NetApp Knowledge Base
How to RTFI a NetApp HCI node or Storage Node using a USB key
5,214
Visibility:
Votes:
5
Category:
netapp-hci
Specialty:
hci
Last Updated:
Applies to
  • NetApp HCI Compute nodes
  • NetApp HCI Storage nodes
  • FC series nodes
Use this procedure to RTFI an HCI node using a USB key
  • For compute nodes that already have ESXi installed
    • This procedure with NetApp HCI 1.6+ Compute BootStrap OS ISO image will update the firmware and the Bootstrap OS on that compute node, leaving ESXi and configuration data intact
    • The only way to reset an existing ESXi installation starting with NetApp HCI 1.6+ is to use the Factory Reset option from the Compute TUI
  • For the HCI storage nodes
  • For the HCI compute nodes
    • It is recommended to use Linux dd command to do a raw copy of the Compute BootStrap OS ISO image onto the USB key
      • Note: due to the larger size of the compute ISO image, it is possible that RTFI may show failures if the USB key is created using 3rd party USB creator applications.
New to NetApp?
