NetApp Knowledge Base
Generate CSR doesn't work in AIQUM
192
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM) 9.x
  • Red Hat Enterprise Linux (RHEL)
  • Certificate Signing Request (CSR)
Issue
  • In AIQUM running on RHEL, navigating to General → HTTPS Certificates → Download HTTPS Certificate Signing Request does nothing — no CSR file is offered for download and the GUI returns no visible error.
  • Reviewing /opt/netapp/essentials/jboss/server/onaro/log/ocumserver.log at the time of the click shows a BouncyCastle signer failure:
ERROR [admin] [default task-3118] [c.n.o.r.m.e.GlobalExceptionHandler] cannot create signer: Key must not be null
org.bouncycastle.operator.OperatorCreationException: cannot create signer: Key must not be null
at deployment.dfm-app.war//org.bouncycastle.operator.jcajce.JcaContentSignerBuilder.build(Unknown Source)
at deployment.dfm-app.war//com.netapp.dfm.app.common.security.CertificateManagerImpl.createCertificationRequest
(CertificateManagerImpl.java:110)
Caused by: java.security.InvalidKeyException: Key must not be null
  • The same error is visible in the browser HAR capture as a 500 response to the Download HTTPS Certificate Signing Request REST call.
  • A keytool -list against the JBoss keystore may show an entry created at install/upgrade time with an unexpected key size or signature algorithm (for example a 3072-bit RSA key when the in-product self-signed entry should be 2048-bit)
  • This indicates the private key material the GUI expects to sign with is missing or mismatched in the keystore.
New to NetApp?
