Virtual Storage Console
Other Resources
- What is the IP address (10.42.0.0 and 10.43.0.0) seen on ONTAP Tools for VMware vSphere 10.x?Sun, 22 Nov 2026
- DNS mapping guidance for OTV 10.x single-node deploymentFri, 20 Nov 2026
- Certificate validation error when adding ONTAP storage backend in OTVThu, 19 Nov 2026
- ONTAP Tools for VMware vSphere (OTV) Manager Login Failure Due to Vault Service TimeoutSun, 15 Nov 2026
- Intermittent VMware Storage vMotion FailuresTue, 10 Nov 2026
- ONTAP Tools for VMware vSphere 10.6 reports "invalid IP address" when adding vCenterMon, 09 Nov 2026
- How To Collect OTV Logs for Pre and Post Deployment and Upgrade IssuesThu, 05 Nov 2026
- ONTAP Tools for VMware vSphere: Storage Backends Not Visible Across vCenters in Enhanced Linked Mode After UpgradeFri, 30 Oct 2026
- Unable to provision datastores or see available ONTAP Aggregates in ONTAP Tools provisioning wizardTue, 27 Oct 2026
- ONTAP Tools deployment fails with deployment error 04055 registry deployment failureMon, 26 Oct 2026
- ONTAP Tools (OTV 10) : How to apply recommended host settings using Swagger UIFri, 23 Oct 2026
- ONTAP Tools (OTV 10) : How to add storage using Swagger UIThu, 22 Oct 2026
- Adding storage, applying host settings or resize datastore in OTV 10 is forbiddenThu, 15 Oct 2026
- SRA Registration Fails with “401 Unauthorized” After RKE2 Certificate Expiration on OTV ApplianceTue, 13 Oct 2026
- ONTAP Tools 10: Customer issued namespace unmap leads to possible metadata corruptionMon, 12 Oct 2026
- ONTAP Tools storage backend not visible after vCenter certificate renewalTue, 29 Sep 2026
- OTV 10 deployment fails with error code 04108 resulting in inability to add storage backendTue, 29 Sep 2026
- ONTAP Tools: How to collect a failing task job ID JSON log fileFri, 25 Sep 2026
- ONTAP Tools OVA deployment fails with RKE2 server has failed as the node IP has changed errorFri, 25 Sep 2026
- OTV 10.x SRM Test Failover Fails with “Failed to create snapshots of replica devices” Due to igroup OS Type Mismatch on NetApp ONTAPWed, 23 Sep 2026
- OTV: Storage system shows 'Client Certificate Expired'Mon, 16 Nov 2026
- Verifying if the currently installed OTV version is up to dateTue, 03 Nov 2026
- ONTAP Tools (OTV 10) : How to add storage using Swagger UIMon, 26 Oct 2026
- OTV: "Authentication failed" alerts seen in ONTAP audit logs after storage credentials changeMon, 26 Oct 2026
- ONTAP Tools: OTV 10 Deployment fails with RKE2 Server ErrorMon, 26 Oct 2026
- Adding storage, applying host settings or resize datastore in OTV 10 is forbiddenFri, 23 Oct 2026
- Storage backend is already on boarded from global scope on OTV 10 PluginFri, 23 Oct 2026
- SRA command discoverArrays failed and Device is not mapped error when using NVMe/FC with OTV 10.xWed, 21 Oct 2026
- ONTAP Tools for VMware vSphere OVA deployment stalls or fails at 44 or 60 percent in vCenterWed, 21 Oct 2026
Highest rated
(rating)- VVOL Datastore displays "vSphere HA failed to create a configuration vVol for this datastore" alarm
- Error while loading Storage Virtual Machine information for controller ID
- ONTAP Tools for VMware vSphere: 'No Controller found for controller id' error when adding storage system to OTV
- ONTAP Tools (OTV) The matching datastore for the specified host could not be found
- ONTAP Tools: Error 'No Controller found for controller id' when adding vserver to OTV
- FlexGroup volume creation fails with OTV for FabricPool-enabled aggregates
- ONTAP Tools for VMware vSphere: 9.13P1 upgrade fails with 'grub_disk_native_sectors' not found error
- Autogrow increased size for ONTAP NFS volume is not immediately represented in vSphere datastore
- ONTAP Tools: VSC in-place upgrading failure due to tcpdump package update error
- OTV VASA PROVIDER: CPU 100 percent utilization
- How to configure VMware vSphere 4.x with Data ONTAP 8.x
- Unable to create Virtual Machine inside VVOL Container
- ONTAP Tools for VMware vSphere: How to import CA signed certificates from ONTAP into OTV when OTV doesn't use CA signed certificates
- ONTAP Tools for VMware vSphere: Sizing Guide for ONTAP tools for VMware vSphere 9.x
- OTV Datastores Are Not Populating and Right-click on OTV Tools All Options Greyed-out
Recently updated
(date updated)- What is the IP address (10.42.0.0 and 10.43.0.0) seen on ONTAP Tools for VMware vSphere 10.x?
Recently added
(date created)- What is the IP address (10.42.0.0 and 10.43.0.0) seen on ONTAP Tools for VMware vSphere 10.x?
