NetApp Knowledge Base
If AIQUM is upgraded together with ONTAP, and AIQUM is restored from a VM snapshot taken before the upgrade, will monitoring continue as normal?
35
Visibility:
Votes:
1
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP 9
  • ActiveIQ Unified Manager (AIQUM)
Answer
Yes, after restoring the AIQUM from a VM snapshot and starting,  the AIQUM resumes monitoring as normal without any special operations.
Note:
  • If an ONTAP has also been upgraded and the version of the ONTAP is not compatible with the restored AIQUM version according to the Interoperability Matrix tool(IMT), monitoring the ONTAP from the AIQUM is not guaranteed.
  • Once the cause of the upgrade failure is identified, the upgrade can be rerun.
Additional Information
It is recommended to upgrade AIQUM prior to upgrading Ontap.
