NetApp Knowledge Base
What is a Baseboard Management Controller (BMC) and how do I use it?
40,385
Visibility:
Votes:
22
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Baseboard Management Controller (BMC)
  • AFF A50, AFF A30, AFF A20, AFF C60, AFF C30, ASA A50, ASA A30, ASA A20, FAS50
  • AFF A1K, AFF A90, AFF A70, AFF C80, ASA A1K, ASA A90, ASA A70, FAS90, FAS70
  • FAS2820
  • AFF A900, ASA A900, FAS9500
  • AFF A250, AFF C250, ASA A250, ASA C250, FAS500f
  • AFF A400, AFF C400, ASA A400, ASA C400, FAS8300, FAS8700
  • AFF A320
  • AFF A220, AFF A150, AFF C190, ASA A150, FAS2720, FAS2750
  • AFF A800, AFF C800, ASA A800, ASA C800
  • AFF A700s
Answer
The Baseboard Management Controller (BMC) is a remote management device that enables you to access, monitor, and troubleshoot a node remotely.
The key capabilities of the BMC  include the following:
  • Remotely diagnose, shut down, power-cycle, or reboot the node, regardless of the state of the node controller.
  • BMC monitors environmental sensors and logs events to help you take timely and effective service actions.
  • Extends AutoSupport by sending additional system event alerts to ONTAP.
  • The BMC is powered by a standby voltage, which is available as long as the node has input power from at least one of its power supplies.
    • It remains available even when the node is power-cycled or turned off.
    • You can still gather command output from the BMC using the console port and pressing Ctrl+G.
  • The console log itself is not committed to disk, but remains in memory buffer even if the storage system is reinitialized.
    • Due to limited buffer space, the system log will be overwritten on an as-needed basis in order to accommodate the latest events.
Note: Refer to the Docs page   About the Baseboard Management Controller  for more  capabilities
List of common activities
AFF A400, AFF C400, FAS8700, FAS8300 specific
  • For AFF A400, AFF C400, FAS8700, FAS8300 systems, to return to the BMC prompt, you will need to use 'Esc-T' and not 'Ctrl-D', as is typical with SP and BMC
  • To get to the BMC prompt from the console port, use 'Ctrl-G'
AFF A700s specific
  • The BMC prompt on this platform is: admin@BMC01:~$
  • For AFF A700s systems, to return to the BMC prompt, you will need to use 'Esc-T' and not 'Ctrl-D', as is typical with SP and BMC
Note: On AFF A700s, AFF A800 and AFF C800, the BMC has its own separate Ethernet interface. It does not share a "wrench" port with the e0M port used by ONTAP.
