Virtual Storage Console
Other Resources
- OTV 9.13 An error occurred while adding a Storage System. Failed with a status code: 409Fri, 12 Apr 2024
- ONTAP Tools for VMware vSphere: Mutual authentication error when adding storage system to OTV 9.13P1Wed, 03 Apr 2024
- Error Invalid ISO while upgrading ONTAP tools for VMware vSphereWed, 03 Apr 2024
- OTV 9.13 The specified Name or IP Address is incorrect when adding storage systemWed, 27 Mar 2024
- vSphere shows higher volume usage than ONTAPTue, 26 Mar 2024
- OTV: Unable to upgrade to OTV 9.13P1Mon, 25 Mar 2024
- ONTAP Tools for VMware vSphere: HTTP ERROR 503 Service Unavailable when exporting OTV logsWed, 20 Mar 2024
- OTV fails to resize SMBC protected volumesWed, 20 Mar 2024
- What to check if OTV is unresponsive state?Tue, 19 Mar 2024
- VMware VMs fail to complete VM disk consolidation in NFS datastoreTue, 19 Mar 2024
- Error occurred while updating storage system and provisioning setting detailsTue, 19 Mar 2024
- ONTAP Tools for VMware vSphere: OTV not reporting Storage Details when in VCF modeMon, 18 Mar 2024
- Uninstalling the NFS plugin for VMware VAAI fails with error "Failed to unmount tarddiskntap"Wed, 13 Mar 2024
- Upgrade from 9.10 to 9.13P1 Build 9816 resulted in Error account validation failureWed, 13 Mar 2024
- ONTAP Tools for VMware vSphere: 9.13P1 upgrade fails with 'grub_disk_native_sectors' not found errorWed, 13 Mar 2024
- ONTAP Tools for VMware vSphere: How to confirm what type of certificates are used by OTVTue, 12 Mar 2024
- Does ONTAP tools boot up when the DNS server is down?Fri, 08 Mar 2024
- Unable to deploy OTV plugin Connect timeout 9.12Thu, 07 Mar 2024
- How to tune memory settings of OTV/VSC for scale and performance 9.12 and aboveWed, 06 Mar 2024
- OTV: Read error during storage discovery using a Discovery privilege userMon, 04 Mar 2024
- Datastores are not populating and right click on OTV tools all options greyed outThu, 18 Apr 2024
- OTV The specified Name or IP Address is incorrect when adding storage systemThu, 18 Apr 2024
- Changing vCenter User For OTVThu, 18 Apr 2024
- ONTAP Tools for VMware vSphere: How to import a certificate chain into OTV when CA certificates are not used for OTVTue, 16 Apr 2024
- OTV 9.13 An error occurred while adding a Storage System. Failed with a status code: 409Mon, 15 Apr 2024
- VMware VMs fail to complete VM disk consolidation in NFS datastoreMon, 15 Apr 2024
- OTV: Services do not start after appliance reboot of upgrade 9.13Fri, 12 Apr 2024
- ONTAP Tools: How to collect a packet trace from OTVThu, 11 Apr 2024
- OTV 9.13 The specified Name or IP Address is incorrect when adding storage systemWed, 10 Apr 2024
- ONTAP Tools for VMware vSphere: Implementing CA signed certificates for 9.12 and newerTue, 09 Apr 2024
- VSC/OTV there are no storage system that match with the selected SCPMon, 08 Apr 2024
- ONTAP Tools for VMware vSphere: 9.13P1 upgrade fails with 'grub_disk_native_sectors' not found errorMon, 08 Apr 2024
- OTV: VASA and SRA operations are slow or unresponsiveFri, 05 Apr 2024
- OTV 9.12 Datastore creation limited on FAS systems to 16TBThu, 04 Apr 2024
- ONTAP Tools for VMware vSphere: How to disable automatic discoveryThu, 04 Apr 2024
- ONTAP Tools for VMware vSphere: How to confirm what type of certificates are used by OTVWed, 03 Apr 2024
- ONTAP Tools for VMware vSphere: 9.12 release does not use the correct certificateWed, 27 Mar 2024
- How to tune memory settings of OTV/VSC for scale and performance 9.12 and aboveWed, 27 Mar 2024
Highest rated
(rating)- ONTAP tools for VMWare vSphere (VSC) - CVE-2021-44228 Apache Log4j Vulnerability - Workaround
- ONTAP Tools for VMware vSphere (OTV): How to Register/Change Password OTV 9.12+ with vCenter
- Cannot select thick provision disks when creating or editing VMDKs from vCenter Server
- OTV: Error 'Node Mgmt LIF IP Address' when adding a storage
- ONTAP Tools: VSC in-place upgrading failure due to tcpdump package update error
- ONTAP Tools for VMware vSphere: RBAC Configuration
- Virtual Storage Console(VSC): Scaling for larger environments
- Importing CA-signed certificate in VSC fails for IPv6
- OTV VASA PROVIDER: CPU 100 percent utilization
- OTV fails to provision NFS datastore at both ESXi host and cluster level
- What is a VAAI primitive and what are its limitations?
- Virtual Storage Console (VSC) The matching datastore for the specified host could not be found
- How to configure VMware vSphere 4.x with Data ONTAP 8.x
Recently updated
(date updated)- Datastores are not populating and right click on OTV tools all options greyed out
Recently added
(date created)- OTV 9.13 An error occurred while adding a Storage System. Failed with a status code: 409
