SMI-S KBs
SMI-S KBs
Resources
Add Link Here
Add Desc here
Add Desc here
Add Link Here
Add Descriotion Here
Other Resources
- Unable to create new LUNs via SCVMM/SMI-S Provider on ASA-C800Wed, 22 Apr 2026
- Is it possible to install two NetApp SMIS Provider installed on the same Windows SCVMMSat, 21 Mar 2026
- Whats the default time for the NetApp SMI-S Provider refresh?Mon, 02 Mar 2026
- SMI-S connection to SCVMM failed with WinRM Unknown error (0x803380e5)Wed, 15 Oct 2025
- How to upgrade SMI-S ProviderWed, 28 May 2025
- NetApp SMI-S Provider fails to add Cluster with err=10061Thu, 14 Dec 2023
- SMI-S discovery issues with ServiceNow agentTue, 13 Dec 2022
- AUTO-ARCHIVED: NetApp SMI-S Provider is unable to generate self-signed certificate for cimserver, 'openssl.cnf is missing'Wed, 08 Jun 2022
- NetApp SMI-S Provider reports the 'cimserver' certificate has expiredFri, 29 Apr 2022
- NetApp SMI-S provider keeps crashing in SCVMMTue, 19 Apr 2022
- Failed to add a E-series to Netapp SMI-S with error HTTP POST 302Mon, 07 Mar 2022
- AUTO-ARCHIVED: SCVMM SMB Share failed with error "The hostname could not be parsed"Wed, 28 Jul 2021
- Adding cluster to the NetApp SMI-S Provider fails with API errorWed, 27 Jan 2021
- Adding the SMI-S provider in SCVMM fails with the error 'A Hardware Management error has occurred trying to contact server'Fri, 22 Jan 2021
- SMI-S Provider cannot be added as provider in SCVMM after deactivation of TLS 1.0 and TLS 1.1 on the clustersFri, 22 Jan 2021
- SMI-S command fails by HTTP 400 Bad RequestTue, 05 Jan 2021
- ServiceNow fails to pull data from NetApp SMI-S ProviderThu, 22 Oct 2020
- How to collect logs from Netapp SMI-S ProviderTue, 14 Jul 2020
- NetApp SMI-S Provider to ONTAP commands fail with "insufficient privileges" errorThu, 18 Jun 2020
- How to create a custom, read-only, ONTAP user, for Netapp SMI-S ProviderThu, 18 Jun 2020
- NetApp SMI-S Provider fails to add Cluster with err=10061Fri, 10 Jul 2026
- NetApp SMI-S Provider reports the 'cimserver' certificate has expiredWed, 21 Jan 2026
- SMI-S connection to SCVMM failed with WinRM Unknown error (0x803380e5)Thu, 16 Oct 2025
- NetApp SMI-S provider keeps crashing in SCVMMMon, 29 Sep 2025
- SMI-S discovery issues with ServiceNow agentThu, 22 Dec 2022
- AUTO-ARCHIVED: NetApp SMI-S Provider is unable to generate self-signed certificate for cimserver, 'openssl.cnf is missing'Tue, 28 Jun 2022
- Adding a storage system in NetApp SMI-S fails with error "CIM_ERROR_FAILED: Filer return: Can't connect to host (err=10061)"Tue, 24 May 2022
- Failed to add a E-series to Netapp SMI-S with error HTTP POST 302Fri, 18 Mar 2022
- AUTO-ARCHIVED: SCVMM SMB Share failed with error "The hostname could not be parsed"Sun, 08 Aug 2021
- How to create a custom, read-only, ONTAP user, for Netapp SMI-S ProviderFri, 04 Sep 2020
