NetApp Knowledge Base
What are the best practices of shelf numbering for attaching SAS shelves to a storage system?
4,648
Visibility:
Votes:
7
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9 OS
  • Disk Shelves
  • SAS Shelves
Answer
Check Active IQ if this impacts your systems
Each SAS shelf directly attached to a High-Availability (HA) controller pair, or to a standalone non-HA controller, requires a unique Shelf ID in the range 0-98. In instances where the node contains internal disks, the internal shelf is set to ID 0, leaving ID's 1-99 available for external shelves.
In an ONTAP 9 environment, the shelf IDs only need to be unique within an HA pair, not across the entire cluster.
For example, if HA pair Node01/Node02 used Shelf ID 10, then HA pair Node03/Node04 may also use Shelf ID 10, if so desired.
Note that when Shelf IDs are repeated across a cluster, extra care should be taken to ensure that any maintenance required is performed on the correct shelf - such as verifying the shelf serial number - and not relying soley on the Shelf ID for identification.
Note: NetApp recommends numbering shelves in stacks by the 10's rule.
For controllers with no internal disks, the numbering would be as follows:
Nodes 1/2:
  • Stack 1 contains shelf ID's 0-9
  • Stack 2 contains shelf ID's 10-19
Nodes 3/4:
  • Stack 1 contains shelf ID's 20-29
  • Stack 2 contains shelf ID's 30-39
In the case of controllers with internal disks (e.g. AFF A150) the shelf ID of the controller chassis is 0. The numbering would be as follows:
Nodes 1/2:
  • Stack 1 contains shelf ID's 1-9
Nodes 3/4:
Additional Information
Further information regarding specific shelves may be found in the documentation library.
