NetApp Knowledge Base
Example of data being sent to NetApp when AutoSupport is enabled on AIQUM
303
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
Applies to
  • Active IQ Unified Manager(AIQUM)
  • ONTAP
Answer
There are two asup types sent by AIQUM
  1. AIQ_Datasource (daily asup)
  • storage summary counts - Count of the storage objects like clusters, svms, volumes, etc
  • object counts
  •  aggregate analytics - Data about the aggrs and their utilization.
  • "cluster_name": "xxx",
  • "free_capacity_in_bytes": 4878926417920,
  • "aggregate_utilization_percent_24_hours": [],
  • "available_ops_24_hours": [],
  • "node_name": "xxx1_1",
  • "serial_number": "XXXXXXXXXX",
  • "uuid": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx",
  • "inactive_data_reporting_enabled": true,
  • "cluster_uuid": "yyyyyyyy-yyyy-yyyy-yyyy-yyyyyyyyyyyy",
  • "name": "xxx1_1_SAS_1",
  • "performance_utilization_percent_24_hours": [],
  • "total_capacity_in_bytes": 9233409974272,
  • "latency_avg_in_ms_24_hours": [],
  • "aggregate_type": "HDD",
  • "status": "NONE",
  • "ops_avg_24_hours": []
  • fabricpool analytics - similar to the aggr analytics
  • node analytics - similar to the aggr analytics
  • headers - basically an extended x-headers as seen in the support bundle.
  • managed object counts - same as seen in support bundle. A count of all the objects in Unified Manager, per cluster and svm.
  • manifest - list of the included files.
  • x-headers - same as the file in the support bundle. host os and hostname/um version/asup sequence info
2. SCHEDULED (Monday asup)
  • This is smaller version of a support bundle, but containing the logs for just one day and no recordings or database/heap dumps
  • This also contains some metrics info that engineering needs to mine about Unified Manager, but those files are not normally used by support. They contain no pii.
  • There are also files related to the protection relationships UM monitors, PSLs, SLOs, and config advisor event counts.
  • There are more files in this asup than in the datasource asup.
