NetApp HCI Operating System
Other Resources
Here is some sample text for the Resolution Guides tab.
- Network configuration mismatch after upgrade to 12.9Thu, 09 Apr 2026
- NetApp HCI - vusb0 shows up after upgrade ESXi version 7 to 8Thu, 26 Feb 2026
- Management Node boots into Emergency ModeTue, 03 Feb 2026
- NetApp SolidFire cluster reports duplicate IP alerts and MVIP instabilityWed, 14 Jan 2026
- Error creating static routes in NetApp Element softwareFri, 05 Dec 2025
- The Compute node boots directly to Ember instead of ESXiWed, 03 Dec 2025
- Unable to setup NetApp mnode: connection refusedMon, 27 Oct 2025
- What is the recommendation for hyperthreading feature in NetApp HCI ESXi Compute nodeSun, 12 Oct 2025
- Upgrade to vCenter Server 8.0 Fails Due to Weak Signature Algorithm in VASA PluginFri, 19 Sep 2025
- Cannot Mount a Snapshot in Order to Restore a VMSat, 06 Sep 2025
- HCI: How to check available storage and expand a datastore in vSphereMon, 28 Jul 2025
- NetApp HCI - How to identify NDE versionMon, 21 Jul 2025
- Last gcCompleted Event Was Over 12 Hours Ago due to cluster Stopped Reporting to ActiveIQFri, 18 Jul 2025
- Which discovery protocol does NetApp HCI recommend for vDS and vSS, CDP or LLDP?Tue, 17 Jun 2025
- is it possible to change the MVIP IP?Wed, 28 May 2025
- How to change ring buffer size of vmnics on HCI compute nodesFri, 02 May 2025
- ESXi Reporting "Performance Has Deteriorated" Messages for Multiple SolidFire VolumesThu, 24 Apr 2025
- Compute firmware upgrade causes node boot issues and IPMI login failureMon, 21 Apr 2025
- HCI intermittent communication loss between ESXi and vCenterFri, 11 Apr 2025
- vMotion failed because ESX hosts were not able to connect over the vMotion networkTue, 18 Mar 2025
- What is the purpose of the datastores created by NetApp Deployment Engine (NDE) during initial deployment?Thu, 02 Apr 2026
- How to handle certificate that is expired or about to expire from vCenter ServerThu, 19 Mar 2026
- HCI node expansion failing with DNS errorWed, 18 Mar 2026
- Last gcCompleted event was over 12 hours ago: Investigation RequiredTue, 17 Mar 2026
- HCI - How to add an HCI Compute node when Easy Scale failsThu, 12 Mar 2026
- Unable to load BMC Web UI with 500 - Internal Server ErrorFri, 27 Feb 2026
- HCI compute host crashed with uncorrectable memory errorTue, 24 Feb 2026
- vSphere and Windows showing inaccurate capacity sizeThu, 19 Feb 2026
- Error "Unable to connect to the BMC" for compute nodes in HCCMon, 16 Feb 2026
- Logging attempts from the vCenter to the mnodeTue, 10 Feb 2026
- How to setup compute node in Distributed Switch configuration from scratch without using NDE ScaleWed, 21 Jan 2026
- Element cluster upgrade fails with: UpgradeError: Staging storage node <storage node name> failed on mNodeWed, 21 Jan 2026
- Create VMFS datastore failed: cannot change the host configurationWed, 07 Jan 2026
- NDE process stuck connecting to vCenter when trying to scale compute nodeThu, 01 Jan 2026
- How to restore assets from backup json file using mnode-support-utilMon, 08 Dec 2025
- How to backup current inventory using mnode-support-utilMon, 08 Dec 2025
Add code for Video content
Highest rated
(rating)- How to reset BMC on NetApp HCI compute nodes
- lacpApiVersion alert while upgrading vCenter
- NetApp Deployment Engine(NDE) or Scale fails to discover new compute and storage nodes
- System logging is not configured on host
- HCI compute node firmware upgrade error
- ESXi host in hung state
- HCC login to mNode FQDN fails with "Something went wrong during the login process" error
- "Power Supply is unresponsive" on Mellanox SN2010
- Which Mellanox Switches are available for the Netapp HCI?
- FRU Replacements for the Mellanox SN2700 Switch
- Element cluster event: Number of virtual volumes is approaching or has exceeded the maximum recommended limit
- How to troubleshoot HCI Scale using APIPA
- Troubleshoot Invalid Gateway in NDE
- Datastore creation via VCP Element Software Plugin fails with "No available disks to create a datastore on"
- Do HCI's SSDs have the same unexpected failures as VMware KB 79471?
Recently updated
(date updated)- Network configuration mismatch after upgrade to 12.9
Recently added
(date created)- Network configuration mismatch after upgrade to 12.9
