NetApp Knowledge Base
What steps should be taken when changing password for cluster monitored by AIQUM?
84
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM)
  • ONTAP 9
  • Changing the cluster admin password entered on Cluster Setup in AIQUM Web UI
  • Monitoring the cluster from AIQUM is working properly
Answer
To ensure monitoring from AIQUM continues, perform the following steps:
  1. Run security certificate show -type server on the cluster to confirm Expiration Date for cluster SVM's server certificate
  2. If the cluster SVM's server certificate has expired, renew the certificate
    Note: Step 4 fails if the certificate has expired
  3. Run security login password to change the cluster admin password
  4. Enter the new password for the cluster admin from Edit Cluster on Cluster Setup in AIQUM Web UI
Additional Information
additionalInformation_text
