SANtricity OS KBS
SANtricity OS KBS
Featured
Collecting E-Series Support Data
How to collect support data for NetApp E-Series Storage Arrays
E-Series Health Image
How to retrieve a core dump from an E-Series storage system
Performance
How to troubleshoot performance step by step
Host Multipath Driver Configuration Error
Troubleshooting E-Series Host multipath driver configuration error alert
Volume Not on Preffered Path
How to troubleshoot Volume not on preffered path
Host Redunancy Lost
How to troubleshoot Host Redundancy Lost Alerts
Other Resources
- SANtricity reports Directory Services Server Connection Failed eventNov, 2026
- Unable to display Event Log in SANtricity System ManagerNov, 2026
- SANtricity upgrade reports an unknown issue occured while performing the upgrade operationOct, 2026
- E-Series Pre-upgrade check fails with Too many destination driver eventsOct, 2026
- E-Series SANtricity OS upgrade fails with timestamp validation failure for DLP fileOct, 2026
- How does E-Series volume host mapping works while using host or host cluster configurationOct, 2026
- Unable to connect RHEL 8.10 to NVMe over InfiniBand on EF300Oct, 2026
- Can SANtricity send standard alert notifications for GUI or SSH login and failed password attempts?Oct, 2026
- E-Series EF80 “Database was closed” API Error Due to WebServer Partition FullOct, 2026
- E-Series Recovery guru reports Storage Array Component - Loss of Communication after upgrading the NVSRAM firmwareOct, 2026
- E-series management port connectivity issue when management port and iSCSI port at saOct, 2026
- E-series Luns missing after controller rebootOct, 2026
- E-Series controller lockdown resolution guideOct, 2026
- Can adding a server to an existing host cluster in E-Series SANtricity affect access to existing cluster volumes?Oct, 2026
- E-Series failed disk pool volumes on SANtricity OS 8.40.40.00/8.52.00.00 and later releasesOct, 2026
- Frequent NTP Query Failed and NTP Service Unavailable Alerts in SANtricityOct, 2026
- Some drives in E-Series randomly reports "Drive shelf path redundancy lost" after resolving unrecognizable Drive DACStoreOct, 2026
- E-Series controllers hit SIGSEGV and lock down during volume reconstruction after a parity mismatchOct, 2026
- EF600 unexpectedly reboots on iSER or NVMe due to access to invalid memory addressOct, 2026
- KMIP Server Connection Failure after controller replacementOct, 2026
