NetApp Knowledge Base
AIQUM 9.16 and above shows multiple issues  during fresh installation on RHEL 9.x due to File Access Policy and Firewall daemons
47
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • ActiveIQ Unified Manager (AIQUM) 9.16+
  • RedHat Linux (RHEL) 9.x
  • File Access Policy Daemon (fapolicyd)
  • Firewall daemon (firewalld)
Issue
  • AIQUM fresh installation on RHEL 9.x failed even though the pre_install script shows no issue
  • Error on screen (also recorded on /var/log/dnf.log):
[root@AIQUM netapp]# yum localinstall netapp-um-9.18-el9.x86_64.rpmLast metadata expiration check: 0:47:07 ago on Mon 23 Feb 2026 11:33:51 AM CET.
Dependencies resolved.=====================================================================================================================================================================================================Package                                      Architecture                              Version                                                Repository                                       Size=====================================================================================================================================================================================================Installing:netapp-um                                    x86_64                                    9.18-2601081010.el9                                    @commandline                                    1.8 GTransaction Summary=====================================================================================================================================================================================================Install  1 Package
Total size: 1.8 G
Installed size: 1.9 G
Is this ok [y/N]: y
Downloading Packages:
Package netapp-um-9.18-el9.x86_64.rpm is not signed
Error: GPG check FAILED
  • Attempting with --nogpgcheck allows the installation to proceed: yum localinstall netapp-um-9.18-el9.x86_64.rpm --nogpgcheck
  • However ocie service failed to start after installation:
  • /var/log/ocie/server.log:
WARN  [org.jboss.modules.define] (main) Failed to define class org.jboss.as.server.jmx.PluggableMBeanServer in Module "org.jboss.as.server" version 18.1.2.Final from local module loader @41ee392b (finder: local module finder @1e67a849 (roots: /opt/netapp/essentials/jboss/modules, /opt/netapp/essentials/jboss/modules/system/layers/base)): org.jboss.modules.ModuleLoadError: Error loading module from /opt/netapp/essentials/jboss/modules/system/layers/base/org/jboss/classfilewriter/main/module.xml
Caused by: org.jboss.modules.xml.XmlPullParserException: Failed to add resource root 'unnamed' at path 'jboss-classfilewriter-1.2.5.Final.jar' (position: END_TAG seen ...     <resource-root path="jboss-classfilewriter-1.2.5.Final.jar"/>... @29:70) caused by: java.io.FileNotFoundException: /opt/netapp/essentials/jboss/modules/system/layers/base/org/jboss/classfilewriter/main/jboss-classfilewriter-1.2.5.Final.jar (Operation not permitted)
Caused by: java.io.FileNotFoundException: /opt/netapp/essentials/jboss/modules/system/layers/base/org/jboss/classfilewriter/main/jboss-classfilewriter-1.2.5.Final.jar (Operation not permitted)
New to NetApp?
