NetApp Knowledge Base
Subscribed syslog EMS events not appearing AIQUM set up with Kyiv Timezone
34
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • ActiveIQ Unified Manager (AIQUM) 9.x
  • All OS platforms
  • Syslog EMS
Issue
  • Some of the subscribed syslog EMS events not appearing AIQUM
  • Alerts appear for other EMS events shows future timestamp in AIQUM GUI
  • ONTAP/AIQUM server timezone appears correct
  • Errors present on ocumserver.log while subscribing an event wafl.vvol.offline and testing the same from ONTAP:
     DEBUG [vldshka] [default task-24] [service.ems.SubscribeEmsDataAccessService|loadData] [org.dozer.fieldmap.FieldMap] Getting ready to invoke write method on the destination object. Dest Obj: SubscribedEmsDto, Dest value: wafl.vvol.offline
     DEBUG [vldshka] [default task-24] [service.ems.SubscribeEmsDataAccessService|loadData] [org.dozer.MappingProcessor] MAPPED: SubscribedEms.messageName --> SubscribedEmsDto.messageName    VALUES: wafl.vvol.offline --> wafl.vvol.offline    MAPID:
     DEBUG [vldshka] [default task-24] [service.ems.SubscribeEmsDataAccessService|loadData] [org.dozer.MappingProcessor] MAPPED: SubscribedEms.description --> SubscribedEmsDto.description    VALUES:  -->     MAPID:
     DEBUG [vldshka] [default task-24] [service.ems.SubscribeEmsDataAccessService|loadData] [org.dozer.fieldmap.FieldMap] Getting ready to invoke write method on the destination object. Dest Obj: SubscribedEmsDto, Dest value: Invalid
     DEBUG [vldshka] [default task-24] [service.ems.SubscribeEmsDataAccessService|loadData] [org.dozer.MappingProcessor] MAPPED: SubscribedEms.status --> SubscribedEmsDto.status    VALUES: Invalid --> Invalid    MAPID:
     DEBUG [oncommand] [SyslogServer: udp] [o.s.t.jta.JtaTransactionManager] Participating in existing transaction
     DEBUG [oncommand] [SyslogServer: udp] [o.s.jdbc.datasource.DataSourceUtils] Fetching JDBC Connection from DataSource
     ERROR [oncommand] [SyslogServer: udp] [c.n.d.e.i.o.f.ClusterEntityManager] ERROR while retriving cluster id for the BGP LIF
     INFO  [oncommand] [SyslogServer: udp] [c.n.d.o.o.s.OntapOutboundServiceFactory] Getting serviceType EMS_SERVICE and clientType REST from service registry
     DEBUG [oncommand] [SyslogServer: udp] [o.s.t.jta.JtaTransactionManager] Participating transaction failed - marking existing transaction as rollback-only
     DEBUG [oncommand] [SyslogServer: udp] [o.s.t.jta.JtaTransactionManager] Setting JTA transaction rollback-only
     INFO  [oncommand] [SyslogServer: udp] [com.netapp.dfm.collector.LockUtils] Releasing ems-processing lock(java.util.concurrent.locks.ReentrantReadWriteLock$WriteLock@139764ee[Locked by thread SyslogServer: udp]) for 18
     DEBUG [oncommand] [SyslogServer: udp] [o.s.t.jta.JtaTransactionManager] Initiating transaction rollback
     ERROR [oncommand] [SyslogServer: udp] [c.n.dfm.impl.ems.SysLogEventHandler] Problems with Syslog Invalid get collection request with cause : "\"36\" is an invalid value for field \"message.name\" (<Message Name>)":null. On Cluster:<Node_Management_IP>
  • Error suggests that AIQUM cant get the cluster details from node management LIF
New to NetApp?
