NetApp Knowledge Base
What certificates does AIQUM use, what is impact when expired and how to regenerate?
14,870
Visibility:
Votes:
3
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM)
  • ONTAP 9
Answer
  • SSL (HTTPS) certificate
Type server-ca
Generated by AIQUM
Stored in AIQUM/ONTAP
Purpose
Authentication of AIQUM server in HTTP/HTTPS connections via browser
Note: AIQUM installs this certificate to ONTAP while adding cluster
Impact when expired
How to regenerate
Validity duration 397 days by default, see also Generating an HTTPS security certificate
Activate new certificate
  • After generate the HTTPS Certificate, restart AIQUM to take effort.
  • Attempt to re-add the cluster from cluster setup page.
CLI example
cluster2::> cert show -vserver cluster2 -type server-ca -organization NetApp
  (security certificate show)
Vserver    Serial Number   Certificate Name                       Type
cluster2   40CF33F77B77864D hshovaum                              server-ca
    Certificate Authority: hshovaum
          Expiration Date: Tue Dec 15 11:58:43 2026
-Notes:
  • Specifying the organization as NetApp will filter out the unrelated certificates
  • The certificate name will be the hostname of the UM server.
  • EMS certificate
Type client
Generated by AIQUM
Purpose
Authentication of EMS notifications received from ONTAP for Subscribing to ONTAP EMS events
Impact when expired
How to regenerate In Unified Manager 9.18 and newer you can regenerate the client certificate (EMS Certificate)  via the maintenance console with the option 'Regenerate Client Certificate'.
  • For versions prior to 9.18, follow CAIQUM-5308  to regenerate the client certificate(EMS Certificate) manually from AIQUM CLI
Validity duration 5 years
Activate new certificate NA
CLI example
cluster2::> cert show -vserver cluster2 -type client -organization NetApp
cluster2   2D5B5CF5        3416f93a-d90b-4aed-a0b2-71205700fe29   client
    Certificate Authority: 3416f93a-d90b-4aed-a0b2-71205700fe29
          Expiration Date: Sun Jun 23 16:22:10 2030
-Notes:
  • The certificate name will be the systemid of the UM server.
  • Certificates for Mutual TLS communication
Type client-ca
Generated by AIQUM
Purpose
Authentication of ONTAP cluster during AIQUM data acquisition via certificate-based authentication.
Impact when expired
How to regenerate Follow the steps in  How to renew a client-ca certificate for Active IQ Unified Manager
Validity duration 1 year, see also CAIQUM-5794
CLI example
cluster2::> cert show -vserver cluster2 -type client-ca -organization NetApp
cluster2   777A377BE8F59D77 admin                                 client-ca
    Certificate Authority: admin
          Expiration Date: Tue Jan 19 12:12:29 2027
-Notes:
  • The certificate name will be the account used to monitor the cluster by the UM server.
  • Cluster certificates
Type server
Generated by ONTAP
Stored in ONTAP
Purpose Authentication of ONTAP cluster while adding ONTAP cluster
Impact when expired
Note: See also What is the impact of an expired digital certificate used for a Vserver for the impact from ONTAP cluster perspective
How to regenerate How to renew a Self-Signed SSL certificate in ONTAP 9
Validity duration 1 year by default, see also Renew TLS/SSL Certificate in ONTAP 9 - Resolution Guide
Activate new certificate After verifying Self-Signed SSL Certificate is up to date, attempt to re-add the cluster on the Cluster Setup page.
CLI example
cluster2   186EAB83D68813CC cluster2_186EAB83D68813CC             server
    Certificate Authority: cluster2
          Expiration Date: Thu Oct 15 08:58:07 2026
Note: If there are multiple, you can run 'ssl show -vserver <cluster name>' to confirm which one is in use.
Note:
Types of certificate can be found by using -type parameter of ONTAP security certificate show command
::> security certificate show -type server-ca
cluster1   85589F65349650BE
                           aiqum.demo.netapp.com_85589F65349650BE server-ca
    Certificate Authority: demo.netapp.com
          Expiration Date: Fri Nov 01 21:06:11 2058
