SolidFire Hardware KBs
Featured
Unresponsive BMC
Troubleshooting unresponsive BMC on H610S
BMC Self Test
BMC Self Test failed
SensorReadingFailed
SensorReadingFailed': IPMI diagnostics are currently unresponsive
Input Missing or Out of Range
Power supply PSx input missing or out of range
DriveAvailableWarning
DriveAvailable Warning AutoSupport Message
Other Resources
- driveFailed alert occurs due to a storage node being offlineWed, 04 Mar 2026
- H610S alert: BMC logs report ECC errors for the NVRAM DeviceFri, 12 Dec 2025
- A storage node becomes unresponsiveSat, 22 Nov 2025
- A drive is in the DriveMissing stateSun, 02 Nov 2025
- Stale driveFailed alert remains in cluster WebUI despite drive being healthyMon, 29 Sep 2025
- energySourceLifetimeStatus alert occurs on H610S and resolves itselfThu, 18 Sep 2025
- How to remove NVIDIA Drivers from an ESXi hostMon, 18 Aug 2025
- SSL Certificate Chain Contains RSA Keys Less Than 2048 bits reported for H610S BMCMon, 11 Aug 2025
- CVE-2023-48795 SSH Terrapin Attack vulnerability reported for SolidFire and HCI NodesMon, 11 Aug 2025
- Incorrect bond port counts detected on the sipi interfaces of nodesFri, 08 Aug 2025
- The H610S system automatically powers on after connecting the powerFri, 01 Aug 2025
- blockServiceUnhealthy occurred from multiple drivesSun, 13 Jul 2025
- H610S node reboots unexpectedly with critical medium errors on multiple drivesFri, 20 Jun 2025
- Active IQ reports bmcSelPCIeError, and the slot links down and up repeatedlyMon, 09 Jun 2025
- Incorrect node replacement process causes data unavailable with 2nd hardware failureMon, 19 May 2025
- Phantom hard drive found on SolidFire storage nodeTue, 06 May 2025
- SolidFire H410S node reboots unexpectedly with CPU Fatal error - AssertionTue, 24 Dec 2024
- Unable to access H410S IPMI via shared port after power drainThu, 05 Dec 2024
- SF19210-all drives marked as DriveMissing and then moved to available stateTue, 26 Nov 2024
- H610S BMC WebUI can't access after IP changedSat, 23 Nov 2024
- What are the arguments for the Element sfinstall script?Fri, 24 Apr 2026
- BMC SEL error: Volt_P3V_BAT and Volt_P12V Lower Critical AlertsThu, 23 Apr 2026
- How to remove NVIDIA Drivers from an ESXi hostMon, 13 Apr 2026
- Active IQ reports bmcSelPCIeError, and the slot links down and up repeatedlyMon, 13 Apr 2026
- Uncorrectable ECC error detected in SEL Log in H610S with BIOS 3B11Tue, 07 Apr 2026
- AutoSupport Message: Element metadataClusterFull alertsMon, 23 Mar 2026
- Drive failed with state NvmeCapacitanceMon, 09 Mar 2026
- Element node fileSystemIsReadOnly /var/log is in Read-Only mode due to boot device issueFri, 20 Feb 2026
- AutoSupport Message: SolidFire Drive status=*REMOVEDThu, 19 Feb 2026
- Abnormal Disk I/O Persists on LACP Bond After Switch Port Reset and TCAM MisconfigurationTue, 10 Feb 2026
- Linux Virtual Machine lost access to SolidFire iSCSI Storage VolumesWed, 28 Jan 2026
- Correctable ECC memory error causes driveAvailableSat, 24 Jan 2026
- ExcessiveCapacitorVoltage alert on NetApp Element storage nodesTue, 20 Jan 2026
- How to archive a SolidFire/HCI cluster in Active IQThu, 15 Jan 2026
- Cluster UI reports "The user name and/or password is not correct" post upgradeWed, 07 Jan 2026
- restoredIncompleteFlashImage alert on SolidFireTue, 06 Jan 2026
- Upgrade drive firmware GXT5104Q to correct level in Element using iRTFISat, 22 Nov 2025
