NetApp Knowledge Base
E-Series Persistent cache backup device has failed - AutoSupport Message
6,825
Visibility:
Votes:
1
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series
Event Summary
  • Persistent cache backup device has failed is reported in the events log on SANtricity
  • CACHE BACKUP DEVICE - Failed error message is showing in the Recovery Guru.
    • Additionally, a  CACHE_BACKUP_DEVICE_INSUFFICIENT_CAPACITY recovery guru failure entry may be logged.
  • The mSATA drive, used for flushing cache in the event of a power down or sudden loss of power, has failed.
    • Depending on the system configuration, an alert may be displayed indicating that the cache is disabled or suspended. This is to be expected if the cache backup device fails.
      • Failure Entry 2: WB_CACHING_FORCIBLY_DISABLED-Recovery Failure Type Code: 378
Validate
  • The Storage Array Profile log indicates that the cache backup device has failed.
  • Example:
Cache Backup Device
            Status:                    Failed
            Type:                      SATA flash drive
            Location:                  Controller A, Connector SATA 1
            Capacity:                  8,192 MB
            Wear Life Used:            0%
            Endurance Remaining:       100%
            P/E Cycles:                15
            Product ID:                ATP SATA III mSA
            Part number:               Not Available
            Serial number:             210703540063
            Revision level:            R082
            Manufacturer:              ATP
            Date of manufacture:       Not available
Resolution
The solution might require a part replacement. Please contact NetApp Technical Support or log into the NetApp Support Site to create a case. Reference this article for further assistance.
New to NetApp?
