NetApp Knowledge Base
AIQUM acquisition process after adding datasource does not finish because Health Poll fails
896
Visibility:
Votes:
1
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
Applies to
  • ActiveIQ Unified Manager (AIQUM) 9.14+
  • ONTAP 9.14+
Issue
  • Cluster discovery takes a long time and eventually fails
  • AIQUM's Event Management:
Event: Cluster Monitoring Failed.
Monitoring failed for cluster cluster. Reason: Incorrect response from one or more Data ONTAP APIs. Contact technical support.
  • acquisition/au.log:
INFO  [common-pool-4105] c.o.s.a.d.n.NetAppOCIEDataSource (NetAppOCIEDataSource.java:217) - [CA] Cloud Agent Baseline response took 600002 ms
ERROR [common-pool-4105] c.o.s.a.d.n.NetAppOCIEDataSource (NetAppOCIEDataSource.java:223) - Timed out waiting for cluster, recommend increasing timeout value
INFO  [common-pool-4105] c.o.s.a.d.n.NetAppOCIEDataSource (NetAppOCIEDataSource.java:338) - [] Total poll duration: 600003 ms
INFO  [common-pool-4105] c.o.s.a.d.n.NetAppOCIEDataSource (NetAppOCIEDataSource.java:346) - [] -- Finished Poll --
INFO  [common-pool-4105] c.o.s.a.f.d.BaseDataSource (BaseDataSource.java:667) - Datasource - 1.2.3.4 is stopped.
ERROR [common-pool-4105] c.o.s.a.f.d.BaseDataSource (DataSourceErrorException.java:246) - 1.2.3.4 [Error retrieving data] - Timed out waiting for cluster, recommend increasing timeout value ([Device name General Device]: Timed out waiting for cluster, recommend increasing timeout value)
INFO  [common-pool-4105] c.o.m.h.AUAuditHttpClientManager (AUAuditHttpClientManager.java:74) - Closing datasource audit
INFO  [common-pool-4105] c.o.s.a.f.d.BaseDataSource (BaseDataSource.java:311) - [netappfoundation] 1.2.3.4 - Finished acquisition (600058 msecs)
  • jboss/server_acq.log shows cloud agent communication event:
ERROR [default task-3936] c.n.u.CloudAgentConnectionUtil (CloudAgentConnectionUtil.java:102) - deletion of connection agent from datasource failed with error code: 404
INFO  [default task-3936] c.n.s.m.AccessHandle (AccessHandle.java:101) - Transitioning state from MAIN to DOWN
ERROR [default task-3936] c.n.s.m.JmsBase (JmsBase.java:261) - Failed to create TextMessage: javax.jms.IllegalStateException: The Session was closed due to an unrecoverable error
  • OCUMSERVER.log:
WARN  [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Acquisition Failed for cluster : 1.2.3.4 message : Timed out waiting for cluster, recommend increasing timeout value
INFO  [oncommand] [reconciliation-0] [c.n.dfm.collector.OcieJmsListener] CONFIG ds=1.2.3.4(8), PollStartTime=1748324314785, UpdateTime=1748324914803, MegaDuration=600003, SystemTime=1748324914822
ERROR [oncommand] [job-451] [refresh(dataSource=1.2.3.4)|forceAcquisition] [com.netapp.dfm.job.JobEngine] Error executing job 641be6841c6a5a33:774b111c:196e5df2fc0:-79e9 task 641be6841c6a5a33:774b111c:196e5df2fc0:-79eb: Errors reported on acquisition with start time 14:38:34.785: [Timed out waiting for cluster, recommend increasing timeout value]
java.lang.RuntimeException: Errors reported on acquisition with start time 14:38:34.785: [Timed out waiting for cluster, recommend increasing timeout value]
New to NetApp?
