NetApp Knowledge Base
ONTAP AutoSupport (Transport HTTPS) Delivery Failure Resolution Guide
8,845
Visibility:
Votes:
7
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • AutoSupport
  • Transport
    • HTTPS
See below for instructions on how to resolve AutoSupport issues related to Delivery or Transmission failures with the transport protocol configured as HTTPS.
Procedure
  1. Verify the current configuration
cluster1::> autosupport show -node <node name> -instance
Node: cluster1-1a
State: enable
SMTP Mail Hosts: mailhost
From Address: admin@email.com
List of To Addresses: address1@email.com,address2@email.com
List of Noteto Addresses: -
List of Partner Addresses: -
Send AutoSupport Messages to Vendor Support: enable
Protocol to Contact Support: HTTPS
Support Proxy URL:
Note: If Protocol to Contact Support is set to SMTP and not HTTPS, refer to the SMTP Delivery Failure Resolution Guide
  1. Verify Connectivity
cluster1::> system node autosupport check show-details -node cluster1-1a
Node: cluster1-1a
Category: https
          Component: https-put-destination
             Status: failed
             Detail: HTTPS PUT connectivity check failed for destination:
                     https://support.netapp.com/put/AsupPut/. Error: Timeout
                     was reached when connecting to the server -
                     'support.netapp.com'
  Corrective Action: Possible network configuration issue. Ensure that you
                     have network connectivity
          Component: https-post-destination
             Status: failed
             Detail: HTTPS POST connectivity check failed for destination:
                     https://support.netapp.com/asupprod/post/1.0/postAsup.
                     Error: Timeout was reached when connecting to the server
                     - 'support.netapp.com'
Category: on-demand
          Component: ondemand-server
             Status: failed
             Detail: AutoSupport OnDemand connectivity check failed for
                     destination:
                     https://support.netapp.com/aods/asupmessage. Error:
                     Timeout was reached when connecting to the server -
Category: configuration
          Component: configuration
             Status: ok
             Detail: No configuration issues found.
5 entries were displayed.
  1. Review the table below to find a Solution with a matching Error description
Error Solution
  • Could not resolve host - 'support.netapp.com'
  • Timeout was reached when connecting to the server - 'support.netapp.com'
  • Peer certificate can not be authenticated with given Certificate Authority certificates.
  1. (Optional) The output of notifyd.log may contain additional information:
cluster1::> node run -node (node name) -command rdfile /etc/log/mlog/notifyd.log
  • copy the output to your favorite text editor
  • To locate the error: Use ctrl F and search
In most cases you may start from the following line (message: Closing connection #0) and work up to the true error message.
Use the following Table for additional messages to look for in notifyd.log:
Error Solution
  • Failed to connect to support.netapp.com port 443: Operation timed out
  • message: Could not resolve host: support.netapp.com
  • message: SSL certificate problem: unable to get local issuer certificate
  • message: SSL certificate problem: self signed certificate in certificate chain
  • Error: Peer certificate can not be authenticated with given Certificate Authority certificates
  • message: error:0E065068:configuration file routines:STR_COPY:variable has no value
  • message: HTTP/1.1 302 Moved Temporarily
  • message: deliver_http_asup: HTTP PUT request failed, code: 302
  • HTTP/1.1 403 Forbidden
  • message: error:0D0C50A1:asn1 encoding routines:ASN1_item_verify:unknown message digest algorithm
  • message: OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to support.netapp.com:443
  • OpenSSL SSL_read: SSL_ERROR_SYSCALL, errno 54
  • error:0E079065:configuration file routines:DEF_LOAD_BIO:missing equal sign
  • message: error:0A000152:SSL routines::unsafe legacy renegotiation disabled
Other Useful Commands:
  • Review AutoSupport History
cluster1::> system autosupport history show -node * -fields node ,seq-num ,status ,error ,destination
seq-num destination status error
39      smtp        ignore ""
39      http        transmission-failed
39      noteto      ignore ""
38      smtp        ignore ""
38      http        sent-successful ""
38      noteto      ignore ""
Additional Information
