NetApp Knowledge Base
DS460 disk shelf shows fans unavailable
916
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • DS460C Disk shelves
Issue
  • EMS log shows following messages:
[Node-01: dsa_disc: ses.status.fanError:EMERGENCY]: DS460-12 (S/N XXXXXXXX) shelf X on channel 2d cooling fan error for Cooling element 8 7 6 5: critical status no redundancy. This module is on the rear of the shelf to the right.
  • The impacted shelf shows the following fan status in environment:
::> system node run -node <nodename> -command environment status
Cooling Units by element:
[1] 5100 RPM
[2] 4500 RPM
[3] 5070 RPM
[4] 4500 RPM
[5] Unavailable<--
[6] Unavailable<--
[7] Unavailable<--
[8] Unavailable<--
  • Storage fault shows 'NOT INSTALLED' for the Fans Element Status similar to the following:
::> system node run -node <nodename> -command storage show fault -v
Fans:
Element Status         Status Bytes  Status Descriptions
  1: OK                01,05,13,A6
  2: OK                01,04,41,A5
  3: OK                01,04,4A,A5
  4: OK                01,04,56,A5
  5: NOT INSTALLED     05,00,00,20
  6: NOT INSTALLED     05,00,00,20
  7: NOT INSTALLED     05,00,00,20
  8: NOT INSTALLED     05,00,00,20
  • Fan module is replaced, but the issue remains.
New to NetApp?
