NetApp Knowledge Base
Fault reported on disk storage shelf: missing cable info
535
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
Issue
  • EMS-LOG-FILE section of the AutoSupport:
Wed Jun 24 01:00:00 CEST [NETAPP_01: statd: monitor.shelf.warning:error]:
Fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
  • The ENVIRONMENT section of the AutoSupport has cable information missing
Channel: 0b
Shelf: 0
SAS cable information by element:
   [1] Internal connector
   [2] Vendor: Amphenol
       Type: MINI-SAS HD passive copper 5m  ID: 01  Swaps: 0
       Serial number: APF16330153087  Part number: 112-00437 A0
   [3] Internal connector
   [4] Vendor:
       Type: <N/A> <N/A> <N/A>  ID: 00  Swaps: 0
       Serial number:   Part number:                            <==== cable information missing
  • The corresponding Controller Module is reseated, issue remains
  • Shelf firmware is on the latest version
New to NetApp?
