NetApp Knowledge Base
Data Infrastructure Insights Acquisition Unit install/upgrade Resolution Guide
1,552
Visibility:
Votes:
3
Category:
data-infrastructure-insights
Specialty:
ds_dii
Last Updated:
Applies to
  • Data Infrastructure Insights (DII) (formerly Cloud Insights)
  • Acquisition Unit (AU) installation/upgrade
Solutions
This Resolution Guide is intended to provide guidance on known issues related to installation or upgrade of DII Acquisition Unit (AU)
Description Link
Ensure the Acquisition Unit Host operating system meets minimum requirements
Acquisition Unit installation minimum requirements
Insufficient memory after AU upgrade Data Infrastructure Insights Acquisition Service on Linux host fails to start due to insufficient memory after AU upgrade
Special characters in proxy credentials not supported.
Failed to install acquisition unit in Data Infrastructure Insights due to special characters in proxy credentials
Some proxies attempt to perform TLS/SSL inspection by impersonating DII web sites with digital certificates not generated from NetApp.
Data Infrastructure Insights Acquisition Unit fails to connect for new install
Some firewalls may not allow the use of wildcard rules.
Data Infrastructure Insights Acquisition Unit install fails on logging in to Data Infrastructure Insights
Java is used during AU installation
A security scan reveals an outdated version of Java installed on a Data Infrastructure Insights Acquisition Unit in the 3rdparty directory
DII and the Acquisition Unit are not able to make changes to the vault storing the keys used to encrypt and decrypt data collector passwords
Data Infrastructure Insights data collectors polling error indicates the password cannot be decrypted after re-installing an Acquisition Unit
