E-series Hardware KBs
Featured
Power cycle Guide
How to power off & on your E-Series system.
Drive status & failures
Collection of drive failures and statuses.
Single degraded drive
Degraded drive channel on single drive.
Cache backup device failure
Cache backup device end of life for controller.
Controller offline
How to diagnose offline E-Series controller?
E5700 Management Task failures
Management task failures with 422 web server error.
Other Resources
- Is preventive replacement recommended for an E-Series drive experiencing intermittent controller-side timeouts?Thu, 24 Sep 2026
- E-Series - Does disk pool space warning block planned drive firmware upgradeFri, 18 Sep 2026
- E4024 all power canister fans fail and temperature sensor unknownTue, 08 Sep 2026
- E-Series volume reconstruction stuck due to URS and DA errorsWed, 02 Sep 2026
- E-Series NVME drive bypassed after drive replacementWed, 19 Aug 2026
- Session terminated unexpectedly errors on E-Series arrays using infini bandMon, 10 Aug 2026
- How to replace an E-Series NE224 controller shelfFri, 07 Aug 2026
- Can a replacement E-series IOM with newer firmware automatically downgrade to the original system firmware revision?Thu, 06 Aug 2026
- Does NetApp E-Series 2800 support static routes on storage controllers?Wed, 05 Aug 2026
- E-series controller rebooted multiple times due to PCI SERR error on the NICsTue, 04 Aug 2026
- SuperPod EF Series during replacement reports I2C busy needs recoveryMon, 27 Jul 2026
- E-Series Storage Reporting Drawer and SAS Port Degradation AlertTue, 21 Jul 2026
- StorageGRID diskpool failure unrecoverable due to incorrect drive replacements on E-SeriesThu, 16 Jul 2026
- Multiple drawers degraded on the same shelf with a bypassed driveThu, 16 Jul 2026
- What does E-X4141B drive's CAPABILITIES field display in Storage Array Profile?Tue, 14 Jul 2026
- Nominal temperature exceeded alert on E-Series (E4024) due to ambient sensor faultFri, 10 Jul 2026
- E-Series “Write-back caching forcibly disabled” (BAD BBU)Tue, 07 Jul 2026
- E28xx Cache Backup Device Status Failed and async failed after replacementSun, 05 Jul 2026
- E-Series power supply with no power input and fans failed after chassis replacementThu, 02 Jul 2026
- E-Series Drive reports UnresponsiveThu, 02 Jul 2026
- E-Series controller in lockdown state OE Lt after encountering configuration issues during startupThu, 01 Oct 2026
- How many disk failures can be tolerated during volume reconstruction in E-Series DDP?Tue, 29 Sep 2026
- Is preventive replacement recommended for an E-Series drive experiencing intermittent controller-side timeouts?Tue, 29 Sep 2026
- Does NetApp E-Series 2800 support static routes on storage controllers?Mon, 28 Sep 2026
- E-Series drive port bypassed and redundancy lost reported for a single driveFri, 25 Sep 2026
- E-Series EF300/ EF600 reports ALT_COMM_LINK_ERROR-Recovery Failure Type Code: 504Fri, 25 Sep 2026
- E-Series controller does not boot after NVSRAM upgrade with 0E LU 7-Segment codeThu, 24 Sep 2026
- E-Series controller in lockdown state OE LF due to controller firmware mismatchMon, 21 Sep 2026
- Unreadable sectors on the E-series platforms on multiple drivesFri, 18 Sep 2026
- E-SEries EF300/600 controller offline with 0EL3 hardware errorThu, 17 Sep 2026
- Controller showing 7-segment codes SE S1Thu, 17 Sep 2026
- E-Series SANtricity OS and IOM firmware matrix for support of different drawer control modulesThu, 17 Sep 2026
- How to identify the various E-Series drawer types in DE460C enclosureThu, 17 Sep 2026
- "DRAWER_OPENED-Recovery Failure Type Code: 344" reported in Recovery Guru of E-Series array when drawer is closedTue, 15 Sep 2026
- E-Series Core Dump Captured and Multiple Drive Path Degraded AlertsTue, 15 Sep 2026
- E-Series VOLUME_HOT_SPARE_IN_USE after disk replacementTue, 15 Sep 2026
- E-series Not able to display old graphical performance statistics in SANtricity System ManagerMon, 14 Sep 2026
- SuperPod EF Series during replacement reports I2C busy needs recoveryTue, 08 Sep 2026
