NetApp Knowledge Base
AIQUM gets unresponsive frequently and autosupport generation fails
1,428
Visibility:
Votes:
1
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
Applies to
  • ActiveIQ Unified Manager (AIQUM)9.6+
  • Windows Platform
  • Rhel
Issue
  • AIQUM gets unresponsive frequently
  • Reboot of the server fix it temporarily before getting into hung state again
  • Autosupport generation fails from maintenance_console/GUI
  • Possible errors in server_mega.log:
ERROR [default task-29] c.n.s.s.a.EmsPostServlet (EmsPostServlet.java:139) - EMS message is malformed; : javax.xml.bind.UnmarshalException
 - with linked exception:
[java.io.IOException: An established connection was aborted by the software in your host machine]
 at com.sun.xml.bind@2.3.3-b02-jbossorg-2//com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:231)
 at com.sun.xml.bind@2.3.3-b02-jbossorg-2//com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(UnmarshallerImpl.java:199)
Caused by: java.io.IOException: An established connection was aborted by the software in your host machine
New to NetApp?
