NetApp Knowledge Base
Ethernet Switch Health Monitor (CSHM) Alert Resolution Guide
28,341
Visibility:
Votes:
3
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Cluster, storage or MetroCluster IP Ethernet switches
  • Ethernet Switch Health Monitor (CSHM) AutoSupport message
Issue
  • Ethernet Switch Health Monitor (CSHM) AutoSupport message was triggered by an Ethernet switch error condition.
  • Active alerts can be displayed by running the command: system health alert show -monitor ethernet-switch
Cause
Monitoring the health of your system
  • Health monitors proactively monitor certain critical conditions in your ONTAP cluster and raise alerts if they detect a fault or risk.
  • If there are active alerts, the system health status reports a degraded status for the cluster.
  • The alerts include the information that you need to respond to degraded system health.
Solution
  1. Identify the Alert ID by running the command: system health alert show -monitor ethernet-switch -instance
Example
::> system health alert show -monitor ethernet-switch -instance
              Node: node1
          Alert ID: UnsupportedSwitch_Alert
 Alerting Resource: sw1(XXXXX)
          Severity: Major
   Indication Time: Wed Feb 25 21:27:48 2015
          Suppress: false
       Acknowledge: false
   Possible Effect: Communication problems and network connectivity issues occur.
        Corrective Actions: Unsupported Ethernet switch
                            "sw1(XXXXX)" found. Connect
                            a supported Ethernet switch to the network.
  1. Follow this guide to help you locate the proper solution to your question or issue related to an Ethernet Switch Health Monitor  (CSHM) Alert.
CSHM Alert Id Solution
ClusterSwitchConfig_Alert
ClusterSwitchMissing_Alert
ClusterIfIslDownWarn_Alert
SwitchCommunityString_Alert
SwitchIfIslDownWarn_Alert
SwitchIfOutErrorsWarn_Alert
SwitchIfInErrorsWarn_Alert
SwitchInfoUpdateFailure_Alert
SwitchLinkDiscoveryProtocol_Alert
SwitchFanFail_Alert
SwitchFanNotPresent_Alert
SwitchFanNotOperational_Alert
SwitchPsuFanNotOperational_Alert
SwitchPowerFail_Alert
SwitchPowerNotPresent_Alert
SwitchPowerNotOperational_Alert
SwitchSNMPCommunication_Alert
SwitchTemperatureWarn_Alert
SwitchTemperatureNotOperational_Alert
SwitchEndOfSupport_Alert
New to NetApp?
