NetApp Knowledge Base
AFF A400/FAS8300/FAS8700 shuts down with nvmem.battery.noCharge alert
61,702
Visibility:
Votes:
4
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • AFF A400
  • AFF C400
  • ASA A400
  • ASA C400
  • FAS8300
  • FAS8700
Issue
  • Unexpected node shutdown
Console Logs
  • Console messages when booting:
 WARNING:  The battery is experiencing a critical failure:
      - Battery is not present
     Without a working battery, the system cannot retain data
     during a power outage, which can result in data loss.
     Power down the system and verify that the battery is
     properly installed.
     To ignore this failure and boot the system in a mode
     where data loss might occur, press 'c' followed by 'Enter'
EMS Logs
  • Either error are reported prior to node shutdown. Examples:
    • NVMEM battery is requesting to be charged
[node_name: env_mgr: nvmem.battery.noCharge:alert]: The NVMEM battery is requesting to be charged but the charger is not charging the battery. To prevent data loss, the system will shut down in 20 minutes.
[node_name: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL.
[node_name: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery not charging)
[node_name: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery charging current failed)
<callhome_battery_failure_1
        subject="BATTERY (current high)"/>
<monitor_shutdown_emergency_1
        reason="Environmental Reason Shutdown (Battery current critical)"
  • NVMEM battery is not present
[node_name:callhome.battery. failure: EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
[node_name: env_mgr: nvmem.battery.notPresent:alert]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
  • NVRAM battery is dangerously low
[node_name: statd: monitor.nvramLowBattery:EMERGENCY]: NVRAM battery is dangerously low.
  • NVRAM battery is capacity low
[node_name: env_mgr: nvmem.battery.capLow:alert]: The NVMEM battery capacity is low (2 cycles).
  • Following AutoSupport subject message is reported:
HA Group Notification from node_name (BATTERY (no charge)) EMERGENCY or
HA Group Notification (BATTERY (no charge)) EMERGENCY
  • Partner performs a takeover:
[node_name: cf_main: cf.fsm.firmwareStatus:info]: Failover monitor: partner Halted
[node_name: cf_main: cf.fsm.takeover.on.halt:info]: Failover monitor: Node initiated automatic takeover after detecting that its partner node has halted.
To confirm the issue, use one of the following methods:
BMC prompt
  1. Execute the following command:
BMC node_name> system battery show
  1. In the results confirm the following:
    1. Current field shows "0 mA".
    2. RelativeCharge field show below 71%.
    3. ChargingCurrent field shows "1000 mA".
AutoSupport logs
  1. Open the AutoSupport titled "BATTERY (no charge)".
  2. Navigate to the SP-LATEST-STATISTICS section.
  3. In the output confirm the following:
    1. Log Collection Time shows the current date (if it does not show the current date/time, do not use AutoSupport section SP-LATEST-STATISTICS to verify).
    2. Current field shows "0 mA".
    3. RelativeCharge field show below 71%.
    4. ChargingCurrent field shows "1000 mA".
  4. Navigate to the PLATFORM-SENSORS.XML section.
  5. In the output confirm one or more of the following show as failed or fault:
    1. DBlade Battery Voltage
    2. Battery Charge Failed?
    3. Battery Charge
    4. Bat Charging State
New to NetApp?
