NetApp Knowledge Base
How to configure a node with 10G cluster ports on a new cluster setup using the X1147A card
1,718
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • AFF A400
  • FAS 8300
  • FAS 8700
  • New Cluster Setup
Certain platforms support 10G connections to legacy Cluster Interconnect switches using a X1147A card in slot 2
  • The cluster will attempt to use e3a and e3b as its cluster connections by default.
  • This procedure outlines the steps to modify the Cluster ports during cluster setup to use the 10G ports in Slot 2.
New to NetApp?
