NetApp Knowledge Base
How to troubleshoot PCI/NMI, UMCE, and nested machine check exception panics
11,940
Visibility:
Votes:
3
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • PCI Non-Maskable Interrupt (NMI) panics
  • PCI Uncorrectable Machine Check Exception (UMCE) panics
  • non-PCI Uncorrectable Machine Check Exception (UMCE) panics
  • Nested machine check exception panics
  • AFF Systems
  • FAS Systems
UMCE stands for Uncorrectable Machine Check Error. It is a type of error that occurs in a system's CPU or memory that cannot be automatically corrected by using the various correction algorithms available in OS and BIOS.
 These errors are often related to issues in the CPU, memory, or other critical components of the system and may cause the system to crash or reboot unexpectedly.
This article describes how to troubleshoot the following types of panic:
Panic message can be found in Ontap event logs as below or in SP/BMC "system log" command output.
event log show -severity * -message-name panic*
Panic Types:
  1. PCI/NMI
PANIC: PCI Error NMI from device(s):PCI Device 111d:806c in slot 2 on Controller, Qlogic FC 8G adapter in slot 2 on Controller, Qlogic FC 8G adapter in slot 2 on Controller. in process idle on release 8.3 (C) on Fri Sep 18 13:27:47 MDT 2015
  1. PCI UMCE
  • Refers to an unrecoverable issue found on the PCI bus.
PANIC: Uncorrectable Machine Check Error at CPU30. SKL_IIO Error: STATUS<0xbb80000000000e0b>(VALID,UC,EN,MISCV,PCC,S,AR,CORR_ERR_STATUS(0),CORR_ERR_CNT(0),MSCOD(0),MCACOD(0xe0b))MISC<0x00000000ae000000>(UCR_BUS_LOG(174),UCR_DEVICE_LOG(0),UCR_FUNCTION_LOG(0),UCR_SEGMENT_LOG(0))IIO Machine Check from device(s):RPT(174,0,0):ErrSrcID(CorrSrc(0),UCorrSrc(0xb100)), PLX PCIE 8749 switch on Controller, PCI Device 1425:600d in slot 1 on Controller, PCI Device 1425:600d in slot 1 on Controller, PCI Device 1425:600d in slot 1 on Controller, PCI Device 1425:600d in slot 1 on Controller, T62100-CR Dual 40/100G NIC in slot 1 on Controller, PCI Device 1425:650d in slot 1 on Controller, PCI Device 1425:660d in slot 1 on Controller.  in process idle: cpu30
  1. non-PCI UMCE
  • Refers to an unrecoverable operation on the system memory or CPU cache.
PANIC: Uncorrectable Machine Check Error at CPU0. MC0 Error: STATUS<0xb200000430000800>(Val,UnCor,Enable,PCC,ErrCode(Src,NTO,Gen,Mem,L0)). MC5 Error: STATUS<0xf2000010c4300e0f>(Val,OverF,UnCor,Enable,PCC,ErrCode(Gen,NTO,Gen,Gen,Gen)); Uncorrectable error at DIMM-1, Channel 0, Serial: BA-00-1131-00098398!69002460-I01-NTA-T1?!, FERR(0x400), NERR(0x402), MERR M10Err, Rank 3, Bank 6, CAS 0x1e8, RAS 0x1bcf Uncorrectable error at DIMM-1, Channel 0, Serial: BA-00-1131-00098398!69002460-I01-NTA-T1?!, MERR M10Err, Rank 3, Bank 6, CAS 0x1e8, RAS 0x1bc.
  1. Nested Machine check
PANIC: nested machine check exception detected on CPU #, no coredump will be generated.
New to NetApp?
