NetApp Knowledge Base
Acquisition failed for all clusters in AIQUM due to maximum connection limit exhaustion
2,386
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • ActiveIQ Unified Manager (AIQUM) 9.6+
  • All OS platforms
  • ONTAP 9.x
Issue
  • Intermittently acquisition is failing for all clusters added to AIQUM
  • Cluster Monitoring Failed and Cluster Not Reachable alerts are triggered by AIQUM
  • However, the acquisition starts working automatically after sometime or if triggered manually.
  • All the prerequisites like AV exclusions and resources availability in terms of CPU/Memory/Disk space are applied on the AIQUM.
  • SSL certificates for AIQUM as well as the ONTAP clusters are valid.
  • AIQUM au.log:
ERROR [common-pool-2064] c.o.s.a.d.n.NetAppOCIEArchivePerformancePackage (NetAppOCIEArchivePerformancePackage.java:381) - Failed to get archive file names from zapi. java.net.SocketTimeoutException: connect timed out
at java.net.PlainSocketImpl.waitForConnect(Native Method) ~[?:?]
Wrapped by: com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Failed to connect to <cluster IP/Hostname>
at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.transport.zapi.ZAPIConnection.createDefaultNaServer(ZAPIConnection.java:803) ~[au-datasource-netappfoundation.jar:9.13.0-2023.09.J299]
ERROR [common-pool-2064] c.o.s.a.f.d.BaseDataSource (DataSourceErrorException.java:246) - <cluster_IP/Hostname> [Error connecting] - Failed to connect to <cluster IP/Hostname> (connect timed out)
ERROR [common-pool-8838] c.o.s.a.f.d.BaseDataSource (DataSourceErrorException.java:244) - Cluster-mgmt [Error connecting] - Failed to connect to Cluster-mgmt (Read timed out) java.net.SocketTimeoutException: Read timed out
ERROR [foundation-poll-1] c.n.u.RestUtil (RestUtil.java:227) - Establishing connection with datasource failed java.net.SocketTimeoutException: Read timed out
  • AIQUM ocumserver.log shows:
ERROR [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Socket connection error for cluster: <cluster IP/Hostname> java.net.ConnectException: Connection timed out: connect
ERROR [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Cluster : <cluster IP/Hostname> is not reachable. Generating cluster not reachable event.
WARN  [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Acquisition Failed for cluster : Cluster-mgmt message : Read timed out
  • apache_error.log shows HTTP connection limit has been reached:
[mpm_event:warn] [pid 7215:tid 34401862144] A keepalive connection from ipspace ID -1, remote address <AIQUM IP/Hostname> is being suspended between requests while the 80-connection limit has been reached. (80 active, 8 waiting) Clients should limit the number of concurrent keepalive connections to avoid large performance penalties and/or failures.
[mpm_event:notice] [pid 7215:tid 34402611200] Holding a connection from ipspace ID -1, remote address <AIQUM_IP/Hostname> while 54 others are held and 80 are active
[mpm_event:notice] [pid 7215:tid 34402611200] Holding a connection from ipspace ID -1, remote address <AIQUM_IP/Hostname> while 55 others are held and 80 are active
  • apache_access.log shows status 408 (Request Timed out)/ 404(Not Found) / 500(Internal Server Error) for AIQUM API call requests:
<AIQUM IP/Hostname> pii_encrypt/3haVFUKxlfQdtYhedGIaWKrSBVCn+5sImuFntsUoOAk=/pii_encrypt - - [Date/Time] "-" 408 - 38 - 0 - - -
<AIQUM IP/Hostname> pii_encrypt/SDcefmsALVePKOMbzl/puA6V6v/HBFUwpN2g9sF8sNo=/pii_encrypt - - [Date/Time] "GET /spi/Node1/etc/log/autosupport/timestamp.0.files/ HTTP/1.1" 500 - 72496937 - 0 - - - - -
<AIQUM IP/Hostname> pii_encrypt/SDcefmsALVePKOMbzl/puA6V6v/HBFUwpN2g9sF8sNo=/pii_encrypt - - [Date/Time] "GET /spi/Node2/etc/log/autosupport/timestamp.0.files/ HTTP/1.1" 404 - 72064359 - 0 + - - - -
New to NetApp?
