from the server certificate
- AIQUM falsely reports an auto giveback is not enabled event after ONTAP is upgraded
- AIQUM File Restore Job Fails stating NDMP service on the cluster is not enabled
- AIQUM for Windows wrapper.log file is over 30GB in size
- AIQUM generates Cluster Imbalance Alerts at midnight
- AIQUM generates event at around 00:17 the day after ONTAP upgrade is performed
- AIQUM generates several obsolete alerts several hours after the actual event
- AIQUM Generating Scheduled Reports at Incorrect Time
- AIQUM GET API failed with error "Internal Server Error"
- AIQUM gets hung due to external scanners or scripts
- AIQUM gets unresponsive frequently and autosupport generation fails
- AIQUM graph shows breaks when load testing is performed by customer on specific clusters
- AIQUM GUI “Null value was assigned to a property of primitive type setter” Error while accessing the Alert setup page
- AIQUM GUI access fails with error "invalid username/password"
- AIQUM GUI calendar not displaying if the language is unsupported
- AIQUM GUI failed to load with ERROR 404 due to lucene index Corruption
- AIQUM GUI shows "404 - Not Found" error because MySQL folders have been deleted
- AIQUM hard disk size is grayed out
- AIQUM HTTPS certificate is not getting updated in ONTAP cluster
- AIQUM in windows show high memory or CPU utlization in a regular interval due to AV scanner
- AIQUM install failed with error "Failed to start MYSQL service. "
- AIQUM Install Fails on RHEL Server when SELinux and ACL are in use
- AIQUM install or upgrade on windows fails with required ports are in use
- AIQUM installation failed when FIPS is enabled in RHEL/CentOS version
- AIQUM installation on RHEL 9.4 fails to start Acquisition unit service
- AIQUM installation or upgrade completes and OCIE not starting
- AIQUM intermittently reports cluster not reachable while using AD user authentication
- AIQUM is not receiving EMS alerts from ONTAP Cluster
- AIQUM is not reporting IOPs and Latency metrics for NFS or CIFs Interfaces
- AIQUM is not showing any FC MCC switches or brigdes
- AIQUM is unable to find valid certification path when setting up Remote Authentication
- AIQUM is very slow or not working after upgrade without following the upgrade path
- AIQUM keeps sending email notifications even after configuring exclusion list of alert
- AIQUM login fails with the error 'Response doesn't have any valid assertion which would pass subject validation administrator'
- AIQUM maintenance user cannot login into web GUI
- AIQUM maintenance user is locked due to multiple login failures
- AIQUM malfunctions due to insufficient resources
- AIQUM Management Server Service will not start
- AIQUM monitoring failed due to share_name may not be null
- AIQUM monitoring fails: An internal error has occurred during MetroCluster component refresh
- AIQUM MySQL database fails to startup due to corruption after unexpected shutdown during install/upgrade
- AIQUM MySQL database restore to a new configuration fails due to space issues
- AIQUM mysql error log gets spammed with 'mysql_native_password' is deprecated
- AIQUM MySQL Service Crashes Frequently
- AIQUM NDMP file restore from snapshot fails
- AIQUM not generate events on volume latency
- AIQUM not listing some user or group quotas when setting up alert
- AIQUM not reachable after antivirus scan
- AIQUM not send volume full alert emails when threshold Is reached
- AIQUM not sending critical alerts even though all critical events are selected
- AIQUM Not Sending Performance Thresholds breach alerts for Node CPU or Volume Latency
- AIQUM occur Event: Storage Failover Node Status Down
- AIQUM ocie service not starting due to EOF exception on server truststore
- AIQUM OCIE service will not start
- AIQUM OCIE Will Not Start
- AIQUM on ESXi shows "Cluster cannot be reached."
- AIQUM ONCOMMANDSVC service stops due to a missing standalone XML file
- AIQUM OVA 9.13 or later does not have NTP service
- AIQUM OVA is not accessible with no acquisitions due to root file system getting full
- AIQUM OVA Upgrade reports failure referencing grub-pc grub2 errors
- AIQUM OVA upgrade stalls out with permission denied for server.truststore
- AIQUM OVA upgrade via diag SSH session gets stuck
- AIQUM performance graphs are not updated after ONTAP admin was temporarily deleted
- AIQUM platform events remain New even after ONTAP has been recovered
- AIQUM protection job paired with WFA fail with error unable to find valid certification path to requested target
- AIQUM provides cannot update server error when trying to rediscover cluster
- AIQUM raises "Verify That Intercluster Peering Is Up"
- AIQUM raises alert for S3 bucket with Qtree Space Soft Limit Breached
- AIQUM remote authentication cannot establish session over SSL
- AIQUM repeatedly sends notifications though corresponding event is not newly detected
- AIQUM reports blocked by third party security software service
- AIQUM reports cluster not reachable due to faulty web services
- AIQUM reports CVE-2019-18197 and CVE-2019-19956 for ONTAP 9.10 or later
- AIQUM reports error status on data aggregate
- AIQUM reports ONTAP licenses that are not expired as expired
- AIQUM reports SnapMirror destination volume size growth rate abnormal and the aggregate space nearly full with TSSE enabled on both Source and Destination
- AIQUM reports some network interface related risks like 'Controller Has Only One Cluster LIF' even if there are enough interfaces
- AIQUM reports Storage VM stopped for vservers hosting destination volumes of a snapmirror relationship
- AIQUM REST acquisition fails on NVMe clusters with Unknown Disk Port Type nvme
- AIQUM REST acquisition fails with cifs_server_name may not be null error when an SVM has CIFS servers in Workgroup auth style
- AIQUM REST API for node-metrics intermittently returns zero samples due to busy ONTAP Web services
- Aiqum restore failing while browsing the volume and getting an error "Volume is not mounted in the namespace"
- Aiqum restore job fail with error with no enough space
- AIQUM restore not allowed for a FlexVol volume created before ONTAP 9.7
- AIQUM returns to SAML login screen at logout with 401 unauthorized error
- AIQUM root filesystem getting full due to syslog and kern.log
- AIQUM root filesystem reaching 100% full
- AIQUM runs java.exe commands in the background
- AIQUM SAML authentication error: Login failed due to expired SSL certificate
- AIQUM SAML authentication fails for Windows Servers
- AIQUM Scheduled Reports/Backups Not Triggering
- AIQUM send Event : ASUP Truncation Identification And Avoidance
- AIQUM send Event : Checks If Software Licenses Match On Both Nodes Of HA Pair
- AIQUM send Event : Volume suitable for anti-ransomware monitoring
- AIQUM sending "Asynchronous Vault Lag Warning" for Deleted or Non Existing Relationships
- AIQUM sends alerts in wrong email ID
- AIQUM sends ocumEvtLifNotAtHomePort SNMP trap after LIF is reverted to home port
- AIQUM sends SNMPv1 with localhost as sender address
- AIQUM server becomes unresponsive during Qualys web scanner
- AIQUM server hung and unresponsive frequently running on virtual machines
- AIQUM server is not reachable intermittently and acquisition fails at times
- AIQUM server stops showing performance data
- AIQUM server webUI is very slow, collection graphs are missing data, no alerts when collection stops
- AIQUM service deployment fails with broken server.keystore
- AIQUM service didnt start after upgrade from 9.10P1 to 9.11
- AIQUM service does not start due to permission denied on ocum-script.log
- AIQUM services are not started after installation on Windows
- AIQUM services do not start due to corrupted server.truststore
- AIQUM services do not start due to corrupted server.truststore EOFException
- AIQUM services failed on windows after upgrade to 9.18P1 due to newer JDK deployment
- AIQUM services failed to start due to root gets full spamming with 404/500 errors in access log files
- AIQUM services may remain unavailable after Windows Server in-place upgrade
- AIQUM services not starting after reboot
- AIQUM Services not starting due to missing keyentry in server keystore
- AIQUM services on OVA and Linux platform not starting due to full root partition
- AIQUM services take long time to start due to unrecognized deployment files
- AIQUM shows "7 Mode filers are not supported." error for ONTAP 9
- AIQUM shows alert for FC Port Command Fan-in Best Practices Threshold Breached
- AIQUM shows false alert MetroCluster Ip inter site connectivity status is down due to misconfigured SAML
- AIQUM shows false alerts for MetroCluster IP inter site connectivity status is down
- AIQUM shows Monitoring is stuck for the cluster everyday same time for a DR cluster
- AIQUM shows Network Interface Status Down for all metrocluster DR SVM-MCs with REST based acquisition via Cloud Agent
- AIQUM shows Package still being processed or data source is already performing poll which leads to polling being skipped
- AIQUM shows storage VM stopped for all metrocluster DR SVM-MCs with REST based acquisition via Cloud Agent
- AIQUM shows substantially lower intercluster lif throughput than expected
- AIQUM snapshot backup fails due to filesystem error
- AIQUM Snapshot based backups are failing with Error Backup cannot be taken
- AIQUM SNMP Traps Not Received as Events in NNMi SNMP Tool Due to OID Mismatch
- AIQUM Some Failed Disks error event not cleared even after replacing a failed disk
- AIQUM stale records remain in webui even after multiple successful acquisitions
- AIQUM status shows "In Progress" and "Rediscover" option is greyed out for clusters
- AIQUM submit button gets unresponsive while adding clusters reimaged from MCC
- AIQUM Support Bundle collection does not complete and in archiving state
- AIQUM triggers "Cluster Monitoring Failed" event momentarily while editing cluster
- AIQUM triggers alert No Active Path to Access LUNs via missing SAN initiator
- AIQUM triggers false local admin enabled event after SAML is enabled in ONTAP
- AIQUM triggers No Active Paths to Access LUN alert for a LUN with NVME namespace
- AIQUM unable to add or monitor clusters with certificate fetch error
- AIQUM unable to generate subscribed ONTAP EMS events due to port 514 connectivity
- AIQUM update fails on windows platform with Aborting Installation as file is tampered due to checksum verification failure
- AIQUM upgrade failed to download ocie-serverbase, netapp-application, netapp-platform
- AIQUM upgrade failed with error "Database creation command failed for UM"
- AIQUM Upgrade fails Error 2738 Could not access VBScript run time for custom action
- AIQUM upgrade fails because 7zip is not installed
- AIQUM upgrade fails due to higher MySQL version already installed
- AIQUM upgrade fails in RHEL if MySQL password is set
- AIQUM upgrade fails to start services due to unsupported upgrade path
- AIQUM upgrade fails with “Hash Sum mismatch” while installing MySQL packages in OVA
- AIQUM upgrade fails with error about not enough space
- AIQUM upgrade fails with Failed to upgrade platform_base
- AIQUM upgrade from 9.10 to 9.12 WildFly Server would not start
- AIQUM Upgrade from 9.12 to 9.13 fails with MySQL error
- AIQUM upgrade from 9.16 to 9.18.P1 hangs during manual RPM upgrade on RHEL Dark Site
- AIQUM upgrade hangs during certificate processing due to expired intermediate CA certificate in truststore
- AIQUM upgrade in windows fail with wizard was interrupted error
- AIQUM upgrade to 9.16P2D23 fails with MySQL ERROR 4058 authentication policy mismatch
- AIQUM upgrade to 9.18 in RHEL fails with missing 7ZIP and MySQL Community repository RPMs
- AIQUM versions 9.13 and later deprecated the Max Snapshots Check Per Volume alert
- AIQUM volume performance chart sometimes shows zero for volume IOPS and latency
- AIQUM Web UI reports ERR_CONNECTION_REFUSED after service restart
- AIQUM webUI dashboard shows "Error loading cluster dropdown"
- AIQUM webUI gives error "Authentication failed. Please verify username and password."
- AIQUM windows fails to start acquisition service due to the service started and then stopped
- AIQUM windows installer gives error: Verify that the specified transform paths are valid
- AIQUM won't display datastore performance when SMBC is in use
- AIQUM Workload Analysis page fails to load
- AIQUM: Status of the service processor with address is offline but SP is online
- AIQUM9.14 and above intermittently has issues acquiring clusters due to expensive ZAPI calls
- Alert e-mail from AIQUM gets garbled as "???" in Japanese Windows OS environment
- Alert from Active IQ Unified Manager: Management Server Almost Out Of Memory
- Alert from Unified Manager: Cluster Not Reachable Resolution Guide
- Alerts generated due to incorrect alert configuration in the AIQUM
- Alerts not received for PSU failure from AIQUM
- Alerts not received for warning lag thresholds for unmanaged relationships breached
- Alerts were not received from Active IQ Unified Manager
- All CommVault AUX copies fail because of UM errors
- Although AIQUM is monitoring a cluster with almost no I/O, the latency for SVMs and volumes is shown as several seconds
- Although there should be sufficient free space, when viewing the node page in AIQUM, it appears that more space is marked as used than the size of the aggregate
- An OnCommand application service fails to start, with error: "Address already in use"
- API call to cluster through Unified Manager API gateway returns error: "User is not authorized."
- API-S End of Support notification
- Are AIQUM logs rotated?
- Are any operations restricted by enabling SAML authentication in AIQUM?
- Are any setting changes required when upgrading AIQUM from 9.16 to 9.18?
- Are multiple interfaces on the AIQUM server supported?
- Are ONTAP events captured and sent to AIQUM through AutoSupport?
- Are there any events or alerts related to virtual machines (VMs) that are available in Active IQ Unified Manager (AIQUM) when adding a vCenter server?
- Are there any tasks required on the AIQUM side after upgrading ONTAP?
- Are there limits on the number of characters for COMMON NAME and ALTERNATIVE NAMES?
- ASUP enabled still Active IQ shows unregistered on System Manager
- ASUP Truncation Identification And Avoidance events generated on AIQUM server for multiple nodes
- Attempting to log in to AIQUM GUI fails with Bad credentials error in audit.log
- AU Logs Auto-Purging in Active IQ Unified Manager (AIQUM)
- Audit Log Size Allocation is About to Get Full warning in Unified Manager
- Audit logs not generating in Active IQ Unified Manager
- Automatic alerts not triggered for NVME flash cache failure
- Automatically subscribed SVM scoped EMS not received in AIQUM for MetroCluster
- AutoSupport logs fail to send for Active IQ Unified Manager
- Autosupports sent to NetApp but not appearing in Active IQ Digital Advisor
- AUX copies fails using Commvault with 'JDBCConnectionException' error
- AUX copies fails with “Maximum Retries Exceeded” Due to Cluster Connectivity Issues
- Aux Copy fails after converting flex volume to flex group
- Auxcopies failing in CommVault due to indexing issues between CommVault and UM
- AUXCopy failed for MetroCluster volumes after planned switchover and switchback
- AUXCopy failed in MetroCluster volumes after adding DR partner nodes in Commvault
B
C
- CA signed certificate for AIQUM is missing root or server certificate
- CAIQUM-8896 Unified Manager Unable to acknowledge Events in 9.18D11
- Can Active IQ Unified Manager accept a remotely generated CSR?
- Can Active IQ Unified Manager calculate average load rate of resource?
- Can Active IQ Unified Manager forward syslog messages?
- Can Active IQ Unified Manager monitor FlexGroup and Constituent Volumes?
- Can Active IQ Unified Manager monitor ONTAP S3 buckets?
- Can Active IQ Unified Manager monitor SANtricity
- Can ActiveIQ Unified Manager "oncommandsvc-stdout" files be deleted ?
- Can AIQUM 9.7 be upgraded to AIQUM 9.12 directly?
- Can AIQUM be configured on Nutanix AHV?
- Can AIQUM configure Cloud bucket protection snapmirror lag EMS events
- Can AIQUM export latency and other workload counters into CSV format?
- Can AIQUM OVA disable SSH?
- Can AIQUM OVA enable SSH public key authentication?
- Can AIQUM server send the resolved events to the Traps host server
- Can aiqum support monitor SFP power?
- Can AIQUM system-defined performance threshold values be displayed in GUI?
- Can be custom specified volume or Qtree Capacity Thresholds in the AIQUM?
- Can copying files restore AIQUM if file corruption occurs in /opt/netapp/data?
- Can custom role with same privilege as admin in ONTAP be used AIQUM for acquisition?
- Can different IP address be used when restoring AIQUM using AMI?
- Can I create a report in Active IQ Unified Manager for the last 7 days that shows all volumes growth?
- Can I use AnyCast DNS on Active IQ Unified Manager?
- Can multiple instances of Unified Manager be combined into a single instance?
- Can ONTAP Audit Log forward to Active IQ Unified Manager
- Can Python be upgraded to 3.9.x after upgrading AIQUM to 9.16P1?
- Can security scanning tools be used with the OVA?
- Can SMTP-S be enabled in OnCommand Unified Manager 5.x?
- Can the AIQUM report the Controller temperature status or value?
- Can the MySQL component installed with Unified Manager for Windows be upgraded independently?
- Can the MYSQL instance on a unified manager virtual appliance be upgraded?
- Can the version of Windows be upgraded on a server hosting Active IQ Unified Manager?
- Can the volume comments be retrieved by Active IQ Unified Manager REST API ?
- Can Third-Party software be installed on the Active IQ Unified Manager OVA?
- Can thresholds be modified for the node root volumes in Active IQ Unified Manager
- Can TLS1.1 be disabled when using AIQUM9.10?
- Can Unified Manager generate an alert when a LUN gets low on space?
- Can Unified Manager OVA be set multiple NTP servers?
- Can we add custom resources for additional monitoring on AIQUM alert setup?
- Can we change the number of days under Performance - Zombie Volumes (inactive for 7 days) in AIQUM server
- Can we configure SIEM logs to from Active IQ Unified Manager
- Can we delete Handling copylight.txt File from ActiveIQ Unified Manager host?
- Can we get historic storage utilization from AIQUM
- Can we get historical capacity usage reports for the entire cluster from AIQUM?
- Can we use CA-signed certificates for mutual TLS certificate in AIQUM?
- Can Windows Server Backup be used to restore the Windows version of AIQUM?
- Can you add CVO cluster to AIQUM? Irrespective of cloud agent enable being true/false
- Can you configure Active IQ Unified Manager with more than one domain for remote authentication?
- Can't generate support bundle in Unified Manager
- Cannot add a new cluster to OnCommand Unified Manager due to invalid name
- Cannot Add Active Directory Group in Active IQ Unified Manager
- Cannot add cluster in AIQUM and getting an error about self-signed certificate
- Cannot add cluster to Active IQ Unified Manager after joining/unjoining nodes on the cluster
- Cannot add cluster to Active IQ Unified Manager because it failed to unregister EMS
- Cannot add cluster to AIQUM due to previous stale entry
- Cannot add clusters when there is a large version difference between ONTAP and AIQUM
- Cannot add ONTAP cluster to AIQUM due to incorrect LIF role
- Cannot browse snapshot restore in AIQUM with error Cannot store non-PrivateKeys
- Cannot create email notification because Unified Manager complains about script upload plugin disabled
- Cannot disable event in AIQUM: "unable to find FlexVol with ID"
- Cannot execute the setup login banner and enable audit log actions in the AIQUM UI
- Cannot log in to UM with "Authenticating token for ldap user not successful"
- Cannot login ActiveIQ Unified Manager using umadmin user after installing it on Linux host
- Cannot login to newly deployed AIQUM GUI but can login to its maintenance_console
- Cannot peer Workflow Automation with Unified Manager, error "cannot determine the unique ID of Unified Manager version from Workflow Automation host"
- Cannot reset jboss user password in Active IQ Unified Manager 9.11+
- Cannot view or update AIQCASecure rules manually on AIQUM
- Capacity dashboard is greyed out and does not load
- Capacity units are showing in TiB and GiB for the volume alerts in AIQUM
- Capacity Values are off in Active IQ Unified Manager
- Certificate is expired or not valid yet NotAfter: DDMMYYYY but none of AIQUM certificate expired
- Change file permissions on server.keystore or server.truststore in Windows Server
- Changes in Cluster Management IP not showing up in ActiveIQ Unified Manager
- Changes or events on an ONTAP cluster are not immediately detected by Unified Manager
- CIFs share name contains Japanese characterset display garbage code in AIQUM
- Cleaning up Java Heap Dump Files
- Cluster acquisition fails due to 'Received fatal alert: unknown_ca' on try 5 out of 5 error
- Cluster acquisition fails in AIQUM due to expired CA certificate for Mutual TLS communication
- Cluster acquisition fails in AIQUM due to Mutual TLS Communication errors
- Cluster acquisition fails in AIQUM due to parsing failure on cifs-share-get-iter
- Cluster acquisition fails on AIQUM 9.14 hosted on Azure even after disabling cloud agent
- Cluster acquisition in AIQUM fails when API Gateway is disabled
- Cluster acquisition is failing with 'Received fatal alert: unknown_ca' on try 5 out of 5 error in aiqum server
- Cluster acquisition via REST failed in AIQUM due to missing nsswitch entries in Data SVMs
- Cluster acquisition via REST fails in AIQUM with NPE on GMode Conversion
- Cluster acquisitions fail with SAML Enabled and mTLS disabled
- cluster acquistion taking longtime and intermittently polling in "failed" state
- Cluster add in AIQUM stuck with operation state "In Progress"
- Cluster addition failed in UM as invalid XML character returned during acquisition
- Cluster addition fails on AIQUM new deployment due to corrupted client.keystore
- Cluster addition fails with keystore was tampered error on RHEL AIQUM 9.16 new installation
- Cluster collections begin to fail abruptly with error, "Keystore was tampered with, or password was incorrect"
- Cluster data source polling stuck due to timeout occurred while waiting on collection completion listener in aiqum
- Cluster discoveries take nearly 1 hour and Operational State is Failed in AIQUM WebUI
- Cluster discovery failed in Active IQ Unified Manager due to invalid login credentials
- Cluster Discovery Failing with Authorization Failed
- Cluster Discovery Fails with Permission Denied after adding Cluster on RHEL AIQUM
- Cluster has status operation state failed status when added to AIQUM
- Cluster inventory collection fails in Unified Manager with NullPointerException error in the recording log_foundation_*_sample.log
- Cluster is in deletion in AIQUM but acquisition is working
- Cluster is not reachable in UM because acquisition service has run out of memory or CPU resources
- Cluster is not reporting EMS notifications in Event Management for AIQUM 9.12
- Cluster mgwd log reports 'Failed to authenticate login attempt to Vserver' coming from ActiveIQ UM
- Cluster monitored by AIQUM is upgraded to 9.14+ and begins producing false positives for "No Active Paths To Access LUN..." events
- Cluster monitoring doesn't work in OCUM after applying firewall rule in ONTAP
- Cluster monitoring fails in Active IQ Unified Manager after change to cluster management ip
- Cluster monitoring stopped in AIQUM after cluster upgrade
- Cluster names are missing in ActiveIQ UM cluster setup page
- Cluster operational state is "failed" while collections are successful for AIQUM 9.12 and above on Linux or OVA
- Cluster operational state is "failed" while collections are successful for AIQUM 9.12 on Windows
- Cluster polling fails in Active IQ Unified Manager due to incorrect password
- Cluster polling fails with configuration exception error in AIQUM
- Cluster Polling Stuck Due to Concurrency Conflict with EMS Event Processing in AIQUM
- Cluster stuck in deletion due to mTLS
- Cluster stuck in Learning Status in Active IQ Unified Manager
- Clusters addition/discovery fail in AIQUM 9.14+ with CA signed certificate and cloud agent enabled
- Clusters fail collections with duplicate entry for key errors in the logs when Cloud Agent enabled
- Clusters in Failed State in AIQUM due to OCIE Service Failure
- Collecting AIQCASecure logs in AIQUM server
- Collection stop due to ClusterSparesEventDetector error in AIQUM server
- Commvault aux copies fail for newly created volumes on AIQUM
- Commvault AUX Copy Jobs Failing Intermittently with "13001 Internal error"
- Commvault Aux copy jobs fails with "JDBC Connection" or "Missing error string" error in AIQUM
- Commvault AuxCopy failure due to error Backup location not found for all input paths
- Commvault backups are failing with error 'volume_name' is missing on node 'backup'
- Commvault IntelliSnap backup fails because Commvault jobs are scheduled too close
- CommVault protection jobs utilizing Unified Manager to create volumes fail because they cannot enable efficiency on the created volume
- Commvault Unable to Connect to Active IQ Unified Manager via IntelliSnap
- Compression Space Savings is always 0 in volume capacity history chart on AIQUM
- Configured NTP server for Active IQ Unified Manager only shows as IP
- Configured Syslog forwarding for Auditlog in AIQUM, but logs are not recorded in the Syslog server
- Configuring autosize mode from grow_shrink to off causes some AIQUM threshold exceeded events
- Configuring SAML authentication in AIQUM
- Configuring user quota email for users if user name is different than email address
- Controller Has Only One Cluster LIF event due to false positives by AIQUM
- CPU Ready for AIQUM vApp shows over than 10ms
- CSV export is empty for SnapMirror details via AIQUM
- Current capacity and trend lines are missing from the volume or aggregate capacity graphs in UM
- CV backups are failing in AIQUM with missing resource pool error
D
- Database backup restore fails with error 'Failed to restore the Database dump' when trying to restore backup
- Deduplication Space Savings and Compression Space Savings missing in volume capacity reports after upgrade
- Delayed alerts are being sent from AIQUM
- Deploying AIQUM OVA gives certificate expired warning in vCenter
- DFM fails to collect performance data with error"Can't connect to host (err=10061)"
- Difference Between AIQUM MIB Files
- Discrepancy between AIQUM GUI and REST API response for Aggregate performance
- Discrepancy in OID string for SNMP V1 versus SNMP V3 in Unified Manager
- Disk Shelf NSM100 is not discovered despite using ONTAP 9.14.1 and AIQUM 9.14 or later
- Do AIQUM display the root volume relationship in the Protection relationship tab
- Do any OnCommand products have a feature to monitor IO at the disk level?
- Do I have to add all my clusters to Active IQ Unified Manager before configuring to EMS subscriptions?
- Does Active IQ Unified Manager for Linux support Java 11 OpenJDK
- Does Active IQ Unified Manager have a configurable session timeout?
- Does Active IQ Unified Manager have the ability to lock out users for incorrect passwords?
- Does Active IQ Unified Manager provide any built-in capability to delay or suppress alerts based on time duration or threshold stability?
- Does Active IQ Unified Manager require a license?
- Does Active IQ Unified Manager require an active internet connection
- Does Active IQ Unified Manager sends latency or IOPS alerts without configuring thresholds?
- Does Active IQ Unified Manager support Hyper-V
- Does Active IQ Unified Manager support inheritance when adding resources to alerts?
- Does Active IQ Unified Manager support MariaDB instead of MySQL?
- Does Active IQ Unified Manager support STARTTLS for remote authentication?
- Does ActiveIQ Unified Manager have any security features that protect from threats?
- Does AIQUM file jmc.exe need an Oracle license?
- Does AIQUM have a feature to list the history of E-mail notifications sent by AIQUM?
- Does AIQUM have any other automatic data transmission features aside from enabling periodic AutoSupport?
- Does AIQUM install refreshed certificates on ONTAP clusters?
- Does AIQUM issue SNMP traps for events whose trap name is shown as "Not applicable"?
- Does AIQUM send a notification for obsolete status if corrective action is taken for the event after it was deleted due to the event retention period?
- Does AIQUM show workloads for FlexGroup volumes and it's constituents?
- Does AIQUM software's functionality change after EOVS?
- Does AIQUM support password complexity and prevent user from using previous password
- Does AIQUM support remote authentication over LDAP and LDAPS?
- Does AIQUM support running with Anti-Virus Software like MDE or MDAV on the same Windows system?
- Does AIQUM support Token-based authentication for API calls?
- Does AIQUM use Japanese calendar or Japanese era name?
- Does AIQUM virtual machine support stopping using "Shut down Guest OS"?
- Does any impact on ONTAP usage occur when "Set login banner for the cluster" is displayed on AIQUM but no action is taken?
- Does expired certificates installed by AIQUM impact monitoring by another AIQUM?
- Does issue caused by expired client-ca affect AIQUM if client-ca has never been used?
- Does NetApp provide a recommended list of critical alerts to enable in AIQUM
- Does newer versions of AIQUM have the Max Snapshot Check per Volume alert?
- Does OnCommand Unified Manager support memory error events?
- Does ONTAP function without addressing AIQUM risk events?
- Does ONTAP REST API security enhancement affect existing REST API communication with AIQUM after upgrading to a newer ONTAP version?
- Does registering vCenter with AIQUM affect the performance of VMs?
- Does restoring the Windows EC2 via AWS Backup and restoring MySQL make AIQUM usable?
- Does the AIQUM alert can monitor the Node down status?
- Does the AIQUM support version downgrade?
- Does Unified manager support all types of NVME in Active IQ Unified Manager?
- Does Unified Manager support configuration of multiple EMS Subscriptions using either wildcards in a message name or by severity or multiple message names in a single subscription request?
- Download or schedule excel report in AIQUM throws an ZipSecureFile setMinInflateRatio exception
- Drive LEDs on Solidfire nodes using the Dell R620 platform are dim or dark
E
- Email alerts stopped working or are only randomly received
- Email notifications not sending in AIQUM installed on Azure VM when specifying SMTP username/password and using STARTTLS option
- EMS notification for AIQUM is duplicated in ONTAP cluster
- Error 404 or page not available when accessing Active IQ Unified Manager
- Error 404 or page not available when accessing ActiveIQ Unified Manager on Windows
- Error 404 or page not available when accessing AIQUM on a vApp or RHEL
- Error 404 or page not available when accessing AIQUM on vApp or RHEL due to a timeout
- Error 404 or page not available when accessing AIQUM on Windows due to a timeout
- Error 500 wile opening events page in AIQUM
- Error Importing SSL certificate : Not an X.509 Certificate
- Error loading cluster dropdown after AIQUM Linux server upgrade
- Error loading cluster dropdown after AIQUM window server upgrade
- Error While Enabling SAML Authentication in AIQUM
- Error while Signing out of the AIQUM server using SAML authentication
- Error: "Invalid URI: Invalid port specified."
- Events and alerts appear in AIQUM hours after they have been triggered on the cluster
- Events do not show up in Active IQ Unified Manager after subscribing to EMS
- Events notifying of configuration-related risks detected by AIQUM do not disappear immediately after the problem is resolved
- Example of data being sent to NetApp when AutoSupport is enabled on AIQUM
- Excessive Active Directory TGT Requests from ONTAP Clusters Monitored by AIQUM
- Expired AIQUM client certificate deletion failed in ONTAP with serial number is in use by the rest-api EMS destination
F
- Facing high delay in Unified Manager response time
- Failed to add a cluster to ActiveIQ UM because of network issues
- Failed to add a cluster to OCUM because the datasourceID = -1
- Failed to add cluster after deploy AIQUM with hostname that not resolve to cluster management IP address
- Failed to add the cluster to OnCommand Unified Manager because the cluster is still present in table netapp_model.cluster
- Failed to add VMware vCenter server to AIQUM
- Failed to connect to the controller timeout waiting for the system to boot error when starting ocie service in aiqum server
- Failed to fetch the HTTPS certificate error due to ONTAP firewall when adding cluster to AIQUM
- Failed to install ActiveIQ UM because the windows HTTP services is started
- Failed to set networking configuration on ActiveIQ UM 9.7 because the hostname contains a dot
- Failed to start "ocie" service in AIQUM due to "Address already in use" error
- Failed to start AIQUM service during upgrade due to 'db update' tool error
- Failed to start AIQUM services after update due to database schema was not updated
- Failed to start services after upgrade because db schema was not updated
- False “Aggregate Overcommitted” Alerts in Active IQ Unified Manager
- False high Node Utilization on Unified Manager due to wrong performance counters received from ONTAP
- FAQ - Active IQ Unified Manager EMS Subscriptions
- FAQ about Python version in Active IQ Unified Manager
- FAQ: Active IQ Unified Manager Event Management
- FAQ: Installing and Updating Third-Party Components in Active IQ Unified Manager
- File path too long csv file is generated when exporting a report from Active IQ Unified Manager
- File Restore Job Fails in AIQUM
- File restore operations in Active IQ Unified Manager fail with the error 'The operation is not supported because NDMP Vserver-aware mode is disabled.
- File restore via AIQUM shows warning that some files may be lost
- Fix it button does not work in ActiveIQ Unifed Manager due to insufficient privileges
- Fix the Windows Installer Coordinator
- FlexGroup Volume Constituent Is Over 90 percent Utilized alert triggered from AIQUM
- Folder restore from AIQUM fails: cannot receive ONC/RPC data error
- For EVENT THRESHOLDS with a Duration of 15 minutes defined in AIQUM, if an event is detected as exceeding the threshold, which timing value is notified?
- Frequent Cluster Imbalance Alerts on AIQUM
- Fresh install or upgrade to UM 9.14+ on Windows fails waiting for UM services to start with "Keystore was tampered with" error
G
- Gaps in Aggregate performance view with Latency section on AIQUM 9.16 with Windows system
- Gaps in AIQUM node or SVM performance on version 9.16
- Gaps in AIQUM node performance on version 9.16 on VMWare vApp
- Generate CSR doesn't work in AIQUM
- Generating a new certificate in AIQUM cause 'ocie' service failed to start and 404 error
- Getting data from AIQUM through REST API fails caused by service down
- Getting error "The term 'um' is not recognized" when selecting various options in the Unified Manager for Windows maintenance console
- Getting error "You are not allowed to perform this action as 'maintuser' is an internal user" while trying to update the email address for maint user
- Getting error while start the Netapp OCIE Acquisition Unit Services on local Computer. "ERROR 1068:The dependency services or group failed to start"
H
- HA state shows "Error" on AIQUM GUI but HA state is fine on ONTAP side
- High CPU usage on Windows AIQUM using AV and vulnerability scanners
- High CPU usage spikes in Windows AIQUM through use of vulnerability scanners
- High CPU Utilization in Unified Manager Due to Large Event Retention
- HIGH CPU utilization on AIQUM due to security scanners
- High node latency from Active IQ Unified Manager but no high CPU or disk
- How are audit logs sent in AIQUM
- How are the values for volume thresholds are being calculated in AIQUM?
- How can DNS connectivity be checked on AIQUM OVA?
- How can i check AIQUM web access log
- How can I stop Active IQ Unified Manager from receiving EMS events?
- How can I update 7-Zip without updating Active IQ Unified Manager
- How can NetApp customers and partners refer to uploaded Active IQ Unified Manager AutoSupport?
- How can NTP and DNS settings be changed from the GUI in vApp AIQUM?
- How can the passwords in ActiveIQ Unified Manager be encrypted?
- How can you export/monitor performance statistics in Unified manager?
- How do Active IQ Unified Manager incremental backups work?
- How do automatically subscribed EMS events obsolete themselves in Active IQ UM?
- How do Full Backup and Incremental Backup Schedules work in Active IQ Unified Manager 9.7 and later?
- How do I adjust data retention in Active IQ Unified Manager?
- How do you change the name of an ONTAP cluster in AIQUM?
- How does Active IQ Unified Manager detect ransomware on ONTAP and trigger event "Ransomware activities detected"?
- How does AIQUM calculate the IOPS/TB metric displayed in the dashboard?
- How does an expired ONTAP user password affect AIQUM cluster polling?
- How does performance data gathering in Active IQ Unified Manager handle failures?
- How is /var/log/mysql/error.log of AIQUM rotated on Linux host?
- How is /var/log/ocie/access_log.log of AIQUM rotated?
- How is /var/log/ocie/server.log of AIQUM rotated?
- How is /var/log/ocum/audit.log of AIQUM rotated?
- How is it determined which AIQUM host registered server-ca certificate on cluster?
- How many days before will UM trigger an event,when the certificate is going to expire
- How many syslog servers can be assigned for AIQUM remote audit logging?
- How to access Active IQ Unified Manager Virtual Machine (OVA) DIAG shell
- How to access Quota email rule examples in Active IQ Unified Manager
- How to access the Mysql error log and config file for Active IQ Unified Manager
- How to add a Soft Limit to a volume
- How to address the "Storage VM XXXX Service Down" event in Active IQ Unified Manager
- How to calculate Used data capacity value in MySQL
- How to calculate volume thresholds size in Active IQ Unified Manager
- How to capture outbound SNMP communication from AIQUM server to a destination
- How to capture SAML trace from Chrome
- How to change language for Unified Manager graphical user interface and documentation on browser
- How to change the Active IQ virtual appliance host name
- How to change the IP address of Active IQ Unified Manager in Windows?
- How to change the name of the maintenance user in AIQUM OVA
- How to check allocated memory for an AIQUM hosted server
- How to check connectivity to SNMP destinations in Active IQ Unified Manager
- How to check MySQL database health on AIQUM
- How to check node connectivity to cluster switches
- How to check NTP status of Unified Manager OVA
- How to check OS or Debian version on Unified Manager Virtual Machine
- How to check the available ciphers on Unified Manager
- How to check the CPU and Memory Reservations for AIQUM hosted on a VMware virtual machine
- How to check whether acquisition in AIQUM uses ONTAPI or REST API from support bundle
- How to check which user deleted the cluster on AIQUM server
- How to clean up ONTAP event notification settings for automatically subscribed events configured by AIQUM
- How to cleanly uninstall Active IQ Unified Manager from Windows
- How to cleanly uninstall ActiveIQ Unified Manager from RHEL/CentOS
- How to clear a resource in alert setup for AIQUM in Swagger API
- How to clear the filters in Event Management in Active IQ Unified Manager
- How to collect a packet trace from Active IQ Unified Manager using tcpdump
- How to collect an Active IQ Unified Manager backup
- How to collect logs ( support bundle ) from Active IQ Unified Manager
- How to collect logs (support bundle) from Active IQ Unified Manager on a Red Hat or CentOS
- How to collect logs (support bundle) from Active IQ Unified Manager on a VMware vApp/OVA
- How to collect logs (support bundle) from Active IQ Unified Manager on Microsoft Windows
- How to collect Node Utilization reports from AIQUM
- How to configure Active IQ Unified Manager SMTP E-Mail notification settings with Microsoft Office 365 Exchange
- How to configure ActiveIQ Unified Manager with non default OpenLDAP settings
- How to configure AD users or groups with AIQUM
- How to configure AIQUM alerting for SnapMirror transfer failure?
- How to configure AIQUM alerting for snapshot creation failure?
- How to configure AIQUM to receive anti-ransomware alerts
- How to configure alerts related to Autogrow events and configuration
- How to configure and receive alerts from ONTAP EMS Event Subscription in Active IQ Unified Manager
- How to configure data retention if prompt to configure performance data retention does not appear when upgrading UM
- How to configure lag thresholds in AIQUM for unmanaged protection relationships?
- How to consolidate Active IQ Unified Manager from UM 9.7P1 version and later
- How to create a CA signed certificate in AIQUM using OpenSSL with EC/RSA algorithm?
- How to create a certificate via cli on AIQ Unified Manager
- How to create and associate user-defined Performance Threshold Policies for SVMs, and corresponding events and alerts in Active IQ Unified Manager
- How to create custom REST calls for Active IQ Unified Manager
- How to create custom volume latency alerts in Active IQ Unified Manager
- How to Create read-only privileges user for UM in ONTAP 9
- How to delete AIQUM mysql database backup
- How to deploy new AIQUM to manage cluster that is already registered to another AIQUM
- How to determine if AIQUM files failed deployment on vApp/OVA and RHEL
- How to determine if AIQUM files failed deployment on Windows
- How to disable Active IQ Platform Events on Active IQ Unified Manager 9.7+
- How to disable events within Active IQ Unified Manager
- How to disable http in AIQUM
- How to disable performance data collection on AIQUM
- How to disable Qtree quota notification emails in Active IQ Unified Manager
- How to disable SAML authentication in AIQUM
- How to disable the general log file of MySQL on Windows
- How to disable TLS cipher suites for web services in Active IQ Unified Manager 9.11 and newer
- How to disable TLS versions in Active IQ Unified Manager 9.9 and older
- How to disconnect a workload from the PSLs from AIQUM/NSLM?
- How to enable debug logging for troubleshooting issues in Active IQ Unified Manager 9.7
- How to enable debug logging for troubleshooting issues in Active IQ Unified Manager 9.8 or later
- How to enable or disable time sync for a VMware virtual machine
- How to exclude MySQL or other packages in Linux during the ActiveIQ Unified Manager installation
- How to export alert configuration from Active IQ Unified Manager using REST API
- How to filter based on event name Active IQ Unified Manager
- How to find legacy OnCommand downloads
- How to find multiple versions of Java installed on Active IQ Unified Manager for RHEL
- How to find MySQL version in AIQUM Virtual appliance
- How to find the memory allocations for MySQL in Active IQ Unified Manager
- How to fix an incorrect order of certificates for a CA signed certificate for AIQUM
- How to generate and convert a signed certificate for Active IQ Unified Manager
- How to Generate Performance reports using Active IQ Unified Manager
- How to get event thresholds from AIQUM via API
- How to get NetApp Keystone Support
- How to identify all the custom volume space nearly full and volume space full thresholds configured in Active IQ Unified Manager
- How to identify and apply the correct resources amount for a Unified Manager instance
- How to identify ONTAP EMS events for subscription in Active IQ Unified Manager
- How to identify Performance Threshold Policy applied to objects on AIQUM
- How to increase performance data samples in Active IQ Unified Manager
- How to increase space to the data disk in an Active IQ Unified Manager OVA
- How to insert a maintenance user into AIQUM database
- How to Install or Remove Netcat on Active IQ Unified Manager (AIQUM) 9.18 OVA
- How to install or upgrade AIQUM in RHEL Dark Site Servers
- How to install tcpdump on Active IQ Unified Manager 9.7 and above OVA
- How to investigate the cause of Active IQ Suggestions
- How to manage AIQUM snmp trap alerts state
- How to manage alerts for Active IQ Unified Manager
- How to manually access logs on the Active IQ Unified Manager virtual appliance
- How to manually upgrade Java Runtime Environment in Active IQ Unified Manager
- How to migrate a backup from a Unified Manager Virtual Machine (OVA) instance
- How to migrate a CommVault IntelliSnap SnapVault destination volume to new storage
- How to migrate a Linux or OVA backup onto a Virtual Machine for restore in Active IQ Unified Manager 9.8 or older
- How to migrate a Unified manager backup file from Red Hat or CentOS host
- How to migrate a Unified Manager backup from a Windows host
- How to migrate and restore a MYSQL backup file onto a Unified Manager 9.9 (or newer) Virtual Machine Server
- How to monitor volume latency and IOPS from Active IQ Unified Manager
- How to move the ActiveIQ Unified Manager files to a new disk in RHEL or CentOS
- How to NDMP backup and restore using Unified Manager and Workflow Automation
- How to open Technical Support case for AIQUM
- How to perform an NDMP restore with Unified Manager and WFA
- How to perform NDMP backup using Unified Manager and WFA
- How to perform volume backups and restores using Active IQ Unified Manager and Workflow Automation
- How to prevent AIQUM alerts about "Volume Space Nearly Full"
- How to prevent Unified Manager from reporting "Port Status Down" event for unconnected/unused network ports
- How to properly restart Active IQ Unified Manager services
- How to properly restart Active IQ Unified Manager services running on a VMware OVA
- How to properly restart Active IQ Unified Manager services running on Microsoft Windows
- How to properly restart Active IQ Unified Manager services running on Red Hat or CentOS
- How to properly stop/start Unified Manager services on Linux or OVA
- How to receive alerts on Active IQ Unified Manager management server disk space events
- How to receive alerts on Active IQ Unified Manager management server memory events
- How to recover a MySQL database when no backup is available
- How to remove registry entries from AIQUM for Windows
- How to renew a client-ca certificate for Active IQ Unified Manager
- How to renew the aiqum server certificate if you have SAML enabled
- How to reserve resources for Unified Manager in vSphere ?
- How to reset the maintenance user password for Active IQ Unified Manager on RHEL or CentOS
- How to reset the maintenance user password for Active IQ Unified Manager on Windows
- How to reset the maintenance user password for an Active IQ Unified Manager vApp
- How to reset the maintenance user password in Active IQ Unified Manager
- How to reset the MySQL root password on Unified Manager when traditional skip-grant-tables fails
- How to resolve Connection refused message when querying time servers in ActiveIQ Unified Manager
- How to resolve disk space issues with Active IQ Unified Manager
- How to resolve memory issues with Active IQ Unified Manager
- How to restore vApp AIQUM from database backup
- How to review and cleanup support bundles for Active IQ Unified Manager
- How to review and cleanup Unified Manager backups
- How to review used space in the root and data partitions for Linux or OVA deployments of AIQUM
- How to run ONTAP API from Windows host for troubleshooting purpose
- How to set a user quota rule to send to a different domain
- How to set alerts for inode utilization in Unified Manager
- How to set system date and time manually in Active IQ Unified Manager virtual appliance
- How to setup Active Directory remote authentication with Active IQ Unified Manager
- How to setup AIQUM Services to Manual Before Windows Patching
- How to setup alerting in Active IQ Unified Manager when Mutual TLS certificates are about to expire
- How to shutdown Unified Manager virtual machine
- How to specify multiple NTP servers in vApp AIQUM 9.13 or later
- How to split an Active IQ Unified Manager instance for horizontal scaling
- How to start a new MySQL error.log in ActiveIQ Unified Manager 9.x
- How to stop alerts related to Obsolete/Resolved events in Unified Manager
- How to stop only ocieau service in Active IQ Unified Manager 9.6+
- How to take JVM full thread dump of ocie on Active IQ Unified Manager virtual appliance
- How to take JVM thread dump of acquisition unit on Active IQ Unified Manager virtual appliance
- How to test EMS subscriptions in AIQUM
- How to test parameters sent to PowerShell from alerts while using Active IQ Unified Manager?
- How to test sending SNMP Traps from ActiveIQ Unified Manager to a Trap Host
- How to test SNMP communication from AIQUM to 3rd SNMP party destination
- How to troubleshoot adding a cluster in Active IQ Unified Manager
- How to troubleshoot Commvault integration with Active IQ Unified Manager
- How to troubleshoot NTP on ActiveIQ UM OVA
- How to troubleshoot UM read-only privileges user in ONTAP
- How to troubleshoot when Active IQ Unified Manager fails to alert 'X' condition
- How to update 7-zip for Active IQ Unified Manager 9.18 on Red Hat Enterprise Linux
- How to update AIQCASecure rules manually in Active IQ Unified Manager
- How to update AIQCASecure rules manually in Active IQ Unified Manager on a RHEL/CentOS/OVA host
- How to update AIQCASecure rules manually in Active IQ Unified Manager on a Windows host
- How to update DNS servers in Active IQ Unified Manager?
- How to update Rate Limit in vApp of Active IQ Unified Manager
- How to update the MySQL version used in AIQUM for Windows
- How to update the MySQL version used in AIQUM for Linux
- How to upgrade Active IQ Unified Manager (AIQUM)
- How to upgrade Active IQ Unified Manager required third-party components for Linux Systems
- How to upgrade Open VM Tools for Active IQ Unified Manager
- How to upgrade Open VMware Tools in Active IQ Unified Manager
- How to use a local user instead of a domain user for adding and monitoring clusters in AIQUM 9.12 and above?
- How to use ActiveIQ Unified Manager SnapShot backups to migrate hosts
- How to use CA signed certificate for DFM server listening on 8488 port, when we already have the CA signed certificate for 8443 port
- How to verify alert notification configuration for ActiveIQ Unified Manager
- How to verify network connectivity between ONTAP and UM for Linux/OVA platforms?
- How to verify network connectivity between ONTAP and UM for Windows platform?
- How to view the top volumes using disk IOPS in Active IQ Unified Manager
- How we can cleanup ONTAP from any references of AIQUM
- HTTP 500 error reported while using Unified Manager GUI
- HTTPS Certificate Regeneration Fails with “sudo: command not found” in UM
I
- Ibd files are missing due to Anti Virus
- If AIQUM is upgraded together with ONTAP, and AIQUM is restored from a VM snapshot taken before the upgrade, will monitoring continue as normal?
- If no vCenter is registered in AIQUM, does AIQUM verify the vCenter's certificate?
- If the AIQUM HTTPS certificate is accidentally updated with invalid content, what impact will occur?
- Impact of "Microsoft Security Advisory ADV190023" for Remote Authentication using LDAP
- In Active IQ Unified Manager (AIQUM), Does used data capacity include snapshots?
- In Active IQ Unified Manager, MySQL doesn't start due to missing iblogfile
- Inconsistencies in performance graph trends for volumes, nodes, and aggregates in Active IQ Unified Manager
- Incorrectly Receiving Cluster Cloud Tier Planning Event
- Initial cluster discovery fails in AIQUM due to permission issue in mTLS keystore file
- Install/Upgrade of AIQUM 9.14+ fails due to failure in decrypting JBoss password
- Installation Guide for Unified Manager shows incorrect Windows OS requirements
- Installation of Active IQ Unified Manager for Linux 9.12 fails post-install scriptlet step but shows installation successful. Accessing UI returns 404 not found
- Installation of Active IQ Unified Manager on Windows fails
- Installation of ActiveIQ Unified Manager on RHEL or CentOS fails
- Installation of ActiveIQ Unified Manager on Windows fails due to user permission issues
- Installation of AIQUM not completed when running it with non root
- Installation of Unified Manager for Windows fails "Installation detected that some/all third party packages are not installed"
- Installation of Unified Manager for Windows fails due to installer not detecting 7-Zip third-party package
- Installation of Unified Manager for Windows fails due to installer not detecting Java third-party package
- Installation of Unified Manager for Windows fails due to installer not detecting MySQL third-party package
- Installation of Unified Manager for Windows fails with error: "Installation detected that some/all third party packages are not installed"
- Installation or Upgrade of ActiveIQ Unified Manager on Windows fails due to a Database setup error
- Installing security software, like Fireeye or CrowdStrike, into vApp AIQUM is supported?
- Insufficient cluster user privileges cause Unified Manager alert Cluster Not Reachable
- Insufficient historical data for aggregate capacity used in AIQUM after failover of aggregates in Metrocluster
- Intellisnap SnapMirror relationships fail to initialize
- Intermittent Cluster Monitoring Failed Events on AIQUM
- Intermittently AIQUM stops sending alerts generated
- Intermittently snapshot creation in primary volume is not happening through AIQUM
- Invalid IDP Metadata error when trying to setup SAML Authentication in AIQUM
- IOPS and Latency data from VMs are missing in Unified Manager due to duplicate uuids or duplicate SCSI-IDs
- IOPS and Latency data from VMware vCenter not available on ActiveIQ Unified Manager due to identical ip addresses
- IPv6 IP address is shown for AIQUM vApp even if on IPv4 IP address is specified
- Is Active IQ Unified Manager affected by January 2026 MySQL Server Vulnerabilities
- Is Active IQ Unified Manager compatible with newer ONTAP versions?
- Is Active IQ Unified Manager required to receive EMS events from a cluster?
- Is AIQUM 9.16P2 compatible with Commvault version 11.36
- Is an Unified Manager HTTPS certificate required to be installed on ONTAP?
- Is cmaXform.exe part of AIQUM installation and can it be deleted as per security report found to be malicious
- Is it mandatory to specify IP address configured on e0M for adding cluster to AIQUM?
- Is it necessary to address the AIQUM server's memory usage if it is about 80 percent?
- Is it necessary to allow connectivity between AIQUM and ONTAP not only through the Cluster Management LIF, but also through the Node Management LIFs?
- Is it normal for the lsof output to show many files held open by mysql and java processes with (deleted) indicator in the output?
- Is it normal that vulnerability scans are showing the use of netexe on AIQUM
- Is it OK to update MySQL used by AIQUM to something other than 8.0.X?
- Is it possible to change the interval of configuration poll activity in AIQUM?
- Is it possible to check ONTAP patches or major version in AIQUM same as AIQDA?
- Is it possible to check the historical data of network throughput from the management tool?
- Is it possible to collect capacity trends for the past year for all volumes at once?
- Is it possible to configure a user for ActiveIQ Unified Manager for Cluster Mode without using the Admin role?
- Is it possible to configure SNMP within AIQUM?
- Is it possible to create a new user with the maintenance permissions like in ONTAP ?
- Is it possible to create non-mixed-mode initiator groups in ONTAP System Manager?
- Is it possible to customize the email subject line from ActiveIQ Unified Manager alerts?
- Is it possible to customize user quota emails in Active IQ Unified Manager
- Is it possible to decrease less than 5 minutes performance polling interval in AIQUM?
- Is it possible to determine which user tampered with the audit log in AIQUM?
- Is it possible to disable events in AIQUM or System Manager for a specific offline volume?
- Is it possible to disable some of the ARS rules in AIQUM?
- Is it possible to download the reports in AIQUM server locally using schedules?
- Is it possible to execute a script when a specific event occurs?
- Is it possible to export a summary or csv file of the Alerts sent from AIQUM to it's configured SMTP server?
- Is it possible to get historical space utilization growth for snapshots using Active IQ Unified Manager?
- Is it possible to have "+" sign in the username or password for AIQUM
- Is it possible to have two or more clusters with the same name in AIQUM?
- Is it possible to import/export a list include all health thresholds of volume or aggregate from AIQUM?
- Is it possible to manage Amazon FSx for NetApp ONTAP in Active IQ Unified Manager?
- Is it possible to migrate Active IQ Unified Manager from VMware to Proxmox
- Is it possible to migrate Unified Manager alert configuration?
- Is it possible to modify the formatting of the email from AIQUM alerts?
- Is it possible to monitor the capacity of MDV volumes with Active IQ Unified Manager ?
- Is it possible to move a SnapLock volume to a non-SnapLock aggregate using AIQUM?
- Is it possible to pull old dated reports from AIQUM?
- Is it possible to register the same cluster with multiple Unified Manager?
- Is it possible to send AIQUM audit logs with port 514 and without Server certificate?
- Is it possible to set zero as threshold of Snapshot Copies in AIQUM to disable event?
- Is it possible to specify multiple SNMP trap hosts in Active IQ Unified Manager?
- Is it possible to trigger an email alert when a user run set diag in cluster cli?
- Is it possible to use mTLS communication between AIQUM and ONTAP?
- Is it possible to view performance graph that collected based on sysstat in AIQUM?
- Is it possible to view the historical space utilization growth and trends for all volumes on a single page using Active IQ Unified Manager?
- Is it possible WFA and AIQUM limitation on export_policy.clientmatch varchar255 to be changed?
- Is it supported to customize JVM options of AIQUM Java processes in normal operation?
- Is it supported to run AIQUM restored from backup concurrently with the original?
- Is it supported to run AIQUM VM and its clone concurrently?
- Is it supported to use Restart-VMGuest VMware PowerCLI to restart AIQUM VM?
- Is manual action required to clear "Max CIFS Connection Exceeded" event in AIQUM?
- Is MetroCluster-IP monitoring supported in Active IQ Unified Manager?
- Is Mysql 8.0.33 and above compatible with AIQUM 9.13P1
- Is server certificate of data SVM used to communicate between AIQUM and cluster?
- Is there a way to check connectivity by CLI in exactly the same way AIQUM performs?
- Is there a way to know the severity of each AIQUM event form MIB?
- Is there a way to run AIQUM without monitoring registered clusters?
- Is there an AIQUM event related to the error of volume efficiency operation?
- Is there an equivalent to volume latency in Unified Manager by using ONTAP CLI or SNMP?
- Is there an option to change the volume size display from TiB GiB to TB GB in AIQUM
- Is there an option to collect Inode utilization report in AIQUM?
- Is there any feasibility to change the location of netappfoundation logs ?
- Is there any impact on AIQUM when renewing vCenter Server certificate?
- Is there any impact when expired certificates of type client with old AIQUM ID
- Is there problem if available memory of AIQUM Linux host is gradually decreasing?
- Is VMware Remote Console mandatory for using vApp AIQUM?
- Issue in SNMP alert monitoring on AIQUM due to difference in OID value received from aiqum MiB
- It is possible to change the default installation path for the Linux version of AIQUM?
J
K
L
- Large oncommandsvc-stdout files are consuming drive space on Windows AIQUM server
- LDAP user lookup fails due to a timeout in ActiveIQ Unified Manager
- Legacy Linux Kernel Image Vulnerability Alerts in AIQUM OVA
- Limitation of User-Defined Performance Threshold Counters
- List of CIFS shares is not displayed in the AIQ Unified Manager because of the duplicated cifs server name
- Local user accounts are not able to be edited or deleted in Active IQ Unified Manager
- Local user create fails with "user already exists with the name" in AIQUM GUI
- Local Users in AIQ Unified Manager containing a dot or special characters cannot be deleted or edited
- Log in to Unified Manager maintenance console fails due to another active session
- Login Attempt :: Error: Authentication failed. is repeated by AIQUM access
- Login to Active IQ UM web UI with the maitenance user because of issues with the underlaying PAM
- Login to Active IQ Unified Manager using remote authentication fails even though the remote authentication test passed
- Logs are not generated at the path specified in the script even though the script is set for alerts in AIQUM
- Logs related to SAML authentication in AIQUM
- LUN get iter API fails on Active IQ Unified Manager
M
- Mail delivery fails in AIQUM when StartTLS is enabled
- Maintenance console menu not populated after AIQUM upgrade to 9.14
- MCC IP False alerts - MetroCluster IP inter site connectivity status is down
- MetroCluster information is not displaying correctly in AIQUM
- mgmtgwd.certificate.expired or mgmtgwd.certificate.expiring for AIQUM client certificate
- Missing Acquisition Recordings in Support Bundle Generated by AIQUM
- Missing menu options in ONTAP System Manager navigation bar
- Missing port down alerts in Active IQ Unified Manager
- Missing views in the Active IQ Unified Manager menus
- Multiple "Dynamic Event Warning Threshold Breached" performance events reported for different volumes
- Multiple Aggregate Overcommitted events generated in AIQUM despite total size of volumes being under defined threshold
- Multiple Aiqum errors when integrated with Commvault application get fixed in Aiqum 9.16P2
- Multiple netapp-um files prevent AIQUM upgrade
- MySQL fails to start when Active IQ Unified Manager is reverted from a newer version to an older version
- MySQL memory consumption increases until server runs out of memory on ActiveIQ Unified Manager for Windows
- MYSQL service fails to start due to missing "File './unified-manager.xxxx" OS error
- MySQL services failed to start in AIQUM RHEL after restore from RHEL ReaR backup
N
- NameID element must be present when accessing AIQUM
- NDMP restores via AIQUM GUI fails intermittently with Error: Null
- NetApp Active IQ Management Server Service stopped immediately after manually restart the service on Windows system
- NetApp Active IQ Management Server Service unable to start on Windows platform due to caching_sha2_password plugin in Jboss user
- Network Interface not at home port event not generated for Management and Intercluster Interfaces
- New alerts not generating in UM although cluster acquisition works fine
- Newly added cluster discovery state shows failed
- Newly created client certificate in Unified Manager does not propagate to ONTAP clusters
- Newly created qtrees are not shown in AIQUM
- No alerts are sent by ActiveIQ Unified Manager because of resource limitation
- No alerts from Active IQ Unified Manager for aggregate usage threshold breaches
- No data seen for All Relationships in Active IQ Unified Manager UI
- No NTP service available on Active IQ Unified Manager 9.13P1 and newer on the OVA
- No performance data after the upgrade of Active IQ Unfied Manager to 9.8RC1
- No performance data in Active IQ Unified Manager monitoring with custom role
- No performance data seen in Active IQ Unified Manager
- No subject alternative names matching IP address when adding authentication server to AIQUM
- No VMware VMs are discovered by AIQUM due to empty virtual disk list
- Node Disk Fragmentation alerts on AFF systems monitored by AIQUM 9.9RC1
- Node low “Available IOPS” Displayed in AIQUM for some clusters
- Node utilization graph and node utilization event mismatch in AIQUM server
- Node Utilization performance metrics in Active IQ Unified Manager reflect inaccurate data
- Not receiving scheduled reports from AIQUM
- Notifications for ARP events not generated in AIQUM
- NSLM End of Support notification
- NVMe disk shelves are not displayed in AIQUM 9.12 for an MCC IP setup
O
- OC Unified Manager 5.x (DFM): HTTP XML Authentication failed due to invalid credentials
- OCIE and OCIEAU services fail to start after disabling syslog on the AIQUM server
- OCIE service does not start after AIQUM from 9.6 to 9.8
- OCIE service does not start after upgrading AIQUM OVA from 9.11 to 9.12
- OCIE service is showing as failed in Keystone collector
- OCIEAU service not starting on AIQUM due to missing recording directory
- October 2022 MySQL Server Vulnerabilities detected in Active IQ Unified Manager virtual appliance (OVA)
- OCUM : Cannot modify the schedule of reports
- OCUM : LDAPs authentication fails due to sha-1 certificate
- OCUM 9.5 installation fails due to "Failed to start MySQL service Setup will terminate now!!!"
- OCUM End of Support notification
- OCUM fails to monitor the cluster when one of the nodes is in uneligible state
- OCUM unable to communicate with authentication server when setting up an LDAP connection
- OCUM: Unified Manager does not show volume and aggregate trend graphs
- Old client-ca of AIQUM remains after applying workaround for Mutual TLS issue
- On midnight after upgrading ONTAP obsolete notifications are sent in UM
- On SMI-S Provider 5.2.6 and VMM 2019 the capacity is not updating
- OnCommand Insight/ Unified Manager doesn't show performance data for VMware vCenter/ ESXi
- OnCommand Unified Manager / SnapProtect / Commvault: Cleanup Procedure after subscribed volume is missing on node error
- OnCommand Unified Manager 5.X Unable to connect to server via webUI
- OnCommand Unified Manager 5.x users are unable to login through the OnCommand Console UI after a backup restore
- OnCommand Unified Manager alert notifications reflect server names as localhost in URL links
- OnCommand Unified Manager Core SnapVault backups failing due to insufficent space
- OnCommand Unified Manager does not update performance graphs because ONTAP root volume ran out of space
- OnCommand Unified Manager fails to import report
- OnCommand Unified Manager reports a Multipath HA issue while controllers in the cluster reports no issue
- OnCommand Unified Manager shows "no data to display" for performance of cluster
- OnCommand Unified Manager upgrade is successful but services could not started
- OnCommand Unified Manager WebUI is not shown
- OnCommand Unified Manager's web interface becomes slow/unresponsive
- Only 3 cloud agent instances can exist at the same time in Ontap
- ONTAP 9.16.1 cluster addition fails in AIQUM Windows 9.16 using Cloud Agent with Runtime exception
- ONTAP cluster acquisition in AIQUM via REST fails with snapmirror policy name cant be empty
- ONTAP cluster remove or delete failed from AIQUM
- ONTAP EMS Event Subscriptions fail with error: java.lang.NullPointerException
- ONTAP EMS events are not being received by the ActiveIQ Unified Manager
- Ontap ems severity to Active IQ Unified Manager event severity mapping
- ONTAP error received that AIQUM certificate has expired
- ONTAP issues warning about UM self-signed certificate expiry
- ONTAP reports mgmtgwd.certificate.expiring or mgmtgwd.certificate.expired for Active IQ Unified Manager client-ca certificate
- Operation state "Failed" with status Green in AIQUM GUI due to excessive stale lun map entries
- Operation state is completed in AIQUM GUI but no performance is showing on graphs
- Operation state showing failed after initial addition of cluster to AIQUM via REST
- Operator role is not honored in AIQUM 9.11P1
- Option 10 in Active IQ Unified Manager maintenance console gives "access denied" despite using correct password
- OVA upgrade ISO is not correctly mounted for UM upgrade
P
- Pages do not load completely when browsing Active IQ Unified Manager 9.x web interface using Safari web browser
- Partial functionality with Active IQ Unified Manager monitoring on a specific cluster
- Path to download jemalloc RPM file manually
- Perf data acquisition fail in AIQUM 9.14 and below for ONTAP 9.16 due to CMAXForm version mismatch
- Performance archive collection fails in OCUM/AIQUM, because node root volume is not properly mounted on VLDB and WAFL
- Performance archive collection fails in OCUM/AIQUM, because the root volume of one node is mounted on another node
- Performance collection fails in Active IQ Unified Manager due to 'Illegal character(s) in message header'
- Performance data shows '0' incorrectly after AIQUM upgrade
- Performance graphs missing for Flexgroup volume on AIQUM server
- Performance graphs not available for cluster in AIQUM server
- Performance graphs not showing up in Active IQ Unified Manager
- Periodic Cluster Load Imbalance Threshold Breached alerts
- Plaintext cluster data transmitted through HTTP in AIQUM
- Port utilization reporting as N/A in AIQUM
- Precheck for installation of AIQUM on windows server
- Prerequisites for enabling SAML authentication in AIQUM
- Previous version backups are not showing in GUI after the AIQUM upgrade
Q
- QoS Volume MAX MBPS Warning Threshold Breached alert triggered by AIQUM
- QoS Volume Peak IOPS/TB Warning Threshold Breached IOPS is incorrect
- Qtree Space Nearly Full and other alerts in AIQUM spamming while qtree list missing from selected resource of alert configuration after giveback of ONTAP node
- Quota email rules are not working in AIQ UM, when unix and windows users are mapped together
- Quota email rules fail to alert when Quota user information is missing or unknown in AIQUM
- Quota notification email are not being delivered to individual users from AIQUM
R
- Re-install AIQUM failed with warning: %post(mmm-analysis-1.1.20-0.el7.x86_64) scriptlet failed, exit status 255
- Re-installing AIQUM fails with error "Failed to start MySQL Service"
- Receiving AIQUM SNMP traps from wrong IP address 127.0.0.1
- Regarding AIQUM Performance Capacity, what are the total values (Available IOPS IOPS) for each model?
- Regarding the Beyond Extreme Performance Service Level created by AIQUM, does deletion have any impact?
- Regenerated AIQUM HTTPS (server-ca) Certificate was not updated in ONTAP
- Regenerated AIQUM HTTPS certificate is not reflected on cluster side
- Regenerated HTTPS certificate with new hostname not shown up on clusters added to AIQUM
- Regenerating AIQUM HTTPS certificate fails because of ALTERNATIVE NAMES entry
- Regenerating AIQUM HTTPS certificate fails with "The Common Name (CN) in the host certificate cannot be set to 'localhost'"
- Remote Authentication fails using AIQUM
- Remote authentication over SSL fails with "Error reading the SSL certificate" message in AIQUM
- Remote user part of remote group is unable to login to AIQUM server
- Removing ONTAP Cluster from AIQUM servers using ".sql" script
- Renaming source volume causes auxcopy failure in Commvault
- Renaming AIQUM virtual appliance fails due to invalid characters
- Renew the client-type certificate from AIQUM 9.18 but the new certificate is not installed in the ONTAP cluster
- Reset jboss password on Unified Manager 9.7P1 if old password is corrupted
- Resolving Common ActiveIQ Unified Manager Alerts Resolution Guide
- Restore a volume in AIQUM fails with Java error in MCC after new nodes are added
- Restore of Active IQ Unified Manager backup fails after downgrading MySQL from 8.0.22 or 8.0.23
- Restoring a file in AIQUM GUI throws a NullPointerException error with a MAV enabled cluster
- Restoring Active IQ Unified Manager backup to new instance results in error Failed to extract the database dump repository file
- Restoring AIQUM MySQL database fails due to duplicate entry
- Restoring incremental backup restores AIQUM Windows to the point of full backup
- Retrieving deleted object events using REST API in AIQUM returns error 404
S
- SAML authentication is failing due to AIQUM server/ssl certificate expired
- SAML authentication is rejected due to metadata mismatch
- SAML Authentication Sporadically Fails in AIQUM
- Scheduled reports not sending at the correct time after updating the time zone configuration in Unified Manager
- SCOM is unable to collect SNMP trap from AIQUM
- Scripts stopped working after AIQUM Upgrade
- Security events are detected after rebooting AIQUM
- Security events from Active IQ platform presented in Unified Manager
- Security software report get-scalemonitor-os-kpi.ps1 is risk file
- Server shows the connection is insecure after installing a CA certificate
- Service processor not configured event generated on Active IQ Unified Manager(AIQUM) server
- Services do not start after upgrade from AIQUM 9.12 to 9.13 OVA
- Services don't start after upgrade to ActiveIQ Unified Manager 9.7 OVA, because of java library error
- Sharing reports through email on OnCommand Unified Manager fails if the report file is bigger than 25MB
- Sign in to AIQUM failed when /opt/netapp is full
- Snapmirror history gone after Active IQ Unified Manager upgrade
- Snapmirror Lag Status not populated with REST based acquisition in AIQUM 9.16P2
- Snapmirror lag thresholds are incorrect in AIQUM
- Snapmirror relationships not visible with REST-based acquisition in AIQUM 9.14+
- Snapmirror replication unhealthy with different reasons,can it overlap in AIQUM event?
- Snapshot based backups are failing in AIQUM 9.14
- SNMP events are being triggered for excluded volumes in AIQUM to ServiceNow
- Some events that are triggered on the cluster do not trigger alerts in AIQUM
- Some volume performance samples are missing in AIQUM repository database
- Sometimes the API result of volume metrics becomes empty
- Source cluster in SnapMirror Relationship is not being reflected in Active IQ Unified Manager, even when the source cluster is being monitored
- Source cluster in SnapMirror Relationship is not displaying in AIQUM
- SP offline event from AIQUM but its State is Obsolete
- Sporadically unable to login with maintenance user in AIQUM GUI
- SSH Weak Key Exchange Algorithms Enabled in Active IQ Unified Manager vApp instances
- StaleStateException found in server.log after freshserver
- Start operation for Active IQ Management Server service fails due to timeout even though it has actually started
- Stopping - Audit Log disabled warning in Active IQ Unified Manager
- Stopping Oncommandsvc on AIQUM Windows fails in a situation where cluster monitoring failed
- Storage Alerts Not Generating in Active IQ Unified Manager
- Storage controller host discovery is failing within OnCommand Unified Manager/ ActiveIQ Unified Manager
- Subject Alternate Name formatting shows incorrect in Active IQ Unified Manager
- Subscribed EMS events not received by Active IQ Unified Manager in NAT environment
- Subscribed syslog EMS events not appearing AIQUM set up with Kyiv Timezone
- Suddenly Unified Manager fails to start throwing Java error creating bean
- Support path for custom SQL Unified Manager reports and scripts
- Supportability for Security Measures applied to Active IQ Unified Manager for Clustered Data ONTAP
- Swap disk drive is not recognized on AIQUM OVA
- Switch power supply failure does not trigger an event in AIQUM
- System Manager UI does not load due to networking issues
T
- The "Cloud Tier Intercluster Network Interface Down" condition has recovered after motherboard replacement, but the event remains in the "New" state for over a week
- The "Cluster Cloud Tier Planning" events trigger Cluster as an anomaly state in the AIQUM
- The "Verify That SSD Mixing Is Correct" alert report from AIQUM
- The AIQUM "Performance capacity used" and "Available IOPS" show N/A
- The AIQUM alert is invalid with some "Exclude" settings for resource
- The AIQUM alert mail fails send out via the SMTP mail server
- The AIQUM for OVA stops to monitor with the "No space left in device" error
- The AIQUM self-signed certificate expiring or is expired
- The AIQUM services shutdown because of /data usage being too full
- The AIQUM shows "The cluster is not reachable" "Cluster Monitoring Failed" alert occasionally
- The cluster is not reachable in UM because the cluster certificate is expired or SSL is not enabled for the admin SVM
- The cluster is not reachable in UM because the cluster Web services are in a bad state
- The disk usage for AIQUM database backups increases after upgrading AIQUM
- The event page in Active IQ Unified Manager loads slowly due to a large number of events
- The menu for renewing the certificate is not displayed in the Edit Cluster window and the client-ca certificate of AIQUM cannot be renewed
- The MySQL service for Active IQ Unified Manager will not start
- The OCIE service of ActiveIQ UM fails to start because of an incorrect DNS entry
- The ocumserver.log fails to update after reinstalling Active IQ Unified Manager
- The Operation state of the cluster remains stuck in an "In Progress" state
- The refresh button is missing on the event page in the OnCommand Active IQ Unified Manager
- The UI of OnCommand System Manager becomes unreachable after the LIF is migrated to another node
- The UM volume threshold did not identify a volume that passed the full or nearly full threshold
- The Unified Manager upgrade to 9.16 is triggering my security software due to a 'whoami' command. Should I be concerned?
- The upgrade of AIQUM fails without any update in the logs or deployment files
- The vulnerability scan reports the AIQUM has "Self-Signed Certificate"vulnerability
- The Workload Analysis page in AIQUM is blank
- There is no option to view configured NTP settings in AIQ Unified Manager OVA
- Timeout loading volume list when creating a qtree or quota in System Manager 9.8
- Troubleshooting failed Active IQ Unified Manager database restores
U
- UM generates invalid alerts: "Verify that SSD mixing is correct" due to outdated rules
- UM MySQL error file contains warning as row size is 8127, which is greater than maximum allowed size (8126)
- UM with limited memory resources crashes with Java heap space error
- Unable to access Active IQ Unified Manager(AIQUM) Web GUI (404 Error)
- Unable to access Active IQ Unifited Manager with Active directory
- Unable to access AIQUM because NetBackup is installed
- Unable to access AIQUM by assertion failure due to corruption on MySQL tablespace
- Unable to access AIQUM due to Untrusted Certificate error
- Unable to access AIQUM GUI due to error "Cannot set log file .\ib_logfile101 to size"
- Unable to access AIQUM GUI via browser when configuring SAML authentication
- Unable to access OnCommand/ActiveIQ Unified Manager after upgrade in Red Hat/CentOS based servers
- Unable to add a cluster in AIQUM with Error during websocket handshake DNS NXDOMAIN
- Unable to add a cluster to AIQUM 9.13 Linux server
- Unable to add cluster data source
- Unable to add cluster in AIQUM due to insufficient ONTAP user role permissions
- Unable to add cluster in AIQUM with client cert error
- Unable to add cluster in Unified Manager "unknown time-zone ID: <timezone>"
- Unable to add cluster on AIQUM due to failed to register EMS destination
- Unable to add cluster on AIQUM RHEL due to missing acquisition user
- Unable to Add Cluster or acquisition fails for existing clusters on AIQUM due to expired client/HTTPS certificate
- Unable to add cluster to Active IQ Unified Manager due to MTU size configuration
- Unable to add cluster to Active IQ Unified Manager resolution guide
- Unable to add cluster to AIQUM due to blocked communication with node management LIF
- Unable to add cluster to AIQUM fails with "Unexpected HTTP response code:408" error
- Unable to add cluster to Unified Manager due to duplicate certificate entries in a cluster
- Unable to add cluster to Unified Manager due to Reason: Error during websocket handshake: read failed
- Unable to add ONTAP cluster to AIQUM because ONTAP does not accept certificates
- Unable to add ONTAP Cluster to AIQUM RC version
- Unable to add or rediscover a cluster in Unified Manager due to duplicate entry for key in AIQUM
- Unable to add the Cluster due to Maximum number of filter rules
- Unable to add Vcenter in AIQUM
- Unable to apply a performance service level to a workload in Active IQ Unified Manager
- Unable to commit network configuration change in Active IQ Unified Manager virtual appliance
- Unable to communicate with the authentication server due to the following reasons: Client truststore is empty
- Unable to Configure LUN Limit Exceeded Alerts in Active IQ Unified Manager
- Unable to Configure Syslog Server in ActiveIQ Unified Manager
- Unable to connect to the Active IQ Unified Manager Maintenance Console using the Putty session
- Unable to create Mysql dump in Active IQ Unified Manager
- Unable to discover existing cluster in AIQUM after changing name and cluster management IP
- Unable to display data and status shows "unknown" for Virtual Machines in AIQUM server
- Unable to download "download https certificate signing request" from AIQUM
- Unable to Download or copy scripts from AIQUM GUI console
- Unable to edit cluster configuration or add a new cluster from the Active IQ Unified Manager web UI, error: "Failed to fetch the HTTPS certificate from HOSTNAME. Enter a valid Host name or Port."
- Unable to edit Cluster IP or Cluster polling fails after changing the cluster_mgmt IP or password on ONTAP
- Unable to enable and configure eth2 on Unified Manager virtual appliance
- Unable to exclude Notice severity EMS Event from AIQUM alerts
- Unable to expand AIQUM Application / SQL DB installation drive
- Unable to extend data disk in AIQUM 9.16P2 with error Blockdev failed
- Unable to generate support bundle on AIQUM 9.12 Windows with TrustmanagerUtil error
- Unable to import CA-signed certificate in ActiveIQ Unified Manager due to unmatched public keys
- Unable to increase the data disk on Active IQ Unified Manager in vApp
- Unable to launch AIQUM in OVA
- Unable to log into ActiveIQ Unified Manager due to duplicate maintenance accounts
- Unable to login in to AIQUM using SSH
- Unable to login to AIQUM GUI after enabling audit remote logging
- Unable to login to AIQUM GUI After Enabling Remote Syslog Logging
- Unable to login to AIQUM GUI post install on RHEL
- Unable to login to WebUI on newly installed AIQUM on RHEL server
- Unable to login with domain users in AIQUM
- Unable to login with maintenance user after migrating backups to new AIQUM OVA
- Unable to monitor a cluster after restarting AIQUM due to DNS NXDOMAIN
- Unable to perform multiple operations in AIQUM as maintenance user is not in the sudoers file
- Unable to provision new volumes for existing subclients in Commvault/SnapProtect when the destination volume has been deleted
- Unable to receive the Anti-ransomware(ARW) events on AIQUM server
- Unable to rediscover cluster in AIQUM due FIPS enabled
- Unable to regenerate or import HTTPS Certificate in AIQUM GUI fails with errors related to sudo access
- Unable to restore files in an OCUM. Repetitive error seen "Too many snapshots are in progress."
- Unable to see all the volumes in AIQUM for multiple clusters
- Unable to see performance information in Active IQ Unified Manager following Ansible password rotation
- Unable to SFTP into Active IQ Unified Manager virtual appliance after upgrade to 9.12
- Unable to sign a certificate that is submitted to a Microsoft CA using PowerShell
- Unable to start AIQUM services after patching 3rd party dependencies
- Unable to start MySQL in UM due to "Unable to read page"
- Unable to start MySQL service in Active IQ Unified Manager 9.7P1
- Unable to start MYSQL service in AIQUM
- Unable to start mysql service with error "Failed to start MySQL Server"
- Unable to start ocie service or take backup in AIQUM due to Access denied for user 'jboss'@'localhost'
- Unable to update or change the DNS search domain entry in AIQUM VApp
- Unable to Upgrade AIQUM server from version 9.10RC1 to 9.10P1
- Unable to upgrade VMware in AIQUM Error - Must be run on virtual machine console
- Unable to View “Other Ops” Details in System Manager or AIQUM
- UNC path for CIFS share cannot be specified as database backup destination path of Windows AIQUM
- Understanding the SAML authentication workflow in AIQUM
- Unexpected PowerShell Transcript files creation in AIQUM windows server
- Unified Manager - Provisioning of destination volume fails due to autosize value
- Unified Manager 5.x reports a 404 error when accessing the Oncommand Console or Operations Manager UI
- Unified Manager 9.14 and above unable to add or monitor a cluster with cloud agent connection error
- Unified Manager 9.14rc1 does not show EMS events from ONTAP
- Unified Manager acquisition fails after database restore to different drive letter
- Unified Manager backup Error occurred while copying files inside temporary directory
- Unified Manager cannot send AutoSupport through proxies with SSL inspection
- Unified Manager cluster discovery stuck due to unresponsive quota-report-iter ZAPI Call
- Unified Manager cluster discovery stuck due to unresponsive Zapi calls
- Unified Manager cluster discovery timed out after 2 hours
- Unified Manager cluster monitoring fails because of keycache
- Unified Manager cluster removal stuck with the description - Deletion in progress
- Unified Manager database backup fails with error: Copying a file or directory is failed due to a file system error
- Unified Manager database backups fail due to insufficient space
- Unified Manager database restore fails due to unknown command
- Unified Manager deduplication savings statistics not available for volumes
- Unified Manager detects AsyncMirror Replication Lag Error event
- Unified Manager diffie-hellman-group1-sha1 enabled reported as security vulnerability
- Unified Manager displays Applicable to Cluster as No in Subscribe to EMS events
- Unified Manager does not collect the last 15 days of performance data after install or upgrade
- Unified Manager Error loading events when navigating to Event Management
- Unified Manager events and alerts on high node utilization
- Unified Manager fails to communicate with a cluster due to network connectivity issues
- Unified Manager fails to edit cluster password due to expired certificate
- Unified Manager fails to gather performance due to Error: Server returned HTTP response code: 401
- Unified Manager fails to start due to Java version not being detected
- Unified Manager generating new "Single Active Path" events every poll and obsoleting the previous one even if event was acknowledged
- Unified Manager has a banner or event saying management server almost out of memory
- Unified Manager has a repeating error that a Protection Job Failed but the snapmirror is updated correctly
- Unified Manager install fails due to running AntiVirus
- Unified Manager installation fails with "Unable to init MySQL"
- Unified Manager is unable to update Cluster user and drops Cluster history after updating the Cluster password within Unified Manager WebUI
- Unified Manager maintenance_console menu doesn't print menu options
- Unified Manager monitoring fails with "Error: Data ONTAP reported error code (13130), message: 'duplicate entry'"
- Unified Manager OCIE Service cannot start due to being masked
- Unified Manager ocie service fails to start after installing or regenerating the web certificate and restarting services
- Unified Manager only showing performance data on some nodes of cluster
- Unified Manager OVA boot failure due to file system inconsistency
- Unified Manager OVA/vApp database backup creation fails with the message: "Copying a file or directory is failed due to a file system error"
- Unified Manager Performance Capacity Used and Utilization is high
- Unified Manager Performance Capacity Used much higher than expected
- Unified Manager performance collection fails because the cluster certificate is expired
- Unified Manager performance collection fails because the cluster is not reachable
- Unified Manager raises warning about no network interface for NFS
- Unified Manager remote authentication fails with error "Sign In Failed"
- Unified Manager reports cannot be combined with an OR link
- Unified Manager reports no space left for a Snapshot copy
- Unified Manager reports Volume Logical Space Full even though volumes aren't full
- Unified Manager scheduled backup and retention not working
- Unified Manager sends AutoSupport from incorrect email address
- Unified Manager Services fail to start after restoring database in version 9.13
- Unified Manager shows error: The Days Until Full threshold set at 7 days is breached
- Unified Manager Storage service subscription for resource key was not found
- Unified Manager UI not accessible because service does not start
- Unified Manager unable connecting to server using SSL/TLS
- Uninstalling WIndows AIQUM from CLI fails without errors
- Unpacking of baseline messages failed with error: {} : java.lang.ClassCastException : java.lang.ClassCastException
- Unsuccessful installation of AIQUM on a server where UM was previously installed
- Unsupported upgrade path causes backups to fail on AIQUM
- Upgrade from AIQUM 9.6 to 9.7 fails with error (No space left on device)
- Upgrade of Active IQ Unified Manager fails
- Upgrade of Active IQ Unified Manager interrupted before upgrade process is completed
- Upgrade of AIQUM on Windows Platform Fails after entering mysql password
- Upgrade of Unified Manager on Linux hosts fails due to missing dependency
- Upgrade to Unified Manager 9.11P1 Fails on starting services
- Upgrading AIQUM Windows from 9.12 to 9.13 fails with database creation command failed for UM
- Upgrading OnCommand Unified Manager 5.2.X
- Upgrading Unified Manager for Windows fails with dfm-app.war in a failed state, error: "Unable to get CN from the server certificate"
- Upgrading Windows AIQUM to 9.12 fails due to checksum verification failure
- User or group 'name' not found when accessing AIQUM
V
- Validating a successful SAML setup in AIQUM
- var/log/ocie is always getting full with 100 percent utilization
- Virtual Machines are not discovered by AIQUM after adding vCenter Server
- Virtual Machines are not discovered by Unified Manager when NFS datastore is hosted on NetApp storage and mounted via IPv6
- Virtual Machines created on NFS datastore are not discovered in ActiveIQ Unified Manager
- VMs from some datastores not seen in Active IQ Unified Manager
- VMware Host Client shows warning that configured guest OS for AIQUM does not match
- VMware time sync causes Active IQ Unified Manager time drift
- VMware Tools is not installed after upgrading Active IQ Unified Manager Virtual Machine (OVA)
- VMware Tools upgrade or install fails after upgrading Active IQ Unified Manager
- Volume anti-ransomware status is enabled, but AIQUM shows still in learning mode
- Volume capacity full but no alerts received from AIQUM
- Volume displays high-activity workloads for the last X days but has only X Snapshot
- Volume Inode full but no alerts received from AIQUM
- Volume Performance Metrics from AIQUM are not being reported to External Applications
- Volume Snapshot Threshold option disabled in Unified Manager if Snapshot Policy is "none"
- Volume UUID in SNMP trap sent by Unified Manager does not match with any of the volumes
- Volumes unmount and Destroy due to NBU plugin cleanup request sent to AIQUM
- Vulnerable undertow version detected in AIQUM 9.13 and 9.14 causing high CPU and acquisition issue
W
- WFA : Peering has failed:: Cannot peer with two clusters with the same UUID
- WFA End of Support notification
- WFA integration with UM doesn't work after UM upgrade to 9.7 or higher
- What actions are required after changing IP address of AIQUM host?
- What actions are required on AIQUM side when migrating vCenter Server?
- What are ActiveIQ Unified Manager’s recording files and how to we parse them for troubleshooting?
- What are the ActiveIQ Unified Manager performance counters that can be exported to an External Data Provider?
- What are the backup and restore best practices for AIQUM?
- What are the best practices for AIQUM server resources?
- What are the changes to "Performance Capacity" in Active IQ Unified Manager 9.7?
- What are the differences between Destination and Unprotected as displayed in AIQUM?
- What are the different fields for when configuring remote authentication in Active IQ Unified Manager?
- What are the different types of events in Active IQ Unified Manager?
- What are the functional differences between the Active IQ Unified Manager platforms (Windows, Red Hat / CentOS, VMware OVA)?
- What are the names of the services used by AIQUM and their default startup states
- What are the needed permissions for wildfly-service.exe in AIQUM for Windows?
- What are the notable log files and their respective locations for Active IQ Unified Manager?
- What are the prerequisites for Active Directory Remote Authentication with AIQUM?
- What are the prerequisites for NDMP backup and restore with AIQUM and WFA?
- What are the remediation steps to address CVE-2025-0411 on Unified Manager 9.16 for Windows?
- What are the supported migration scenarios for Active IQ Unified Manager?
- What certificates does AIQUM use, what is impact when expired and how to regenerate?
- What do FIN_WAIT_2 Messages mean in netstat output
- What does the "Volume Days Until Full" event in AIQUM mean?
- What does the LDAP Enabled column mean in Active IQ Unified Manager?
- What happens to an event when its source object is deleted
- What happens to EMS Subscriptions when a monitored cluster is removed from ActiveIQ Unified Manager?
- What happens to the EMS subscription request if a cluster is 'not reachable' from ActiveIQ Unified Manager for one or more subscribed EMS events?
- What happens when an event is generated in AIQUM?
- What IP address should I use to add a cluster to AIQUM?
- What is a "Cluster Cloud Tier Planning" event in Unified Manager?
- What is an AIQUM Trap ID 13705 Logical interface No Route Configured?
- What is an audit log tampered event in Active IQ Unified Manager?
- What is cert Authentication Method that has been added when using AIQUM?
- What is impact on AIQUM if cluster certificate expires?
- What is OnCommand Unified Manager development environment?
- What is Performance Budgeting?
- What is the "clus-agent-xxxx" user on my cluster for?
- What is the acquisition recordings folder and can I delete files from it?
- What is the default filter for Event Management in Active IQ Unified Manager
- What is the default MySql password in Active IQ Unified Manager
- What is the difference between Automatically subscribed and Manually subscribed EMS event in Active IQ Unified Manager
- What is the difference between SVM latency and volume latency in AIQUM?
- What is the End of Version Support for NetApp Plug-in for Symantec Netbackup?
- What is the impact of removing the "cluster agent connection" from ONTAP
- What is the purpose of AIQUM server-ca certificate being used by ONTAP?
- What is the requirement to use LDAP authentication user for adding clusters to AIQUM?
- What is the threshold of CRC Error Check For Data NIC Ports AIQUM event?
- What is the upgrade path for Active IQ Unified Manager versions?
- What is the Volume Qtree Quota Overcommitted warning?
- What Log files to look at for Unified Manager backup or restore troubleshooting?
- What options are available for customizing reports in Active IQ Unified Manager
- What permissions are required to add a cluster to AIQUM?
- What platform or version limitations are there when restoring an Active IQ Unified Manager backup
- What should be done if Oncommandsvc becomes STOP_PENDING while trying to stop it?
- What steps should be taken when changing password for cluster monitored by AIQUM?
- What values are shown in performance table on AIQUM Performance Explorer page?
- What version of Active IQ Unified Manager does NetApp recommend?
- What version of Active IQ Unified Manager first deprecated v1 APIs?
- What version of axios does AIQUM use?
- What versions of MySQL are required for AIQUM releases 9.9.- 9.11?
- What Windows diagnostic commands are executed by Unified Manager during ASUP or Support Bundle collections?
- When attempting to add an authentication server in the AIQUM using the "Use Secure Connection" option, an error is thrown: "Cannot establish communicate to the host xxx.xxx.xxx over SSL"
- When integrated with Commvault application errors seen in Aiqum 9.18
- When renewing the client or client-ca certificate from AIQUM, is it expected behavior for the “Issued on” date and the “Expired on” date to be one day earlier?
- When restoring Active IQ Unified Manager database backup the hostname of the original server is used
- When setting up an alert in AIQUM, can events be specified using a blacklist approach?
- When subscribing to EMS events within Unified Manager, "Applicable to Cluster" status shows “No”
- When upgrading the RHEL version of AIQUM that is not connected to an external network, how should third-party software be upgraded?
- When using AD remote authentication in AIQUM, can the username be specified in formats such as down-level logon name or UPN instead of just the username?
- Where are AIQUM API POST requests logged?
- Where are the performance API calls in ActiveIQ Unified Manager?
- Where can I download the MIB files for Active IQ Unified Manager?
- Where can I download Unified Manager software?
- Where can I find information on the AIQUM database schema
- Where can information be found about third-party software used by Unified Manager?
- Where is the destination of AIQUM AutoSupport message to technical support?
- Where is the performance inventory page for storage objects located in AIQUM?
- Where to execute Unified Manager CLI commands in VMware (OVA) environment?
- Where to find an aggregate specific storage capacity graph in AIQUM for the last 12 months?
- Which expiring SSL certificate generates AIQUM alert "Cluster Certificate About to Expire" and "Cluster Certificate Expired"
- While preparing to upgrade Active IQ Unified Manager, MySQL does not start after upgrading to 8.0.x from 5.7.x
- Why "LUN Offline" event is not generated in the OnCommand Unified Manager?
- Why Aggregate Latency graph in UM, shows constantly higher latency for one aggregate?
- Why AIQUM does not support higher version ONTAP?
- Why are SnapMirror and AIQUM using ports not specified in the requirements?
- Why can't clusters send some configured EMS events to ActiveIQ Unified Manager?
- Why can't I set a QoS policy on a volume in Active IQ Unified Manager?
- Why do alerts not get triggered on certain EMS events in AIQUM?
- Why do I only see 30 days worth of snapmirror history in Active IQ Unified Manager?
- Why do I see an increase in IOPs or throughput for an ONTAP volume?
- Why does Active IQ Unified Manager alerts on 'Out of Memory' condition when the total memory usage is less than 100 percent?
- Why does Active IQ Unified Manager not show performance statistics for a volume?
- Why does Active IQ Unified Manager report no performance statistics for a node?
- Why Does ActiveIQ Unified Manager show different metrics and statistics than we see on Grafana?
- Why does AIQUM not trigger an alert when the Node panics?
- Why does AIQUM reports "Single Mode Ifgrps Are Not Recommended" or any alerts related to configuration?
- Why does AIQUM trigger multiple mail alerts for Ransomware Activity Detected event with NEW and OBSOLETE status at the same time for the same volumes?
- Why does the entitlement risks page in ONTAP System Manager show some nodes as unlicensed for a feature, when they are per the CLI?
- Why does the sum of all volume IOPS in an aggregate not match the aggregate IOPS?
- Why does the volume latency or IOPS not match the aggregate in Active IQ Unified Manager or ONTAP?
- Why has ActiveIQ Unified Manager stopped receiving configured EMS events from a cluster after ONTAP was upgraded to a newer release?
- Why is ’Aggregate disks over-utilized’ reported, even if DF shows aggr used size is fewer than 90%?
- Why is ‘Thin-Provisioned Volume Space At Risk’ event in UM seen with volume provisioned capacity being a short percentage of the available space of the host aggregate?
- Why is Active IQ Unified Manager not able to send notifications for issues even though EMS subscriptions appear to have been successfully configured?
- Why is Active IQ Unified Manager not affected by CVE-2023-4807?
- Why is Aggregate Degraded event sometimes not triggered by AIQUM even though Aggregate Reconstructing event is triggered?
- Why is an ONTAP cluster missing from the Unified Manager web interface?
- Why is Cluster Capacity being listed HA-Pair wise instead of Cluster wise in AIQUM 9.12 onwards
- Why is the "Volume Growth Rate Abnormal" event displayed after midnight?
- Why is there a difference between ONTAP "statistics volume" and Active IQ Unified Manager IOP counts?
- Why is there no data present in the table netapp_model_view.snapshot within Active IQ Unified Manager
- Why is Unified Manager showing a status of 'Yes' in the Applicable to Cluster column for the EMS event(s) added, but is not receiving EMS notifications from a cluster?
- Why it takes up to 15 mins for ActiveIQ Unified Manager to alert for a user/group quota breach?
- Why Max value is inconsistent with breakdown view of AIQUM performance chart?
- Why may AIQUM report qtree space events or not when quota is turned off and then on?
- Why the available aggregate IOPS is increased after AIQUM upgrade?
- Why UM shows Qtree Space Full event on allocated volume size when quota is not set?
- Why volume latency alert received when graph doesn't shows 5 minute continued latency
- Why Volume level IOPS exceeds Node IOPS in AIQUM
- Will Microsoft 2011 Secure Boot UEFI expiration impact OnCommand applications?
- Will upgrading ONTAP to v9.14.1 with AIQUM v9.14 and closed AMQP port cause issues
- Windows Active IQ Unified Manager does not complete the backup
- Windows Active IQ Unified Manager upgrade fails reporting permission error
- Windows AIQUM services are regularly crashing
- Workloads from ONTAP 9.16.1 are not displayed in AIQUM 9.14
X
