ONTAP Hardware KBs
ONTAP Hardware KBs
Featured
Automatic Firmware download Feature
The Automatic Update feature allows ONTAP to automatically download and install recommended firmware
How to perform a health check
A Resolutiom guide of various methods to check the health of your system
Shutdown and Power up procedures
Best practices and procedures to perform a graceful shutdown and power up your ONTAP cluster
Controller hardware upgrade Resolution guide
This guide describes how to upgrade controller hardware of an AFF system or a FAS system in a cluster by moving storage or volumes
Service Processor (SP) & Baseboard Management Controller (BMC) Resolution Guide
Collection of solutions for your SP or BMC questions
DISK FAILED process
Provides guidance around the disk failure process
Other Resources
- Multiple disks are in unknown statusMar, 2026
- Upgrading BMC firmware to 19.3 might fail to update battery firmware versionMar, 2026
- Environmental Shutdown (nvmem.battery.capLowCrit)Mar, 2026
- Node reboots with BATTERY remain capacity critical low alertMar, 2026
- AFF-A400: Repeated unexpected takeoversMar, 2026
- How to capture log bundle for Nvidia Cumulus SN2100 switchMar, 2026
- After node reboots, LACP ports are down and switch ports are in 'Link Flap error-disable' stateMar, 2026
- Ethernet port down to Cisco switch after ONTAP reboot, link disabled due to flappingMar, 2026
- Panic string: User initiated "system core" nmi when user did not initiate system coreMar, 2026
- Attempts to modify on-access policy filter fail with "Error: command failed: Cannot modify a policy on an administrative Vserver"Mar, 2026
- Errors on All HA Mailbox Disks After Adding Disks to NS224Mar, 2026
- DS460 Drawer Critical/Critical state and offline aggregates on FAS8300Mar, 2026
- Multiple Disks Report “Bad Label” After Adding New Shelf – ONTAP FAS/AFF SystemsMar, 2026
- Frequent drive failures on a ShelfMar, 2026
- Storage failover interconnect error due to wrong cablingMar, 2026
- Active IQ digital Advisor (Wellness Risk) Disk FW upgradeMar, 2026
- Unexpected [BMC.emergency]: System input power lostMar, 2026
- "cf.disk.skipped" Message Appears After Disk Sanitization in ONTAPMar, 2026
- Automatic FW updates not working due to failed downloadsMar, 2026
- SP HBT STOPPED on A900 / FAS9500 - Unresponsive NodeMar, 2026
- How to power up all ONTAP nodes in a cluster following a graceful shutdown
- How to perform graceful shutdown and power up of all ONTAP nodes in a cluster
- BIOS updates for memory reliability and the PPR feature
- How to identify a failed disk prior to replacement
- How to manually download EMS log file via SPI?
- How to determine the disk and shelf firmware version on a controller and verify it is up to date
- Cluster hw_assist: hw_assist functionality is inactive - How to configure hw_assist
Highest rated
(rating)- AFF-A1K Front LED panel not lit
- boot_recovery procedure does not complete
- How to convert cluster ports from 4x10G to 1x40G
- Node perform takeover/giveback automatically due to DIMM UECC error
- SwitchIfDead_Alert
- How To Safely Remove Disks from a NetApp System Running ONTAP 9
- Node fails to boot: Failed to get FRU data. Abort booting ONTAP due to MID1_FRU
- Node reboots with NVDIMM in ERROR condition
- IO card is degraded IOXX X00G P1/P2 Temp is not readable due to unsupported SFP
- Is ADP limited to the internal disk on the FAS2720?
- monitor.rtcLowPower or monitor.rtcHighPower occurs on Coin cell Real Time Clock (RTC) battery
- EMS reports ACP Processor error and SHELF_FAULT error
- AFF C800 Console access not working through RJ45 port, Micro USB port works
- Newly installed controller only responsive via BMC prompt due to incorrect line voltage from PDU
- How to convert existing 10G or 25G cluster ports to 40G or 100G cluster ports
Recently updated
(date updated)- Multiple disks are in unknown status
Recently added
(date created)- Upgrading BMC firmware to 19.3 might fail to update battery firmware version
- During an ONTAP upgrade, is there a risk of losing uncommitted data if an NVRAM failure occurs?
- How to get sysconfig -ac output from ONTAP clustershell
- How to identify an Ethernet adapter in an ONTAP system
- I/O for disk has been suspended 1 times for x seconds
- Unable to access BMC on AFF-C800
- Service Processor is not reachable due to sp.dup.ip:error SP IP address in use by another system
- AFF-C250 Node Down Due to PCM Failure
- SAS Host Adapter 0a Offline
