NetApp Knowledge Base
Amber LED after disk replacement due to disk autoassign misconfiguration
1,524
Visibility:
Votes:
0
Category:
disk-drives
Specialty:
hw
Last Updated:
Applies to
  • All FAS/AFF platforms.
  • ONTAP 9
Issue
  •  After disk replacement the Amber LED is ON
  • Fault status reported by drive:
cluster::> system node run -node node1 -command storage show fault -v
18 [Bay 18]: OK 01,12,00,20 FAULT REQSTD
New to NetApp?
