ONTAP Operating System KBs
Other Resources
- Unable to get, delete, update image package to the repositoryApr, 2026
- ONTAP error shows Upgrade is not complete an upgrade task abortedApr, 2026
- Inode nearly full alert threshold set at 80% is breached on SnapMirror destination volumeApr, 2026
- Data Network port degraded due to L2 reachabilityApr, 2026
- Aggregate encryption keys from decommissioned nodes remain in OKMApr, 2026
- WAFL Inconsistent - AutoSupport MessageApr, 2026
- Frequent “Possible Ransomware Activity Detected” alerts on SAN volumes after ONTAP 9.17.1P4 upgradeApr, 2026
- Options to enable FabricPool in system manager Greyed outApr, 2026
- When are AutoSupport triggered during an Automated Non-Disruptive Upgrade in ONTAP?Apr, 2026
- vol.full:alert alert triggered at 99% while vol show command shows only 92% utilizedApr, 2026
- ONTAP Select: NVRAM Device /dev/nvd0 not found when booting into ONTAPApr, 2026
- ANDU Validation Warning Broadcast Domain Ports Cannot Communicate Across NodesApr, 2026
- Ransomware alerts missing after upgrade to 9.16Apr, 2026
- ONTAP ARP Alert: “Possible Ransomware Activity Detected” on NAS Volume after ONTAP upgradeApr, 2026
- All admin accounts are locked and the cluster cannot be accessedApr, 2026
- Snapshots are not being created as per the volumes snapshot policyApr, 2026
- ONTAP Upgrade Validation Fails due to ssh-rsa in hostkey algorithm configurations in FIPS modeApr, 2026
- Rubrik Appliance Connection Issues to NetApp ONTAP due to Role Permission MismatchApr, 2026
- cpeer.xcm.update.warn: Periodic update of peer network information failed. The following operations are incomplete: node/ip map update failed.Apr, 2026
- Volume encryption keys are not restored for non-existent volumes with KMIPApr, 2026
- How to manually upload AutoSupport messages to NetApp in ONTAP 9
- How to perform a health check in ONTAP 9
- How to non-disruptively migrate a node's root volume onto new disks in ONTAP 9
- How to enable SVM scoped Vserver scoped NDMP
- How to configure weekly only AutoSupport messages and exclude daily
- How to set up deduplication compression in clustered Data ONTAP
- How to customize clustered Data ONTAP output formats for easy importing into Excel
- How to wipe the configuration of a clustered Data ONTAP 8.x node and re-initialize it
- How to Netboot Clustered Data ONTAP 8.1x (and later)
- How to efficiently search the event log in clustered Data ONTAP
Highest rated
(rating)- How to persistently add a static route to force traffic over a specific gateway to the external key manager during boot
- Time delay between NTP servers and NetApp
- What is the difference between SP-Heartbeat and hwassist Keep Alive?
- Error when converting Flex Volume to FlexGroup volume, is not supported
- ONTAP upgrade validation check fails due to TSA Certificate Error
- Does an ONTAP upgrade include BIOS firmware updates?
- configbr.backupFailed EMS messages after ONTAP upgrade
- CVE-2023-48795 SSH Protocol Vulnerability in NetApp Products
- Volumes go offline during ONTAP upgrade to 9.14.1 and above
- How to decode an Autosupport file output with Docker
- disk encrypt show hangs after sanitize
- vifmgr.clusterBD.Partition Error
- Is it possible to exclude items from multi-admin-approval by a name pattern?
- Error: "show" is not a recognised command when displaying encryption keys
- How to check supported ONTAP version for a NetApp storage platform in Hardware Universe
Recently updated
(date updated)- Unable to get, delete, update image package to the repository
Recently added
(date created)- Frequent “Possible Ransomware Activity Detected” alerts on SAN volumes after ONTAP 9.17.1P4 upgrade
- Autosupport alerts still sent to invalid email address after modification
- Is it possible for the AutoSupport notification time for ARP and the threat detection time shown in ONTAP System Manager to be different?
- Can wometric Key Manager connect with NetApp AFF-C30
- SVM Root Volume move stuck in cutover commit phase resulting in loss of access to vols in SVM
- Network switch does not advertise connected data ports via LLDP
- AutoSupport fails with SMTP authentication error (client not authenticated)
- Can you use secure purge on NAE volumes?
- EMS message NTP CLOCK SKEW DETECTED error reported on ONTAP
- How does ONTAP display the target of a quota report for default user quotas?
- What is the time required to create a Snapshot copy for a large volume in ONTAP 9
