NetApp Knowledge Base
AUX copies fails using Commvault with 'JDBCConnectionException' error
638
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
AIQUM 9.X
Issue
AUX copy operation usingCommvaultfails  with JDBCConnectionException error
Error returned:[13001][Unable to acquire JDBC Connection; nested exception is org.hibernate.exception.JDBCConnectionException
OCUM server log:
2023-03-15 19:10:11,203 ERROR [oncommand] [um-default-data-source connection adder] [com.zaxxer.hikari.pool.HikariPool] um-default-data-source - Error thrown while acquiring connection from data source
java.sql.SQLSyntaxErrorException: (conn=63788) Connection.setNetworkTimeout cannot be called on a closed connection
at org.mariadb//org.mariadb.jdbc.internal.util.exceptions.ExceptionFactory.createException(ExceptionFactory.java:62)
at org.mariadb//org.mariadb.jdbc.internal.util.exceptions.ExceptionFactory.create(ExceptionFactory.java:171)
at org.mariadb//org.mariadb.jdbc.MariaDbConnection.setNetworkTimeout(MariaDbConnection.java:1655)
Ocum error log:
2023-03-15 19:13:30,615 ERROR [oncommand] [job-611] [c.netapp.dfm.workqueue.WorkerThread] Internal system error: Failed to obtain JDBC Connection; nested exception is java.sql.SQLTransientConnectionException: um-default-data-source - Connection is not available, request timed out after 30002ms.
2023-03-15 19:20:59,065 ERROR [ocumadm] [job-640] [conform(storageService=CC-CVLT-NGDC-EMEA_SP-38_Copy-102)|FINISH] [com.netapp.dfm.job.JobEngine] Unexpected error setting status for task be62767482397849:-7b935f7f:186e5e31509:-860 in job be62767482397849:-7b935f7f:186e5e31509:-808. Terminating job.
2023-03-15 19:20:59,065 ERROR [ocumadm] [job-640] [conform(storageService=CC-CVLT-NGDC-EMEA_SP-38_Copy-102)|FINISH] [com.netapp.dfm.job.JobEngine] Failed to persist job after executing task: Failed to obtain JDBC Connection; nested exception is java.sql.SQLTransientConnectionException: um-default-data-source - Connection is not available, request timed out after 30001ms.
2023-03-15 19:21:13,982 ERROR [oncommand] [postHeadroomTask-0] [c.n.i.a.common.AnalysisService] Caught exception in performanceCollectionComplete for cluster 23932156 at Wed Mar 15 18:04:30 CET 2023
2023-03-15 19:21:14,046 ERROR [oncommand] [postHeadroomTask-0] [c.n.i.a.common.AnalysisService] org.springframework.jdbc.CannotGetJdbcConnectionException: Failed to obtain JDBC Connection; nested exception is java.sql.SQLTransientConnectionException: um-default-data-source - Connection is not available, request timed out after 30000ms.
at deployment.dfm-app.war//org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:82)
at deployment.dfm-app.war//org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:646)
at deployment.dfm-app.war//org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:713)
at deployment.dfm-app.war//org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:744)
at deployment.dfm-app.war//org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:757)
at deployment.dfm-app.war//org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:815)
New to NetApp?
