How to resolve memory issues with Active IQ Unified Manager
Applies to
- Active IQ Unified Manager (AIQUM)
- OnCommand Unified Manager (OCUM)
Answer
Determine the amount of reserved memory
Utilizing reserved memory should be full or none, as fractional reserves can cause issues
Check AIQUM memory recommendations
| Software Version | System Requirements |
Active IQ Unified Manager 9.6 and above |
VMware OVA - Virtual infrastructure or hardware system requirements |
| Microsoft Windows - Virtual infrastructure or hardware system requirements | |
| Red Hat and CentOS Linux - Virtual infrastructure or hardware system requirements | |
| OnCommand Unified Manager 9.5 and earlier | Virtual infrastructure or hardware system requirements |
Review best practice recommendations for sizing
- See page 10 - "Unified Manager scalability" in Active IQ Unified Manager: Best practices guide
- If you are more than halfway to the next tier, increase resources to the next tier to allow for growth.
i.e. If you have 30 nodes, increase memory from 12GB to 60GB - Alternately, add 1GB of memory for each node monitored in addition to the starting 12GB memory.
i.e. If you have 30 nodes, increase memory from 12GB to 42GB
Make memory adjustments as needed
- VMware Docs - Change the Memory Configuration
- VMware Docs - Allocate Memory Resources to a Virtual Machine in the VMware Host Client
Confirm that no ballooning or swapping is occurring on the virtual machine.
- VMware Docs - Memory (Data Counters)
- VMware Docs - Memory (MB)
Linux only - Linux may stop Unified Manager processes to free memory
- On Linux platforms, check for OOM "Out of Memory" killer ending processes to free up memory.
- In rare instances Red Hat and CentOS platforms kill Unified Manager services / processes to free up memory.
Dec 8 22:00:18 um-hostname kernel: Out of memory: Kill process 45678 (java) score 228 or sacrifice child
Dec 8 22:00:18 um-hostname kernel: Killed process 45988 (sh) total-vm:122868kB, anon-rss:260kB, file-rss:0kB, shmem-rss:0kB
Dec 8 22:00:19 um-hostname systemd: mysqld.service: main process exited, code=killed, status=9/KILL
Dec 8 22:00:19 um-hostname systemd: Unit mysqld.service entered failed state.
Dec 8 22:00:19 um-hostname systemd: mysqld.service failed.
Dec 8 22:00:20 um-hostname systemd: mysqld.service holdoff time over, scheduling restart.
Dec 8 22:00:20 um-hostname systemd: Stopped MySQL Server.
Dec 8 22:00:20 um-hostname systemd: Starting MySQL Server...
Additional Information
- Is it necessary to address the AIQUM server's memory usage if it is about 80 percent?
- Common memory issues include
- Unified Manager application is running slow:
- Services take a long time to come online.
- WebGUI is slow.
- Backups take a very long time ( and possibly fail ).
- Unified Manager application CPU and/or memory utilization are extremely high; swap / page file is in use.
- Unified Manager application experiences inconsistent behavior:
- Services hanging.
- Services restarting.
- Services not starting at all (especially after upgrade)
- Occasional issues with alert notifications.
- Inventory / performance acquisition polls may not complete within their normal 15 minute / 5 minute cycles.
- Other abnormal (unexplainable) inconsistent behavior when running in a virtual environment.
- VMware ESXi displays one or more of the following:
- Memory Ballooning
- Swapping
- Transparent Page Sharing
- Compression
- Scale Monitoring Messages
- "Unified Manager Server Low On Memory"
- Log indications:
- MySQL "
error.log" file:2020-04-12T04:02:10.036849Z 205 [Note] Aborted connection XXX to db: 'unconnected' user: 'jboss' host: 'localhost' (Failed on my_net_write())2020-04-12T08:50:42.808598Z 450 [Note] Got timeout reading communication packets
- Unified Manager "
server_mega.log" file:2020-04-12 06:11:01,221 ERROR [default task-4] c.n.s.s.a.OriginatorUpdateServlet (OriginatorUpdateServlet.java:82) - Transaction rolled back: javax.ejb.EJBTransactionRolledbackException: Transaction rolled back
- Unified Manager "
ocumserver.log" file:- 2019-06-06 02:49:49,566 INFO [oncommand] [pool-22-thread-4] [c.n.d.e.p.e.b.UnifiedManagerMemoryEventTypeController] Scale Monitor: New Memory Event Created: event id=128123,eventSeverity=low, thresholdValue=5.0, currentUsageValue=6.690000057220459, totalMemorySizeValue=1.365997568E10, jvm=AuJvm
2019-06-06 01:49:49,190 INFO [oncommand] [pool-22-thread-55] [c.n.d.e.p.e.b.UnifiedManagerMemoryEventTypeController] Scale Monitor: New Memory Event Created: event id=128094,eventSeverity=almostOut, thresholdValue=7.0, currentUsageValue=7.195000171661377, totalMemorySizeValue=1.365997568E10, jvm=AuJvm
- MySQL "
NOTE: This is not an exhaustive list of logs indicating memory issues. Please be aware that NetApp Support will find other log lines that can also indicate memory issues.
