NetApp Knowledge Base
Shelves not displayed correctly after recabling
279
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8700
  • ONTAP 9.7P9
  • DS2246 Disk Shelf
  • I/O Module (IOM) firmware 191
Issue
  1. ::> node run -node <node> sysconfig -a displays shelves only on one path
slot 0: SAS Host Adapter 0d (Broadcom SAS3616W rev. 2, SAS, <UP>)
       Firmware rev:      12.00.00.00
       NVDATA rev:        12.03.01.02
       Base WWN:          5:00a098:00e41eb:73
       Phy State:         [0] Enabled, 6.0 Gb/s
                          [1] Enabled, 6.0 Gb/s
                          [2] Enabled, 6.0 Gb/s
                          [3] Enabled, 6.0 Gb/s
       Mini-SAS HD Vendor:        OEM
       Mini-SAS HD Part Number:   CAB-Q10/Q10-P1M+01
       Mini-SAS HD Type:          Passive Copper (unequalized) 0.5m end_0
       Mini-SAS HD Serial Number: M200901510002
       30.0 : NETAPP   X426_STBTE1T8A10 NA02 1713.5GB 520B/sect (S3Z0P62K)
       33.23: NETAPP   X426_HCBFE1T8A10 NA05 1713.5GB 520B/sect (08GEATPA)
       Shelf 30: DS2246  Firmware rev. IOM6 A: 0191  IOM6 B: 0191
       Shelf 31: DS2246  Firmware rev. IOM6 A: 0191  IOM6 B: 0200
       Shelf 32: DS2246  Firmware rev. IOM6 A: 0200  IOM6 B: 0200
       Shelf 33: DS2246  Firmware rev. IOM6 A: 0200  IOM6 B: 0200
slot 1: SAS Host Adapter 1c (Broadcom SAS3616W rev. 2, SAS, <UP>)
       Firmware rev:      17.00.00.00
       NVDATA rev:        17.01.00.11
       Base WWN:          5:00605b:01098a9:88
       MFG Part Number:   111-04226
       Board Name:        HBA 9405W-16e
       Assembly:          03-50044-10006
       Serial number:     SPB0521908
       Mini-SAS HD Part Number:   1110683242+00
       Mini-SAS HD Type:          Passive Copper (unequalized) 2m
       Mini-SAS HD Serial Number: M200901510028
  1. System Storage configuration is in Multi-Path HA
NetApp Release 9.7P9: Thu Nov  5 20:15:56 EST 2020
    System ID: 0123456789 (node-01); partner ID: 0987654321 (node-02)
    System Serial Number: 212121212121 (node-01)
    System Rev: B2
    System Storage Configuration: Multi-Path HA
  1. Shelf cabling has recently changed
New to NetApp?
