NetApp Knowledge Base
CHASSIS OVER TEMPERATURE SHUTDOWN - AutoSupport Message
8,485
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
Event Summary
[node02: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
The above message appears when the chassis temperature is too hot.
  • The message appears just before system shutdown and indicates a potential environmental problem or faulty hardware in the system, such as a fan failure or a malfunctioning temperature sensor.
  • Systems should be in a data center with ambient temperatures within the operating range of the system. Check Hardware Universe for the specific platform requirements.
Validate
Event log
  • Run event log show -severity * -Message-name *temperature*
[node01: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Midplane 4 Temp is warning high (47 C).
[node01: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Midplane 3 Temp is warning high (47 C).
[node01: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
[node01: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Temperature critical)
[node01: env_mgr: monitor.shutdown.chassisOverTemp:EMERGENCY]: Chassis temperature is too hot: Ambient temperature is warning high. System will be shutdown in 2 minutes[node01: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
[node02: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Midplane 4 Temp is warning high (47 C).
[node02: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Midplane 3 Temp is warning high (47 C). [node01: dsa_worker3: callhome.shlf.overtemp:error]: Call home for SHELF OVER TEMPERATURE 43 C (109 F)
[node01: dsa_worker3: ses.status.temperatureError:critical]: DS4246 (S/N SHJMS000000011A) shelf 0 on channel 0a temperature error for Temperature sensor 1: critical status; overtemperature failure. Current temperature: 43 C (109 F). This module is on the front of the shelf on the left, on the OPS panel.
[node01: env_mgr: monitor.shutdown.chassisOverTemp:critical]: Chassis temperature is too hot: System will be shutdown in 2 minutes
SP/BMC logs will report the same Alerts
  • SP-LATEST-SYSTEM-EVENT-LOG
[IPMI.emergency]: env_mgr triggers OS halt:One or more temperatu
[Controller.notice]: Appliance user command halt.
[IPMI Event.critical]: System power down
[IPMI.notice]: 00ff | 02 | EVT: 6f03ffff | Sensor 255 | Assertion Event, "Storage OS graceful shutdown"
[IPMI.emergency]: Data ONTAP initiated shutdown
Resolution
  1. Check the data center temperature. Is the cooling system working correctly?
    • Check Hardware Universe for the specific platform requirements
    • Check for obstructions blocking air flow
  2. Best practice is to upgrade the SP/BMC firmware to the latest versions because the alert could be due to a firmware issue: Steps to update ONTAP's  Service Processor (SP) or Baseboard Management Controller (BMC)
  3. Follow How to boot a node after a power loss or a high-temperature shutdown in ONTAP
  • If the issue persists and the data center temperature is verified within the accepted operating range, contact Support
The solution might require a part replacement. Please contact NetApp Technical Support or log into the NetApp Support Site to create a case. Reference this article for further assistance.
