ONTAP Hardware KBs
ONTAP Hardware KBs
Featured
Automatic Firmware download Feature
The Automatic Update feature allows ONTAP to automatically download and install recommended firmware
How to perform a health check
A Resolutiom guide of various methods to check the health of your system
Shutdown and Power up procedures
Best practices and procedures to perform a graceful shutdown and power up your ONTAP cluster
Controller hardware upgrade Resolution guide
This guide describes how to upgrade controller hardware of an AFF system or a FAS system in a cluster by moving storage or volumes
Service Processor (SP) & Baseboard Management Controller (BMC) Resolution Guide
Collection of solutions for your SP or BMC questions
DISK FAILED process
Provides guidance around the disk failure process
Other Resources
- "Active IQ Config Advisor Summary Report " reports "SAS Cabling checks"Apr, 2026
- Config Advisor giving cabling error, SAS Cabling checks due to a False errorApr, 2026
- Nodes fails to boot with Waiting for reservations to clearApr, 2026
- Node reboots due to "Power Fail" errorApr, 2026
- Disk auto-assign not working after disk replacementApr, 2026
- ONTAP Disk Ownership and Assignment – Resolution GuideApr, 2026
- Inlet ODP Temp sensor high thresholds are modifiedApr, 2026
- ONTAP AlphaUser Synced State showing SYNC FAILEDApr, 2026
- Chelsio T6 network card encounters fatal error and port has gone down unexpectedlyApr, 2026
- T6 cluster port hung leading to cluster network issuesApr, 2026
- Network ports reporting downApr, 2026
- disk reports not respondingApr, 2026
- How to determine a failed disk location based on disk id using HWUApr, 2026
- What is a Service Processor and how do I use it?Apr, 2026
- Single disk is missing from all paths on NS224 shelfApr, 2026
- IFGRP missing after NIC replacementApr, 2026
- How to update SP or BMC firmware using an FTP serverApr, 2026
- SP HBT MISSED triggers node down during firmware updateApr, 2026
- Is it allowed to mix of multiple capacities of the same drive type in internal shelfApr, 2026
- 2 ethernet ports of same IFGRP report link downApr, 2026
- How to power up all ONTAP nodes in a cluster following a graceful shutdown
- How to perform graceful shutdown and power up of all ONTAP nodes in a cluster
- BIOS updates for memory reliability and the PPR feature
- How to identify a failed disk prior to replacement
- How to manually download EMS log file via SPI?
- How to determine the disk and shelf firmware version on a controller and verify it is up to date
- Cluster hw_assist: hw_assist functionality is inactive - How to configure hw_assist
Highest rated
(rating)- Node reboots with NVDIMM in ERROR condition
- SwitchIfDead_Alert
- Newly installed controller only responsive via BMC prompt due to incorrect line voltage from PDU
- IO card is degraded IOXX X00G P1/P2 Temp is not readable due to unsupported SFP
- AFF-A1K Front LED panel not lit
- One node send "monitor.fan.failed" alert messages every hour.
- monitor.rtcLowPower or monitor.rtcHighPower occurs on Coin cell Real Time Clock (RTC) battery
- How To Safely Remove Disks from a NetApp System Running ONTAP 9
- boot_recovery procedure does not complete
- Can an existing aggregate be expanded with large HDDs after being converted from RAID‑DP to RAID‑TEC
- How to convert cluster ports from 4x10G to 1x40G
- Is ADP limited to the internal disk on the FAS2720?
- Node down due to "ADR event ID: 0" event
- Node fails to boot: Failed to get FRU data. Abort booting ONTAP due to MID1_FRU
- EMS reports ACP Processor error and SHELF_FAULT error
Recently updated
(date updated)- "Active IQ Config Advisor Summary Report " reports "SAS Cabling checks"
Recently added
(date created)- Inlet ODP Temp sensor high thresholds are modified
- Nvidia SN2100 lost management access after nv config save
- ONTAP switch SNMP monitoring fails after reboot/takeover with SwitchSNMPCommunication_Alert and SwitchInfoUpdateFailure_Alert
- Cluster join fails due with cluster ports online
- HIC1 Type sensor is showing as faulty on HA pair nodes
- AFF A250 node doesn't come back online during ONTAP upgrade
- Ontap generate CHASSIS POWER DEGRADED but from BMC all normal
- After motherboard replacement, giveback is vetoed by fabric pools
- ONTAP upgrade stops due to PCIe device missing on AFF A90
- Persistent SCSI Recovered Errors on multiple drives
- CriticalCECCCountMemErrAlert and BootDimmDisableAlert in observed in AFF A1K
- Is it Safe to Disregard “Very Low Memory” Alerts on FAS2720 After Upgrading to ONTAP 9.16.1P11?
- AFF-A30 fails to boot with - IPMI:Read controller FRU common header:failed
- Intermittent BMC ping loss on both nodes
