Vulnerable undertow version detected in AIQUM 9.13 and 9.14 causing high CPU and acquisition issue
Applies to
- Active IQ Unified Manager (AIQUM) 9.13, 9.14
- RHEL/OVA/Windows
- CVE-2023-3223 &
- CVE-2023-1108
Issue
- AIQUM is vulnerable to :
- Which causes the memory and CPU usage to continually increase after being scanned by vulnerability scanners like Qualys/Crowdstrike
- This can cause Almost out of memory event in Windows system.
Source: Resource-Exhaustion-Detector
Windows successfully diagnosed a low virtual memory condition.
The following programs consumed the most virtual memory: mysqld.exe (PID) consumed xxxx bytes, java.exe (PID) consumed xxx bytes, java.exe (PID) consumed xxx bytes.
- This can cause AIQUM service stop in Windows system.
Source: Service Control Manager
The NetApp Active IQ Management Server Service service entered the stopped state.
- HTTPS protocol communication from server monitoring system to AIQUM repeatedly goes down and comes back up
- High CPU usage presents:
- On Windows, OpenJDK Platform Binary process exhibits high CPU usage.
- On vApp,
jbossCPU usage keep increasing.
- As a side effect, inventory and performance collections start skipping due to previous collections becoming stuck and still considered running:
INFO [oncommand] [org.springframework.jms.listener.DefaultMessageListenerContainer#1-1] [com.netapp.ipc.jms.OCIE_Events] Ignoring notification : PACKAGE_SKIPPED for datasource xx.xx.xx.xx: another POLL already running- Performance graphs are not shown with Insufficient Historical Data.
- Gaps in the performance graphs.
- This situation occurs intermittently.
- The capacity data for aggregates or volumes have not been updated since a certain day
- AIQUM can send scheduled reports but the data in the reports have not been updated since a certain day
- TCP sessions are not cleared towards the application / server from vulnerability scanners:
- au.log shows warning:
Data source is already performing a poll of netappstorageperformance. Therefore this poll is skipped.
Failed to obtain reconciliation-processing lock for 0:10:00.000 for datasource
- ocumserver.log shows error:
Timeout occurred while waiting on collection completion listener ClusterSparesEventDetector..EnhancerBySpringCGLIB..abbaf0ec. Cancelling it so that others can continue- ERROR [oncommand] [reconciliation-0] [c.n.dfm.collector.OcieJmsListener] Ignoring PACKAGE_CHANGED at updateTime Tue <timestamp>, previous foundation poll at pollStartTime <timestamp> still being processed for ds=x(xxxxxx), adding to the droppedJmsDataSources list
ERROR [oncommand] [reconciliation-0] [c.n.dfm.collector.OcieJmsListener] Previous foundation poll at pollStartTime <timestamp> ongoing for ds=x(xxxxxx), adding to the droppedJmsDataSources list
Note: Even in environments where vulnerability scanners are not used, similar access patterns can cause this issue. Therefore, the absence of vulnerability scanners does not mean the environment is unaffected by this issue.
