NetApp Knowledge Base
Transient AutoSupport (BATTERY (capacity low)) NOTICE message
5,232
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • AFF A250
  • Baseboard Management Controller (BMC) fw. 15.1
Issue
  • EMS message:
HA Group Notification from node_name (BATTERY(capacity low)) NOTICE
  • One or both nodes report the same issue, cleared a few seconds later:
Fri Aug 06 10:15:39 +0200 [node_name_1: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
Fri Aug 06 10:16:39 +0200 [node_name_1: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
Fri Aug 06 10:32:49 +0200 [node_name_1: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
Thu Aug 05 00:02:49 +0200 [node_name_2: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
Thu Aug 05 00:03:49 +0200 [node_name_2: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
Thu Aug 05 00:32:09 +0200 [node_name_2: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
  • No other related errors reported.
  • A high amount of traffic can be noticed in the BMC/e0M ports. Example:
eth0      Link encap:Ethernet  HWaddr D0:39:EA:47:11:31
          inet addr:192.168.0.1  Bcast:192.168.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:539889 errors:0 dropped:277459 overruns:0 frame:0
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:54208615 (51.6 MiB)  TX bytes:624 (624.0 B)
          Interrupt:32
-- interface  e0M  (34 days, 11 hours, 25 minutes, 25 seconds) --
RECEIVE
 Total frames:      110m | Frames/second:      37  | Total bytes:     20986m
 Bytes/second:     7045  | Total errors:        0  | Errors/minute:       0
 Total discards:      0  | Discards/minute:     0  | Multi/broadcast:   569k
New to NetApp?
