NetApp Knowledge Base
Cluster acquisitions fail with SAML Enabled and mTLS disabled
2,601
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
Active IQ Unified Manager 9.14+
Issue
Cluster acquisition failing clusters because of a malformed JSON response received for a REST API during the foundation poll.
2025-01-13 13:34:50,300 ERROR [rgraf][default task-35][c.n.d.o.o.OntapMutualAuthenticationManager]Exception installing Mutual TLS certificate on ONTAP
com.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 12 path $
    at deployment.dfm-app.war//com.google.gson.JsonParser.parseReader(JsonParser.java:66)
    at deployment.dfm-app.war//com.google.gson.JsonParser.parseString(JsonParser.java:47)
    at deployment.dfm-app.war//com.google.gson.JsonParser.parse(JsonParser.java:98)
    at deployment.dfm-app.war//com.netapp.connection.core.OntapRestResponse.<init>(OntapRestResponse.java:32)
    at deployment.dfm-app.war//com.netapp.resource.Node.getCollection(Node.java:576)
    at deployment.dfm-app.war//com.netapp.dfm.ontap.outbound.service.rest.OntapNodeRestService.isSpareLow(OntapNodeRestService.java:49)
    at deployment.dfm-app.war//com.netapp.dfm.collector.ClusterSparesEventDetector.onCompletion(ClusterSparesEventDetector.java:56)
    at deployment.dfm-app.war//com.netapp.dfm.collector.ClusterSparesEventDetector$$FastClassBySpringCGLIB$$fa213feb.invoke(<generated>)
    at deployment.dfm-app.war//org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218)
Caused by: com.google.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 12 path $
New to NetApp?
