NetApp HCI Hardware
NetApp HCI Hardware
Other Resources
- NDE Scale keeps going back to the vCenter credentials pageMar, 2026
- Multiple H410 nodes down Block Service Unhealthy and Amber light on due to over temperature eventJan, 2026
- HCI compute node vmnic port down due to SFP failureJan, 2026
- Network uplink redundancy lost on vmnic5 is detected from vCenter alarmOct, 2025
- Volumes are offlineOct, 2025
- Which file should be checked to verify SEL on HCI compute nodes for health check?Sep, 2025
- Nagios or PRTG reports intermittent network connectivity issuesSep, 2025
- HCI node has red LED due to bad slot in chassisMay, 2025
- HCI Compute 6 hardware related RTFI_HARDWARE_FAILURESMay, 2025
- How many power supplies does H410 series need to operate during a partial outage?May, 2025
- BMC UI not accessible for H610S storage nodeApr, 2025
- Incorrect bond port counts detected on the sipi alert due to I/O error on NVIDIA Mellanox SN2010Apr, 2025
- H410 Power Supply Failure detected and amber light on due to faulty 2U H-series chassis slotMar, 2025
- Storage node without metadata driveMar, 2025
- H410C suddenly stops and IPMI shows "Performing power action failed. Please check."Feb, 2025
- CMCE Makes System Status LED on H610S Blink Amber w/o Causing a RebootFeb, 2025
- Node can't boot up during the upgrade of compute firmware 2.179.0Jan, 2025
- Does NetApp HCI use CIM when collecting hardware information from ESXi?Dec, 2024
- ActiveIQ reports powerSupplyErrorDec, 2024
- How to enable auto power on after node encountered a power outageNov, 2024
- HCI compute node keeps rebooting due to incorrect boot sequenceApr, 2026
- PANIC bora/vmkernel/main/dlmalloc.c:4924 - Usage error in dlmalloc on H410CApr, 2026
- How to disable SSDP protocol from running on H610-series and StorageGRID appliancesMar, 2026
- How to install SSL Certificate on NetApp HCI's BMCFeb, 2026
- H610S node offline Volt_CPU1_ABC Voltage Lower CriticalNov, 2025
- H410S - all block drives simultaneously marked as AvailableNov, 2025
- BMC/IPMI not accessible after being set or an upgrade or power drainNov, 2025
- RTFI failed with error "Cannot find valid solidfire install image"Oct, 2025
- NetApp SolidFire node crashedSep, 2025
- NetApp H610S node reboots unexpectedly with uncorrectable machine check errorSep, 2025
- H610S NVRAM device problems detected, metadata drive will be removedAug, 2025
- Memory DIMM with Uncorrectable ECC on HCI compute nodeJul, 2025
- Serial number of H-Series node reverts to HMxxxxxxx after RTFI or firmware updateJul, 2025
