NetApp Knowledge Base
DS460 Drawer Critical/Critical state and offline aggregates on FAS8300
197
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • DS460C
Issue
  • System reported a hardware fault where Drawer 1 on shelf 1.10 entered a critical/critical state
  • All 12 disks in the drawer showed as unknown container types
  • Aggregates aggr0_n1 and aggr1_n1 on node node-01 were offline
Example:
cluster::*> storage shelf drawer show
Drawer  Shelf Drawer Status   A/B Closed? Count Firmware A/B
1.10   1     critical/critical closed 12/...
cluster::*> disk show -container-type unknown
Usable Disk Container Container
Disk     Size  Shelf Bay Type Type Name Owner
1.10.12  14.26TB 10 12 FSAS unknown - node-01
cluster::*> aggr show
Info: Node node-01 that hosts aggregate aggr0_n1 is offline
      Node node-01 that hosts aggregate aggr1_n1 is offline
New to NetApp?
