NetApp Knowledge Base
Active IQ Unified Manager High CPU Usage - Resolution Guide
4,284
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM)
Answer
Getting Started
Note: When high CPU usage is observed, even if the environment is not experiencing any AIQUM software defects and the number of monitored nodes is below the maximum number of a tier in the resource recommendations table, adding CPU resources may be required, depending on the number of storage objects.
Common Issues
Symptom Solution
  • AIQUM becomes unresponsive
    • Exception occurred while detecting scale db pool issue: java.lang.NullPointerException: null
    •  ocum kernel: Rate limit exceeded
  • AIQUM reports AIQCASecure database lock
    • Collection from <ONTAP_IP>_<AIQUM>_202311251252.0.files Failed with error - database is locked
    • File "peewee.py", line 3237, in execute_sql sqlite3.OperationalError: database is locked
  • AIQUM server hangs when running on virtual machines
  • Vulnerability scanners can trigger high cpu and memory in Unified Manager 9.13 and 9.14
Additional Information
additionalInformation_text
