NetApp Knowledge Base
ONTAP AutoSupport Networking resolution guide
4,544
Visibility:
Internal
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • AutoSupport
  • Transport
    • HTTP(s)
    • SMTP
  • Networking
This guide will help you identify the proper solution based on your networking issue.
For example:
  • Operation timed out
  • No route to host
  • couldn't connect errors
These indicate that either ONTAP is using an invalid route or it could not obtain a route.
  • Review the LIF and route configuration to ensure ONTAP is using the management interface. (node mgmt and cluster mgmt LIF)
For a smoother experience, run the following command to gather your Nodes configuration
Verify your current configuration
::>autosupport show -node <node name> -instance
Node: cluster-01
State: enable
SMTP Mail Hosts: mailhost
From Address: admin@email.com
List of To Addresses: address1@email.com,address2@email.com
List of Noteto Addresses: -
List of Partner Addresses: -
Send AutoSupport Messages to Vendor Support: enable
Protocol to Contact Support: HTTP or HTTPS
Support Proxy URL:
Verify Connectivity is good
cluster1::> system node autosupport check show -node node2
                            On Demand
Node             HTTP/HTTPS Server     SMTP       Configuration
node2            ok         ok         ok         ok
Connectivity fails
  • If connectivity fails, you must check connections and firewall rules are allowed to reach support.netapp.com
Procedure
Networking error Solution
Operation timed out
  • LibCurl Error (6): Couldn't resolve host name
  • Error: Could not resolve host
  • message: Couldn't resolve host 'support.netapp.com'
failed to connect to 2620:10a:4005:c000::a78:2d11: No route
to host
This can usually be ignored.  If you are using IPv6 for your Admin SVM, then this is relevant .. otherwise it is just a symptom of a routing issue, either IP config, routing or hostname resolution.
message: connect to 216.240.21.18 port 443 failed: Connection refused
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
