SFP Resolution guide
- 9,047
- Visibility:
- Public
- Votes:
- 2
- Category:
- fas-systems
- Specialty:
- hw
- Last Updated:
- 11/15/2024, 3:36:36 PM
Applies to
- Small form-factor pluggable (SFP)
- Brocade switches
- Cisco switches
- AFF
- FAS
- E-Series
Answer
This article contains Solution and How-to KBs for SFP issues.
The article describes how to interpret the level of optical signal strength of the SFP for Brocade FC switches | Normal range of SFP optical power level for brocade |
The article describes how to interpret the level of optical signal strength of the SFP | SFP power value close to lower limit on storage |
The article describes the scenario when the SFP with the weak optical signal causes loss of access to LUNs intermittently | Host lost access to LUNs due to faulty SFP |
The article provides troubleshooting steps of a switch port with no light from SFP | No light from SFP |
The article provides steps to troubleshoot and identify faulty SFP or cable in Cisco FC switches. | Bad SFPs in Cisco switches |
The article describes the scenario when 10G/25G onboard port not reading SFP information | SFP info not available on AFF array |
The article describes how to interpret porterrshow output from a Brocade switch | What is the information given from a portErrShow output on a Brocade switch? |
The article provides a cross-reference table for SFP+ copper ethernet cables and corresponding NetApp part numbers | How to determine the NetApp part number for SFP+ Ethernet cables |
This article describes the procedure to determine the NetApp part number for Brocade switches | How to determine the NetApp part number for Brocade and NetApp SFPs |
The article describes how to determine faulty cable and/or SFP in Brocade switch | How to determine whether the SFP or Cable is faulty on a Brocade switch |
The article provides steps on how to monitor Brocade SFPs for hardware failures using MAPS | How to monitor Brocade 16GB and 32GB SFPs for any hardware failures using MAPS |
The article describes sfpshow command to determine and troubleshoot an SFP in Brocade switch | How to utilize the 'sfpshow' output of a Brocade Switch to determine if an SFP is faulty |
The article describes the procedure to find the correct part number of the SFP for replacement in an E-Series system | How to order the correct replacement part for a failed SFP |
The article describes how to use a command or AutoSupport for viewing optical power on Ethernet SFPs | How to view SFP optical power for Ethernet connections |
This article describes how to troubleshoot laser faults on Brocade switches | Brocade SFP reports Laser_Flt error due to faulty switch end sfp |
Additional Information
N/A
