NetApp Knowledge Base
How to identify controller chassis slot position for AFF and FAS models within ONTAP
1,149
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF Models
  • FAS Models
NetApp AFF and FAS models are configured within a chassis that can hold up to two controllers.  Depending on the model the configuration will be either a top and bottom controller configuration or left and right controller configuration.  Note:  For left and right configurations it is designated as you are looking at the chassis from the back of the system where the controllers are inserted.
New to NetApp?
