NetApp Knowledge Base
AIQUM DB backups not visible in GUI
203
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
DP
Last Updated:
Applies to
AIQUM
ONTAP 9
2025-05-26 00:00:00,169 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.impl.backup.BackupScheduleJob] Regular Backup Job triggered.2025-05-26 00:00:00,169 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.impl.backup.BackupScheduleJob] Regular Backup Job got permit and started.2025-05-26 00:00:00,174 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Verified that Mysql dumps repo path is valid and has proper permissions: /aiqum_dump_backup/ocum-backup/database-dumps-repo2025-05-26 00:00:00,174 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.dfm.impl.backup.BackupUtils] Created nested directory with effective path: /aiqum_dump_backup/ocum-backup/AIQ_UM_9.14_backup_unix2025-05-26 00:00:00,255 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Regular Backup Job: Incremental dump couldn't be taken, proceeding for full dump.2025-05-26 00:00:00,255 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Starting to take mysql dump2025-05-26 00:00:00,345 INFO  [oncommand] [task-scheduler-13] [eventPurgerJobGroup|eventPurgerJob] [c.n.d.core.event.purger.EventPurger] Purged 2 events (timestamp cutoff was 2024-11-26 23:00:00)2025-05-26 00:00:00,360 INFO  [oncommand] [task-scheduler-13] [eventPurgerJobGroup|eventPurgerJob] [c.n.d.core.event.purger.EventPurger] Purged 0 events (timestamp cutoff was 2024-11-26 23:00:00)2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Full Backup DB Dump Size: 16868818944 bytes2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Space needed for Backup: 20242582733 and Free space available in backup directory: 1409329643522025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.dfm.impl.backup.BackupUtils] Created nested directory with effective path: /aiqum_dump_backup/ocum-backup/AIQ_UM_9.14_backup_unix/database_dumps2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Created mysql dump Reference file: /aiqum_dump_backup/ocum-backup/AIQ_UM_9.14_backup_unix/database_dumps/ocum_mysql_full_backup_1748210400386.sql2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Created mysql dump file /aiqum_dump_backup/ocum-backup/database-dumps-repo/ocum_mysql_full_backup_1748210400386.sql2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Created mysql dump Reference file /aiqum_dump_backup/ocum-backup/AIQ_UM_9.14_backup_unix/database_dumps/ocum_mysql_full_backup_1748210400386.sql2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.backup.MysqlDumpOperation] Starting mysql full dump process2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.backup.MysqlDumpOperation] Locking the instance for backup2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.backup.MysqlDumpOperation] Instance is locked2025-05-26 00:00:00,386 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.backup.MysqlDumpOperation] Running command /usr/bin/mysqldump --login-path=jboss --ignore-table=ocum.managementstation --flush-logs --add-drop-table --routines --triggers --databases --single-transaction mysql management sanscreen acquisition ocum ocum_view ocum_report ocum_report_birt ocum_data_collector netapp_model_view netapp_model netapp_performance vmware_model_view vmware_model vmware_performance scalemonitor opm -r /aiqum_dump_backup/ocum-backup/database-dumps-repo/ocum_mysql_full_backup_1748210400386.sql by user jboss2025-05-26 01:21:02,333 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Created mysql dump compressed file: /aiqum_dump_backup/ocum-backup/database-dumps-repo/ocum_mysql_full_backup_1748210400386.sql.7z2025-05-26 01:21:02,918 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] After compression, deleted origional mysql dump file: /aiqum_dump_backup/ocum-backup/database-dumps-repo/ocum_mysql_full_backup_1748210400386.sql2025-05-26 01:21:02,921 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlBackupProperties] Successfully purged all rows of backup consolidation dumps from database.2025-05-26 01:21:02,955 ERROR [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.dfm.impl.backup.BackupUtils] Error occurred while copying files inside temporary directory in Backup pathjava.nio.file.AccessDeniedException: /opt/netapp/essentials/conf/server.properties_03_04_2025 at java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:90) at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111) at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:116) at java.base/sun.nio.fs.UnixCopyFile.copyFile(UnixCopyFile.java:235) at java.base/sun.nio.fs.UnixCopyFile.copy(UnixCopyFile.java:603) at java.base/sun.nio.fs.UnixFileSystemProvider.copy(UnixFileSystemProvider.java:258) at java.base/java.nio.file.Files.copy(Files.java:1295) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupDirCopier.visitFile(BackupDirCopier.java:94) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupDirCopier.visitFile(BackupDirCopier.java:23) at java.base/java.nio.file.Files.walkFileTree(Files.java:2725) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupUtils.copyToTempDirectory(BackupUtils.java:232) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupUtils.copyBackupMappingFiles(BackupUtils.java:297) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager.createBackupInTransaction(MySqlDumpBackupManager.java:384) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager.createMySqlBackup(MySqlDumpBackupManager.java:296) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager.createMySqlRegularBackup(MySqlDumpBackupManager.java:269) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager$$FastClassBySpringCGLIB$$b622c0d3.invoke(<generated>) at deployment.dfm-app.war//org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218) at deployment.dfm-app.war//org.springframework.aop.framework.CglibAopProxy.invokeMethod(CglibAopProxy.java:386) at deployment.dfm-app.war//org.springframework.aop.framework.CglibAopProxy.access$000(CglibAopProxy.java:85) at deployment.dfm-app.war//org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:704) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager$$EnhancerBySpringCGLIB$$dbb731e4.createMySqlRegularBackup(<generated>) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupManager.createBackup(BackupManager.java:37) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupScheduleJob.run(BackupScheduleJob.java:38) at deployment.dfm-app.war//com.netapp.dfm.core.scheduling.DelegatingJob.execute(DelegatingJob.java:53) at deployment.dfm-app.war//org.quartz.core.JobRunShell.run(JobRunShell.java:202) at deployment.dfm-app.war//org.springframework.scheduling.support.DelegatingErrorHandlingRunnable.run(DelegatingErrorHandlingRunnable.java:54) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) at java.base/java.lang.Thread.run(Thread.java:829)2025-05-26 01:21:02,987 INFO  [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.i.b.MySqlDumpBackupManager] Deleted BackupFileInfo entity in DB2025-05-26 01:21:03,013 ERROR [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.impl.backup.BackupScheduleJob] Error occurred in Regular Backup Job:com.netapp.dfm.impl.backup.BackupCreationException: The file or directory was not copied due to a file system error. at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupUtils.copyToTempDirectory(BackupUtils.java:261)2025-05-26 01:21:03,013 ERROR [oncommand] [task-scheduler-12] [Backup|ScheduleBackup] [c.n.d.impl.backup.BackupScheduleJob] Error occurred in Regular Backup Job:com.netapp.dfm.impl.backup.BackupCreationException: The file or directory was not copied due to a file system error. at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupUtils.copyToTempDirectory(BackupUtils.java:261) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupUtils.copyBackupMappingFiles(BackupUtils.java:297) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager.createBackupInTransaction(MySqlDumpBackupManager.java:384) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager.createMySqlBackup(MySqlDumpBackupManager.java:296) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager.createMySqlRegularBackup(MySqlDumpBackupManager.java:269) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager$$FastClassBySpringCGLIB$$b622c0d3.invoke(<generated>) at deployment.dfm-app.war//org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218) at deployment.dfm-app.war//org.springframework.aop.framework.CglibAopProxy.invokeMethod(CglibAopProxy.java:386) at deployment.dfm-app.war//org.springframework.aop.framework.CglibAopProxy.access$000(CglibAopProxy.java:85) at deployment.dfm-app.war//org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:704) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.MySqlDumpBackupManager$$EnhancerBySpringCGLIB$$dbb731e4.createMySqlRegularBackup(<generated>) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupManager.createBackup(BackupManager.java:37) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupScheduleJob.run(BackupScheduleJob.java:38) at deployment.dfm-app.war//com.netapp.dfm.core.scheduling.DelegatingJob.execute(DelegatingJob.java:53) at deployment.dfm-app.war//org.quartz.core.JobRunShell.run(JobRunShell.java:202) at deployment.dfm-app.war//org.springframework.scheduling.support.DelegatingErrorHandlingRunnable.run(DelegatingErrorHandlingRunnable.java:54) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) at java.base/java.lang.Thread.run(Thread.java:829)Caused by: java.nio.file.AccessDeniedException: /opt/netapp/essentials/conf/server.properties_03_04_2025 at java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:90) at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111) at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:116) at java.base/sun.nio.fs.UnixCopyFile.copyFile(UnixCopyFile.java:235) at java.base/sun.nio.fs.UnixCopyFile.copy(UnixCopyFile.java:603) at java.base/sun.nio.fs.UnixFileSystemProvider.copy(UnixFileSystemProvider.java:258) at java.base/java.nio.file.Files.copy(Files.java:1295) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupDirCopier.visitFile(BackupDirCopier.java:94) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupDirCopier.visitFile(BackupDirCopier.java:23) at java.base/java.nio.file.Files.walkFileTree(Files.java:2725) at deployment.dfm-app.war//com.netapp.dfm.impl.backup.BackupUtils.copyToTempDirectory(BackupUtils.java:232) ... 21 common frames omitted
New to NetApp?
