NetApp Knowledge Base
How does Active IQ Upgrade Advisor help to perform an ONTAP upgrade or revert ?
26,847
Visibility:
Votes:
3
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • Data ONTAP 8 7-mode
  • AutoSupport
  • Active IQ Upgrade Advisor
  • FAS/AFF systems
Answer
The ONTAP Upgrade Advisor is a tool within Active IQ that will provide a plan with steps and commands to successfully perform a ONTAP upgrade or revert. The plan also contains context-sensitive links to the following:
  • Pre and post-upgrade checks
  • Issues and risk exposures
  • ONTAP Release Notes
  • Links to shelf module, system, and diagnostic FW
How to Use Upgrade Advisor via Active IQ Digital Advisor
