NetApp Knowledge Base
AIQUM installation or upgrade completes and OCIE not starting
1,999
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM)
  • RHEL/CENTOS
Issue
  • RHEL installation/upgrade completes but OCIE does not start and eventually times out.
  • Errors seen:
    • netapp-um-post-install.log
      • Jun 12 11:27:48 hostname [477873]: Starting Active IQ Management Server service . This may take couple of minutes
        Jun 12 11:34:37 hostname sudo[493864]: pam_sss(sudo:account): Access denied for user jboss: 6 (Permission denied)
        Jun 12 12:27:31 hostname systemd[1]: ocie.service: start operation timed out. Terminating.
        Jun 12 12:27:31 hostname systemd[1]: ocie.service: Failed with result 'timeout'.
        Jun 12 12:27:31 hostname systemd[1]: Failed to start LSB: Active IQ Management Server.
    • ocumserver.log
      • 2024-06-12 11:29:50,131 ERROR [oncommand] [ServerService Thread Pool -- 118] [c.n.d.a.c.l.OnStartupMethodInvoker] Exception during startup java.lang.IllegalArgumentException: Unable to get CN from the server certificate.
    • server.log
      • 06-12 11:29:50,132 ERROR [org.jboss.msc.service.fail] (ServerService Thread Pool -- 118) MSC000001: Failed to start service jboss.deployment.unit."dfm-app.war".undertow-deployment: org.jboss.msc.service.StartException in service jboss.deployment.unit."dfm-app.war".undertow-deployment: java.lang.RuntimeException: java.lang.IllegalArgumentException: Unable to get CN from the server certificate.
        2024-06-12 11:29:50,147 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) WFLYCTL0013: Operation ("deploy") failed - address: ([("deployment" => "dfm-app.war")]) - failure description: {"WFLYCTL0080: Failed services" => {"jboss.deployment.unit.\"dfm-app.war\".undertow-deployment" => "java.lang.RuntimeException: java.lang.IllegalArgumentException: Unable to get CN from the server certificate.
        2024-06-12 11:29:50,196 ERROR [org.jboss.as] (Controller Boot Thread) WFLYSRV0026: WildFly Full 26.1.3.Final (WildFly Core 18.1.2.Final) started (with errors) in 114705ms - Started 11132 of 11372 services (2 services failed or missing dependencies, 459 services are lazy, passive or on-demand) - Server configuration file in use: standalone-full.xml
    • server_mega.log
      • 2024-06-12 11:29:50,120 ERROR [ServerService Thread Pool -- 118] c.o.m.s.ServerCertificateUtils (ServerCertificateUtils.java:170) - Unable to retrieve server certificate; : java.io.IOException: Keystore was tampered with, or password was incorrect
            at java.base/sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:795)
        Caused by: java.security.UnrecoverableKeyException: Password verification failed
            at java.base/sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:793)
            ... 58 more
New to NetApp?
